posted by djc123 on Jul 22, 2008
The water dispenser works but is so slow no one uses it. I have replaced the filer multiple times but no change.
Solution #1
posted on Jul 27, 2008
need make and model to be sure , but if you are using a self tapping saddle valve to tap into the water supply then it will be slow. correct style is to have a drilled out valve. this is a little tricky, you may need a plumber.
jim
jim
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on Jul 25, 2008
there s a motor present for the working of the water dispenser whose rpm would be slow due to which the water dispenser is slow so change tat motor or repair it and then use it after tat it will work properly
Suggest a new solution for this problem
Post a New problem for KitchenAid Superba Architect
Email this problem
Email this problem
Can you Help with these Refrigerators problems?
KitchenAid Superba Architect KSCS25INSS Side...
overactive ice maker
the wire that triggers the ice... Answer This...
WATER FILTER LEAKS
WATER FILTER LEAKS
water leaks from the water... Answer This...
Ice dispenser and water filter
Ice dispenser stopped working... Answer This...
water filter location
where is the water filter... Answer This...
ice maker kitchenaid
ice maker stopped working.... Answer This...
Repair Service
Find Refrigerator Repairman Near You:
Find Parts
