Question about Panasonic CQ-DPX33 CD Changer
2001 Lincoln LS Can't get the CDs to eject
Want to take the unit out of the dash to retrieve the CDs. Where is the unit release? What tool should I use?
  • 4 more comments
  • Jim Sloan
    Jim Sloan Aug 19, 2008
    cd error - changer is stuck in change mode - its a 6 disc, in dash...help?
  • Anonymous Sep 10, 2008
    want to eject cds but cd error
  • amthomaz77 Oct 15, 2008
    my CD changer for my lincoln is reading CD error when i push any button and the cd's will not eject
  • Anonymous Oct 15, 2008
    cd stuck in 6 disc changer need to get it out
  • Anonymous Oct 25, 2008
    Is it just me or is this site useless? hopefully no one else here had this issue happen to them the day after they dropped 730.00 for replacement of the "factory upgrade" Sway bar because the front bushings went shitty, and the oxygen sensor - a sweet 127.00 part to get the engine light to go out. I love my lincoln when it works, but this ***** is making me a hater of Lincoln.
  • Anonymous Nov 23, 2008
    i can't eject, load, or change cd's. any ideal how to fix this?
My problem is with the alpine system. it only ejects when cold. if tried when hot it jams and wont play cds or release until cold again. i removed the panel above the radio and place an icepac on the radio and after a while it starts spitting out cds
Posted on Nov 12, 2008
Heater blowing cold air, 2001 Lincoln ls. Where is blend door located?
Under the dash on the heater box . Mite be able to see it from under the dash , or take the glove box out .
Oct 28, 2016 | 2001 Lincoln LS
Were is fuse box b at
The 2001 Lincoln Ls v8 has three fuse boxes Located: 1. Under the Hood on the passenger side, 2. Under the dash on the passenger side behind a kick panel, and 3. In the trunk next to the battery where your spare tire is.
Sep 28, 2010 | 2001 Lincoln LS
Cd player will not eject holds 6 cd 2001 ls licoln says cd error
This happens to me as well, usually if you press and hold the eject button all of the cd's will be ejected. A couple of times I had to use another cd to kind of slide underneath the stuck cd to assist with it ejecting while I pressed the eject button.
Feb 24, 2010 | 2001 Lincoln LS
Cd player on 2001 lincoln ls - cd error when i press load button
My father inlaw just purchased a 2001 lincoln, with a six disc changer, Question is he loaded the unit ,and now he wants to eject the cd's and the changer won't open? any suggestions thanks
Jan 06, 2010 | 2001 Lincoln LS
2001 Lincoln LS: CD Changer wont eject CD's. Keeps saying CD ERROR when I press eject then select any of the 6 CDs. Also, it says slots full when I press load and press any of the 6 CDs. I just bought the...
you really need to take the cd changer out of the dash,and then open the cd changer ,is one of you cds is making the problem,ones is remove it should be working fine,good luck
Sep 17, 2009 | 2001 Lincoln LS
Cd would not eject now wont play or eject or anything.
Start by checking all of the fuses in your car if the radio is not even powering on. If this does not work your next step is to have the unit repaired or replaced at which point the cds can by removed by taking the unit apart. You can do this yourself or take it to a best buy and have it replace with an aftermarket unit which will be much better and a lot cheaper than going back to the dealer
Apr 22, 2009 | Car Audio & Video
When i tried to eject my cd it didnt come out and i cant play cd's it reads error
I have a 2002 LS and sometimes get a problem trying to eject CDs. If your problem is the same as mine, then its relatively simple to get that CD out.
The little access panel on the head unit opens up but the CD does not eject, in my case there is a slight alignment issue and the CD gets stuck when trying to come out. The thing to do is to get a thin blade (a knife works), hit the eject button, pick a slot (any slot), and then slide the blade on the top edge of the CD that you see in the access port. Simply nudge it down and as long as the unit is trying to eject it will come out.
Good luck...
Feb 02, 2009 | 2000 Lincoln LS
Envoy 2004 cd player
I had same problem with a 2005 Envoy in Jan '09. I took it to the ex-GM dealer. He said he'd try. The unit would only play using radio.
Mechanic took unit out of dash, and top off of unit. Ejected CD bu moving the eject mechanism. Replaced top and unit.
Works and plays cds. Cost $25.00 And i tipped the mechanic $10.00 for his knowledge.
Jan 30, 2009 | 2004 GMC Envoy
2003 Lincoln LS
My 2001 Lincoln LS has done this 3 or 4 times in the last 8 years. I disconnected the battery (for a minute), pulled the fuse, held the 'load' 'eject' button simultaneously for about 1 minute, banged on the dash, slid a credit card along the opening...prayed : ) For 2 days it wouldn't work. Then today I pressed the CD button and it worked. I immediately removed the one 'burned' CD that I had in slot 5, The only think I can think might have affected it was-
1. Put in a new CD that one of our local gospel groups made.
2. Weather had been quite warm, then 2 days ago, it got freezing cold outside again????
I don't know? Probably just an idiopathic occurrence.
It is the Alpine head, LS sports package.
Oct 18, 2007 | Car Audio & Video
Panasonic CQ-DPX33 CD Changer Logo
913 people viewed this question
Top Panasonic Car Audio & Video Experts
xxxxxx xxx
Are you a Panasonic Car Audio and Video Expert? Answer questions, earn points and help others
