Back to:
Tags:
InFocus Replacement Lamp Projector Lamp For X1 Projector&Screenplay 4800 [ SP-LAMP-009
Lamp resistance and voltage
posted by mreynolds851 on Jul 22, 2008
The Infocus X1 projector gives an indication that the "lamp is not firing after 5 attempts". Before I spend the money on a new lamp, can I check the Ohms of the lamp (I get infinite ohms) or can I check the voltage to the lamp (approx. 129VAC at the connector) to confirm that it is the lamp? It is alot of money to buy the lamp if the unit is at fault. In other words, is there a way I can confirm it is a lamp fault, or, could it just be the projector itself?
Thanks, Mike
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Can you Help with these Multimedia Projector Replacement Lamps problems?
The set will come on as soon as it is plugged into wall...
I cant even plug my dvd or vcr to the tv because all i get...
please help me reinstail my all in one lexmark x2300
Hello I have a C20X and after about three minutes the...
Loading problems.
Repair Service
Find Multimedia Pro. Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
