Question about Refrigerators
Bosch Fridge Freezer KGV2604G (9 years old) , compressor does not kick when Fridge warms up. Fridge has to be turned off, left for a while, then truned on before the compressor starts to work and cool the fridge to the required temperature.
  • Anonymous Aug 05, 2008
    We just started to notice problems with the same model (almost exact same age as well). I had to max-out the fridge to get it to start again; but I will try you on/off approach.
    Have you checked for any gas leakage? Pull the unit out and look around the back for signs of frost. That's a leak. Rub some liquid soap around the joints near the compressor and see if there is any bubbling, that also shows a leak. Although I doubt a leak is your problem - it sounds more like the thermostat or something.
See here for how to fix: http://www.howtomendit.com/answers.php?id=17078
(Scroll to bottom. I just use a piece of insulated wire to create the short.)
Posted on Aug 10, 2008
I have an LG fridge w/bottom freezer model LRBN22511TT approx 9 yrs old. Actually haven't had any troubles with the unit until recently. It seems the compressor isn't coming on, but there is an occasional...
9 years should not be a death warrant. I believe your defrost relay (bottom front area under grill) has gotten stuck on. It's a small black box about 3x4inches with a timer motor built in it. When it is ON the heater in the freezer coils turns on and defrosts. When it turns back OFF the compressor is allowed to come back on.
Dec 05, 2010 | Refrigerators
Started leaking water out the freezer door and ice was melting last nite... bad timing we just got a snow storm here in NC last nite. Seems to be running but food is defrosting. Its a GE Side by Side about...
Normal 0 MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} . Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay.
Check to see if the condenser fan at the back underneath near the compressor is running. If no check fan.
Are the condenser coils near there warm or room temp. should be warm
How to check stuff>
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Is the evaporator fan in the freezer running. It blows cold air into the fridge side through a damper in the wall between the freezer and fridge. Make sure the damper is open.
Below the evaporator fan is the evaporator coils. Remove the back cover in the freezer to observe the frost pattern. Light frost everywhere(NORMAL) or a partial pattern of ice(LOW ON FREON) or nothing(LOW FREON OR COMPRESSOR PROBLEM).
Jan 30, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Fridge/Freezer cools intermittently
It could be the thermostat. When you catch it in a cycle where it's warming up, gently tap the dial with the handle of a screw driver. If it starts chances are it's bad. If you know electricty you can jump the two terminals on the thermostat to do this test.
Aug 25, 2009 | Danby 3.6 cu. ft. / 102 liter Chest...
My Kenmore fridge/freezer side by side isn't staying cold
Ok so we just had our Kenmore fridge quit cooling , everything in the freezer defrosted , and we lost a lot of food,BUT my husband ordered a part #8201786 which is a starter , and installed it and it worked! The fridge was clicking but it just wouldnt kick on, and the fan still worked. There are websites that you can order the part from, It cost $63.05 with tax!!!! good luck
Mar 15, 2009 | Kenmore 53642 / 53644 Side by Side...
Faulty Fridge freezer
I suspect you may have a faulty compressor! Do you notice if the compressor starts?
Feb 05, 2009 | Bosch Freezers
FREEZER WORKING - FRIDGE NOT WORKING
Ok, got it sussed! [well here's what I did anyway]...
Quite simply, I turned off the fridge-freezer at the mains overnight and in the morning, broke and chucked out the ice chunks that had lined up in the bottom of the freezer section and then turned it back on. I returned that night to see that it was working fine again! Hallelujah, I got my fridge back!!
So it seems that all it needed was a good long defrost, so far so good! I hope this solves your problem.
Jan 07, 2008 | Bosch Classixx KGV28323 Bottom Freezer...
Refrigerators Logo
144 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
