Question about Toshiba 32A33 32" TV
Help! Menu screens pop up randomly and it won't respond to either the buttons on the remote nor on the TV itself
  • scrider123 Jul 30, 2008
    Toshiba 36' drop/ down menu as a mind of its own! It just drops down whenever, I replaced the remote, no help! HELP
I don't know if this will help your problem, but we were having similar problems with our Toshiba 32A33. None of the buttons on the TV or remote worked, the volume would go up and down uncontrollably, it wouldn't turn back on unless unplugged for several hours
Try either taping a penny very firmly over the TV/video button on the set to keep it depressed at all times, or wedging a piece of plastic in it to keep it down (Cardpsycho's solution).  However you do it, keeping this button depressed solved every problem we had.
Posted on Oct 04, 2008
  • Anonymous Oct 06, 2008
    Hi folks,
    Just to update, the penny method hasn't work very long, but I still couldn't find a piece of plastic to wedge, so now I've tried the corner of a wooden shim.  I wedged it in until the button was depressed, then snapped it off and taped it down firmly.  So far, so good...  Back to the Red Sox for now...
Bush 24 inch tv/dvd combi screen went blank as if it's on standby. won't respond to remote control. one week old. is it seroius?
try switching on tv point remote at the tv pressing the menu/exit button and holding for 10/20 seconds hope this works for you
Oct 07, 2012 | Bush Industries IDLCD26TV16HD LCD TV
Pc monitor "menu" pops up on screen
Probably got over zealous with your cleaning liquid and it has destroyed the key pad behind.
Apr 08, 2017 | Computers & Internet
Tv continues to go to menu screen (not dish menu, tv menu)
sounds like a button is stuck. Remove the battery from the remote and see if this fixes the problem
Sep 07, 2009 | Televison & Video
Front panel buttons and remote have stopped working.
Is the favorite channel menu a function that is normally accessed by a button on the remote?
If so, that button on the remote might be stuck.
If this is the case, the menu may at times pop up all by itself and other buttons on the remote and on the TV's front panel may not respond at all (it had happened on my remotes more than once).
Try to clean the remote control (the housing, rubber pad with knobs, circuit board) with ethyl alcohol, when you clean the housing, you should also clean the holes through which the buttons protrude, there might be some dirt that keeps the button stuck.
It may also be a stuck button on the TV front panel, so check these too.
Also, it could be something else, i just wrote the description of a problem and the solution which to me seemed most likely.
Hope you get it fixed.
regards
3rq8 (Triarcuate)
Jul 25, 2009 | Sony FD Trinitron WEGA KV-20FS100 20" TV
Menu Screen Keeps Coming up on the screen
The most commom causes are One. There ia a stuck button on the tv itself. The Menu button. The membrane switch or the TACT switch is bad and needs to be replaced. The Main bd can also be bad.
Jul 16, 2009 | Philips 42PF9630A 42 in. Plasma Television
Samsung TV HPS4253 menu continues to pop up randomly
Its probably the buttons (hopefully) you can open the tv and disconnect this control panel most of the time. Sometimes the remote (IR) signals go through this board. If the problem continues without board connected, its likely the main board = more expensive (100-300 $ part)
Feb 05, 2009 | Samsung HP-S4253 Television
RCA 52927
Solder Bridge on power switch to ground SW13201
Dec 10, 2007 | RCA P52926 52" Rear Projection Television
Buttons dont respond correctly
Sounds like one or more of the keypad buttons are sticking - That would also cause the remote control to stop functioning.When you saw "P:0 V:0" you somehow managed to put the tv into the service menu. Pull the keyboard away from the plastic buttons and make sure nothing is in the way.
Aug 22, 2007 | RCA P52929 52" Rear Projection Television
Hitachi 60V500A Tv changes inputs by itself
sounds like the tac switches on the actual tv which are very hard to get they may be sticking
Mar 21, 2007 | Hitachi 60V500 60" Rear Projection...
Toshiba 32A33 32" TV Logo
346 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
