Question about Acer Computers & Internet
Laptop turned itself off when try to boot up again fan comes on no lights on key board but alarm sound repeating itself
  • 558 Answers
The battery is not charged
Posted on Jul 22, 2008
How do I reset the alarm on a 2005 hyundai Santa 2.4l
Not sure about yours, but many will reset by: turn key to "on" and wait 15 minutes or so; shut off, then try to start.
Apr 15, 2016 | Hyundai Cars & Trucks
THE Element lights up in dash every now and then .when it does the door locks make sound of locking and unlocking , also the dome light comes on. I can reset it by opening the door and closing it. Could...
sounds like you bumping your door unlock button on your key ring you have a square black alarm door opener on your keys thats what it sounds like is happening if you do try it with you inside car see if situation repeats itself if not then some one has one to your car that may be playing tricks or you have a faulty door alarm key it has something to do with your anti theft system
Dec 12, 2010 | 2000 Ford Taurus
Problem with Fan - Dell Laptop Inspiron B130 ?
If the fan is dead, then the laptop will shut itself off after a short while to prevent heat damage. It is normal for the fan to spin up when you turn on the laptop and then stop turning. The fan will kick in again when it is needed as heat builds up. The system fan has absolutely nothing to do with the lcd lighting up.......seriously.
If the laptop is running, but the screen goes dark after a few seconds, it sounds more like the backlight on the lcd panel is shot. From what you describe, I assume that your lcd is not 'lit up' at all, but you can see a faint image on the screen. If this is the case, then either the inverter board is shot, or the backlight for the lcd panel is dead. You can try calling Dell at 1-800-www-dell and try to purchase an inverter board. They are cheap, and it would be worth the gamble to buy one, because if the backlight is shot, then you need a new lcd panel - $350+ (the backlight is part of it and not replaceable). The inverter board is located at the bottom of the display module, right behind the dell logo at the bottom of the display. It's quite easy to get at.
Here's a good test. Shut the laptop off, and attach a computer monitor to the 15 pin vga connector at the left side of the laptop. Turn on the laptop and the monitor should show you an image. If not, try holding the blue 'fn' key and press and release the f8 key. This should switch you over to the external monitor. If the laptop works fine when connected to an external monitor but has no image, then it's definitely not the fan, and you should try an inverter board. If still no good with a new inverter board, you can still use the laptop with an external monitor.
Hope this helps!.......let me know how you make out.
Dec 12, 2009 | Dell Inspiron B130 Notebook
Acer 6920 Won't boot... Neither post... But lights and fan start.
sounds like the integrated video on the mother board went out there is a company in florida that will fix it for about 150 dollars but you have to send them your computer the list on ebay for mother board repair
Oct 06, 2009 | Acer Aspire 6920 Notebook PC
My laptop(Toshiba Satellite A105 - S2051) wont turn on with or without battery on a/c adapter. Adapter seems to have a charge but when i plug it in and try hitting the power button nothing happens. I do...
hi, this is tricky, as the machine does seem to freeze even before booting. the fan may have become stuck, use some compressed air with the fan inlet (bicycle pump may do) to clean out some dust.
wait some time and switch on again.
observe if the green lamps for harddrive and cd-drive light up.
if no, the computer does not boot up, it may be then that :
the fan is broke and laptop prevents overheat damage by not booting up(buy a new fan and replace it)
or the machine itself is broke
in either way, if the solution i provided did not help, i would recommend to see a technician!
good luck then
Aug 08, 2009 | Toshiba Satellite A105 Notebook
Simpson oven 736 evolution turns itself on briefly then turns off
sounds like you have a control board problem
Jun 12, 2009 | Ovens
Computer does not boot up completely -shuts down by itself
for xp there was a update called service pack 3 witch caused alot of compaq to just boot the shut off this seems to be ur problem although i am not sure of ur pc's brand hope this helps
Here to Help
Shaun
Nov 24, 2008 | Computers & Internet
Boot everytime
POBLEM WITH THE MOTHERBOARD...SORRY...
IF IT IS WITHIN WARRANTY TRY GET IT DONE THRU VENDOR IT WILL SAVE MONEY
May 22, 2008 | HP Compaq nx6125 Notebook
Computers & Internet Logo
27 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
