FixYa.com
Tags:
Toshiba Refurbished 44MB MFM 3.5 HARD DRIVE  Floppy Drive
Conner CP-3044
By Joey2 - usenet poster
Hi netters,
I have a conner hard disk, model CP-3044, I think it is about 44MB.  Lately, it
seemed to have failed and I am trying to find a replacement.  Would appreciate
if someone could tell me the number of cylinder, sectors etc of this hard disk
and whether it is an IDE, EIDE or whatever.
Incidently, the hard disk comes from my portable PC, an OLIVETTI model M211V.
I have invested heavily on this machine over the years and do not want to see
it go to waste because of the hard disk.  If possible I would like to put in a
larger hard disk, but the PC manual says 100MB is the largest.  Can I push the
limit higher?  How can I reach Olivetti international or for that matter does
conner have an internet address where I can seek help? :]
Thanks in advance.
Andrew Sim.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Aug 11, 2005
Not Rated (0)
Ross
Ross - usenet poster
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
Okay, for you and all who have problems with HDD's :
( Sorry it's large but it helps :)
|       CAP    = CAPACITY IN FORMATTED MEGABYTES
|       CYC    = MAXIMUM NUMBER OF CYLINDER
|       H      = NUMBER OF DATA HEADS
|       RWC    = START REDUCED WRITE CURRENT
|                IF IT'S = CYC + 1 THEN IT IS NOT USED
|       WPC    = START WRITE PRECOMP
|       ENC    = ENCODING METHOD R=RLL, M=MFM
|       RATE   = TRANSFER RATE IN MEGABITS/SEC
|       ACCESS = AVERAGE ACCESS TIME
|       SPT    = SECTORS/TRACK X 512 bytes
|       FH     = FULL HIGH FORM FACTOR
|       HH     = HALF HIGH FORM FACTOR
|       R      = RLL (run length limited)
|       N      = NRZ (non return to zero)
|       M      = MFM (modified frequency modulation)
|       SA     = STAND ALONE
|       Z      = ZBR
ALPS ELECTRIC
MODEL   ST-506  MFM      CAP   CYC  H  RWC  WPC ENC  RATE ACCESS  SPT COMMENTS
DRND-10A        3.5"      10   615  2  616  616 M    5    60 MS   17
DRND-20A        3.5"      20   615  4  616  616 M    5    60 MS   17
        ST-506  RLL
RPO-20A         3.5"      20   615  2  616  616 R    7.5  60 MS   26
DRPO-20D        3.5"      20   615  2  616  616 R    7.5  60 MS   26
AMPEX
MODEL   ST-506           CAP   CYC  H  RWC  WPC ENC  RATE ACCESS  SPT COMMENTS
PYXIS-7         5.25 FH    5   320  2  132  132 M    5    90 MS   17
PYXIS-13        5.25 FH   10   320  4  132  132 M    5    90 MS   17
PYXIS-20        5.25 FH   15   320  6  132  132 M    5    90 MS   17
PYXIS-27        5.25 FH   20   320  8  132  132 M    5    90 MS   17
ATASI
3020                      17   645  3  320  320 M    5            17
3033                      28   645  5  320  320 M    5            17
3046                      39   645  7  320  320 M    5            17
3051                      43   704  7  359  350 M    5            17
3053                      44   733  7  350  -   M    5            17
3075                      67  1024  8 1025 1025 M    5            17
3085                      67  1024  8  -    512 M    5            17
BASF
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these Floppy Drives problems?
Floppy Drives
applications of linear...
1. if a rectangle has a length... Answer This...
Floppy Drives
floppy drive
The floppy drive will not open... Answer This...
Floppy Drives
word problems regarding a...
If you earned an average of... Answer This...
Floppy Drives
maths linear equations
A positive number is 5 times... Answer This...
Floppy Drives
konica floppy photo disks
I have photos on the old konica... Answer This...
Repair Service
Find Floppy Drive Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
