Question about Sharp R-1480 Microwave Oven
Start button The Microwave light will not turn off, the start button is not working. The others are working but when you press start nothing happens.
  • Sharp Master
  • 9,086 Answers
We have the service manual for this model and have uploaded it to our site here to help you. You will need the free Adobe Reader to view or print it.
On these models, the problem is usually a broken tab on the upper door switch mount.
This is usually caused by either a bad door switch, a loose door switch mount, or occasionally a problem on the control panel.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. Other times, it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
You can probably find exploded views and order parts by entering your model number here at the Sears parts site. The best place to order Sharp parts is Tritronics.
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Posted on Jul 23, 2008
The start pause button does not work.microwave keeps running. Press clear/off
The key pad module is faulty.
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Apr 21, 2016 | GE Microwave Ovens
My start button isn't working....I can press the "popcorn" button and it will automatically turn itself on and cook whatever I have placed in the microwave, but nothing happens when I press the "start"...
If it will start automatically without using the 'start' button, the 'start' button must be bad. If the door sensing switch was bad, it wouldn't start at all. It needs a new keypad. The most common cause of a keypad failure is from spraying a cleaner on it instead of using a just barely damp cloth to clean it. The liquid can run down the front of the laminated keypad and get into the bottom and seep up into the lamination....
Nov 03, 2013 | Jenn-Air JMV9169BAS Convection Microwave...
The problem is that when I press the 'Start' button, nothing happens. The clock is working, the fan is working, but I cannot cook anything even after I have entered the time and the power level
If when you press the start button the turntable starts but no heat then magnetron is faulty otherwise if nothing happens then the touchpad itself is faulty.
Oct 10, 2013 | Samsung 1.8 Cu. Ft. Over-the-Range...
Microwave refuses to work when START button is pressed. Oven light stays on when door is closed. Control panel seems to be working ok but nothing happens after cooking settings are set and START button...
That's probably a failed door switch or door switch mount.
It's a pretty simple do it yourself fix. See this helpful file on door switches.
You can find handy exploded views and order parts by model number here.
But if your cooktop lights failed recently, you have a damaged control circuit board, which we can usually repair for $39.95. Details are here.
Jan 11, 2011 | Whirlpool MH1150XM Convection/Microwave...
Hi. I have a Maytag mmv5207bcs Microwave. Pressed...
mmv5207ba/bc microwave 0 button fan on button does not work all other key pad buttons seem to work
May 21, 2010 | Microwave Ovens
Microwave will not heat food. punch in heating time, press start and nothing happens
HI. your control board has failed. you will need to replace the control board asap if possible.
May 30, 2009 | Panasonic Microwave Ovens
Viking microwave has digital lights but will not turn on to cook?
Hi the problem will be with the touch panel membrane or the controller. if yoiu can hear a click when the start button is pressed then the touch panel is OK asnd you should look at the controller which can be replaced as a unit or if you are up to it it's probably the main cook relay that has failed.
Jan 29, 2009 | Viking DMOC205SS Microwave Oven
The touchpad on my microwave has quit working.
possibly a stuck button which would mean a replacement pad, do the buttons bleep when you push them do some work and others dont its quite common normally its the start button or the cancel which goes(due to constant pushing) and it causes the error alternatively its a possible logic board fault which is far more expensive to replace!
Nov 12, 2008 | Microwave Ovens
Nothing happens when you press "Start"
PLEASE CHECK IF DOOR IS CLOSED PROPERLY THOSE HOOKS ON THE DOOR ACTIVATE SWITCHES ON THE INSIDE OF MWAVE OPEN COVER AND CHECK IF HOOKS ARE MAKING CONTACT WITH SWITCHES .COULD ALSO BE TOUCHPAD FAULT YOU WILNEED A TECH
May 09, 2007 | GE JE1540 Microwave Oven
Sharp R-1480 Microwave Oven Logo
70 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
