Question about Samson Servo 120 Amplifier
Power input switch to 220V?
The back of the amp says that it can be used in the USA at 115V, or in Europe at 230V.
I got it in the USA and i want to use it here in China, where power is 220V.
I changed to the recommended fuse type, but they blow immediately. Is there some kind of switch I can use to run this here at 220V?? I opened the chassis and none is visible.
  • 143 Answers
This is a bit of a guess, but a lot of "switching" power supplies are capable of using anything from 97 to 230 volts without using a switch to pre-set what you are going to plug them in to. That is a guess about why there is no switch, and if I'm right, it is likely that the capacitors in the power supply are...were...strong enough to survive with American voltage, but 220 is a bit too strong for their age. The repair requires parts and soldering.
I'd like to know the real answer if you eventually get it fixed. Please post it here.
Posted on Jul 23, 2008
Will a Packard bell i media desktop run on united states power ?or is it strictly designed to run on European power ?
Here in the US, and with more than 20 years experience as a computer tech I would venture to answer that almost any computer should work almost anywhere in the world.
You only need to look at the input voltage and make certain the power supply is set to match the line voltage supplied where you are. Standard electricity in Europe is 115v or 220v @ 50hz and in the US it is 115v (almost universally) or 220v (rarely) @ 60hz. The biggest difference is the ac frequency used but for computer power supplies that is immaterial.
A computer power supply converts the ac input power to regulated and filtered 3.3v, 5v, and 12v dc so the ac frequency does not have any affect on the filtered dc output that actually operates the computer. Almost all power supplies have a voltage selector switch near the power cord plug on the back of the computer to choose 115v or 220v. Newer power supplies are designed to be auto selecting on input voltage so even that manual selection is no longer required.
You likely will need a different power cord since the shape of the prongs on power outlets in Europe is always different than here in the US. If I remember correctly from my time in Europe that even varies by country there.
As long as you keep in mind the possible different voltages and the different prong shape and arrangements for the ac power source your packard bell computer should work well here in the US.
Absolute worst case scenario would be that if the power supply already installed in your PC is extremely low quality and was designed to use only one input voltage then it is possible you may need to replace the power supply with one that is designed to be used anywhere.
Mar 02, 2017 | Packard Bell Computers & Internet
If I am hooking up a used water pump and set for 115v setting just like old one and it squeels load but switch to 220v and it quited done to normal will that work for me okay
good question
where are you a 120v usa {backward nation}
region or a 240v region uk or europe 220v ac
you question is far to vague and not right
its set to 240v and its quiet and 120v it squeels
perhaps thats why the old one gave up ???
if you live in a 240v area and the old one failed when set to 120v
its a feking no brainer
the old pump died because it was set to use the wrong voltage
therfore if you live in a 240v area like say the uk or france europe in general 220-240 then set it too 240v and quiet
its obviously happy. and quiet...
Mar 04, 2015 | Washing Machines
How do I wire a cutler hammer a10ago for 115 volt
I'm going to take a guess and say you are dropping a 230v motor down to a 115v motor.
If the original motor on your equipment was 3 phase, then you need to change motors.
On the other hand, if the equipment had a 230v single phase and you are switching the motor wires so you can plug the equipment into an available 115v outlet, then I would suggest reconsidering. I would recommend running a 220v service line to your equipment instead. It will save on your electric bill and the motor will last longer. A 115v motor pulls twice as much amperage as the same motor running on 230v. (it may even be too much for the 115v outlet you are planing on using) Your variable rate electric meter will tell your power company to up the rate you pay per kilowatt-hour when you use power at a lower voltage but higher amperage rate.
That said, you need to make sure that the coil in your fancy starter switch is a 115v coil. (it probably is) When you hook up the 115v plug, you need to make sure that the black wire in the Starter Switch is the wire that the switch borrows power from to kick start the magnet that keeps the circuit closed. Beyond that , you probably don't have to do anything in the switch. If there's a red wire, you can just disconnect it and tape it off and do the same in the plug.
If the a10ago's function is a mystery, it will help to understand how it works:
Basically, the contactor has three switches side by side. Where the power comes into the box, there's what looks like a lot of extra screws. That's where the thermal protector is (circuit breaker) that will protect your motor at the proper level designed for the motor. The switch has a spring that holds it open so the motor won't run. But there's an electro magnet that can hold the circuit closed. That magnet is only energized when the switch is closed because even though one of its leads is connected to the hot side of the switch, the other lead is connected past the contactor which has no power when the switch is off.
Your 'START' push button momentarily energizes the coil (or maybe it just overpowers the spring and physically pushes the switch closed). The switch closes and the motor runs and keeps running because the coil is energized. Your 'STOP' button momentarily cuts current to the coil and the switch pops open.
The purpose of this contraption is:
1. It contains a circuit breaker suited for just the motor that is running, not for every load on the circuit.
2. It has contacts that will wear much longer than a standard switch.
3. If your shop loses power with the motor running and then the power comes back on later, your motor wont start running by itself. It will wait until you press the 'START' button.
Oct 09, 2014 | Saws
My computer will not come on , it is plugged the screem is in power save , it sound like it's dead, I have no solution can you help
Check the power supply first to make sure it hasn't gone bad. Note: I had a case where somebody changed the input voltage from 115V to 230V. It did not work on a 120 Volt outlet until I discovered the red slide switch on the back of the power supply was in the wrong position. Maybe somebody thought it was an on/off switch. It isn't often that people get off so easily, but it's worth a look.
(The voltage setting switch is next to the power cord socket, is generally recessed slightly so it's hard to mess with it. Usually it's colored red, but is sometimes black, and is always marked 115V in the correct position for U. S. operation. If it reads 230V that is the problem, unless you are outside North America and using 230 Volt power. In that situation setting it to 115V may cause major damage.)
Nov 04, 2010 | Computers & Internet
Burnt components on wr55x10942 motherboard
Replace it & the power supply. Make sure that the switch on the power supply is set to 115v for U.S. or to 230v for Europe.
May 14, 2010 | Computers & Internet
Ok i neeed help!!!!!!!! on my power supply there is a switch which you can move to 115 volts to 230 volts. everytime i switch it to 230 volts the computer wont turn on? why is this happening? when i put it...
This is the power supply for your PC, depend on your local country power supply, some country like North US may use 110 V in their daily use electrical stuff and some country like Euro, UK use 240 V.
Your PC power supply is design to suit this 2 type of power input so can be sold everywhere. What u need to do is to make sure your local country power supply voltage and then just switch the input correctly, i think u have done it.
YBC (/\)
Oct 20, 2009 | Computers & Internet
I HAVE A 115V USA HAIR CLIPPER.LIVE IN UK, SO
Look on the side of the clipper handle. You ahould see what appears to be a screw. With your clipper plugged in and turned on, turn that screw with a screw driver in either direction, the noise you are talking about should quiet down quite a bit,
Aug 21, 2009 | Oster Health & Beauty
4600 dell power supply
If you travel to Europe you might need to change your power settings here in the USA we use 110-120v for most household items . Things like AC,ovens,and dryers. use 220v. Larry
Mar 08, 2009 | Dell POWER SUPPLY Power Supply
Need to chat with an agent!
1. make sure not only those are properly seated on the led portion of the the case and on the motherboard..
2. also check your power supply motherboard connector is properly seated on the mother board
3. and make sure your power supply switch is on the right postion (110v/115v North america or 220v/230v Europe)
4. make sure the wall outlet plug is working properly. and properly connected to the back of the powersupply
Dec 04, 2008 | E-Machines eMachines Desktop PC
Sony VAIO VGC-RB50 No Power
Most likely you have a problem with your power supply. First off make sure your Input voltage selector switch is properly set. This switch should be located next to the power cord. In most cases it is red in color, and will have "115V" and "230V" printed on the switch. I have seen red switches and black switches, but mostly red. I you live in the US, you should see "115V", Europe is "230V". Before flipping the switch, unplug power cord.
Since the light is blinking, you are getting power to the power supply. The power supply might be bad, and you need a new one.
Nov 07, 2007 | Sony VAIO VGC-RB50 PC Desktop
181 people viewed this question
Top Samson Audio Players & Recorders Experts
Michial Gueffroy
 Grubhead
Grubhead
Jerry Umali
Are you a Samson Audio Player and Recorder Expert? Answer questions, earn points and help others
