Question about HP Officejet Pro L7780 All-In-One InkJet Printer
Ink cartridge door
The little clip that holds the ink cartridge in place is broken.
How can I replace it. Can you mail me one or where do I order one?
    Novelist:
  • 106 Answers
If part of the ink carriage is damage, i suggest that you need to call HP at 1-800-474-6836. Remember, if you let someone fix it and it wont work, it voids the warranty. Try calling HP, and if they found out that it really needs to be replace, then, they can go ahead and have it replace.
Thank you so much.
adonscott
Posted on Jul 24, 2008
How to change the ink cartridge in a Canon iP1900 printer please
1•Protect your desk, printer stand or work surface by placing an old newspaper in front of or next to the printer. The newspaper will provide you with a place to work without getting ink anywhere you don't want it. It seems as though no matter how careful or neat you are, a little bit of ink always manages to escape when replacing an ink cartridge.
•2
Prepare the new ink cartridge for installation. Remove the replacement cartridge for your Canon printer from all of its packaging. You may need scissors to remove the heavy wrapper. Leave the protective orange cap or tape in place for now. Set the new cartridge aside on the newspaper.
•3
Remove the old ink cartridge from the Canon printer. With the printer on, open the front door or panel of the printer. Wait a second or two and the ink cartridge holder should move to the opening where it is accessible. If it does not move, shut the door, turn the printer off for a moment, turn it back on and try again. Lift the small lever that secures the ink cartridges within their holder. On most Canon printers, it is colored green and located on the right side of the ink cartridge holder. Gently lift the old ink cartridge out of the printer.
•4
Place the new ink cartridge in the printer. Remove the plastic cap or tape protecting the ink cartridge, being careful not to touch the black and gold "sensor" area of the cartridge. Gently but firmly push the new cartridge into the empty slot left where you removed the old ink cartridge. The label should be facing outward. You should feel the cartridge pop into place. Then push the lever back down that you lifted in Step 3. Close the printer door. Use paper towel or wet wipes to clean any ink from your hands.
Aug 18, 2010 | Canon Office Equipment & Supplies
How do I change the ink cartridges in my Canon MP480? rn_bluediamond@yahoo.com
Step 1
Step 2
Step 3
Step 4
Aug 11, 2010 | Canon Pixma MP480 All-In-One InkJet...
How do you remove printer heads on cx3200
The two clips that swing down and hold the ink cartridges can be easily removed without breaking anything or removing screws. Look at the hinge points and use a screwdriver to gently pry one hinge of each clip out and the clips will simply lift out. But after that there are 2 small screws that hold the print heads in that ink cartridge carriage. Remove them and keep track of them. The white clip positioned in the color ink cartridge bay helps to hold the ribbon cable in place, but once you see what will move in regard to the print head, you can loosen the white clip and the print head should lift up. In this way, conceivably, the CX3200 print head should detach from the ribbon cables (there are 2) and a new one goes in its place. I'm dealing with a friend's CX3200 that the black is not printing and I'm cleaning it out and finding a lot of dried sticky ink. Probably used until dry or refilled the cartridge with the wrong type of black ink.
Apr 10, 2010 | Epson Stylus CX3200 All-In-One InkJet...
How do you take out the ink box out of a Epson Stylus NX400 printer?
Usually there is a clip that releases the ink cartridges. You have to lift up the scanner unit and the ink cartridge will move to a position where you can remove it. There you will see the clip that holds the cartridges in place. Pull it back and lift up. You will now be able to remove whichever cartridge you want.
If you are replacing the ink, insert it and press gently until it clicks and then push the clip back into place.
Close the scanner unit and you are finished.
Thank you
Lolita
Jan 18, 2010 | Epson Stylus NX400 InkJet Printer
How do i remove old printhead and install new one
Replacing the printhead If your printhead is damaged or broken, you may replace it yourself.
  1. Make sure your printer is turned on.
  2. Open the printer access door by lifting from the recessed hand-holds on the sides of the unit. autourg00977009id2130369.jpg
    The printhead moves to an accessible position for handling the ink cartridges. The ink cartridges are seated in the printhead.
  3. Pinch the latch on the ink cartridge with your thumb and forefinger and lift it out of the print head. Remove both ink cartridges.
    caution.gif CAUTION:
    Insert the ink cartridges into the newly installed printhead as soon as possible to prevent any drying of the ink.
  4. Unlatch the printhead by lifting the rectangular latch on the top of the printhead.
  5. Remove the old printhead from the carriage .
  6. Remove the new printhead from its bag.
    Do not touch copper contacts on the printhead, as this may damage it.
  7. Remove and discard the black plastic casing and the orange protective cap.
  8. Place the new printhead into the carriage.
  9. Push firmly against the target label on the printhead until you hear it click into place.
  10. Re install the ink cartridges. As needed, see Replacing ink cartridges.
  11. Close the printer access door. The printer should now complete a printhead calibration to ensure that it is ready to for normal operation.
Nov 23, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
I HAVE A HP PRINTER "PHOTOSMART C5580" HOW DO I GET TO CHANGE THE DEFAULT INK. I VERY SELDOM PRINT IN COLOR, AND WOULD LIKE TO BE ABLE TO ALWAYS PRINT IN BLACK ONLY, EXCEPT WHEN I NEED TO GET COLOR AND TO...
To replace the ink cartridges
1. Make sure the HP All-in-One is turned on.
2. Open the ink cartridge door by lifting from the front center of the device, until the door locks into place.
3. Squeeze the tab below an ink cartridge to release the latch inside the HP All-in-One, and then lift the latch.
If you are replacing the black ink cartridge, lift the latch on the far left.
If you are replacing one of the five color ink cartridges, such as yellow, light cyan (blue), cyan, light magenta (pink), or magenta, lift the appropriate latch in the center area.
4. Pull the ink cartridge toward you out of its slot to remove it.
5. Remove the new ink cartridge from its packaging, and then, holding it by the handle, slide the ink cartridge into the empty slot.
Make sure that you insert the ink cartridge into the slot that has the same shaped icon and color as the one you are installing.
6. Press down on the gray latch until it clicks into place.
7. Repeat steps 2 through 5 for each ink cartridge you are replacing.
8. Close the ink cartridge door.
re Printing in black only - you can do this by selection this option from your application and choosing the print properties of the printer and setting to Black / Greyscale printing only.
Sep 20, 2009 | HP Office Equipment & Supplies
Won't print after replacing cartridges
The following text copied from HP website to tackle this problem. minimtop.gif Follow the instructions below to install the print cartridges. NOTE: If you are installing ink cartridges in the unit for the first time, be sure to use only the print cartridges that came with the unit. The ink in these cartridges is specially formulated to mix with the ink in the print head assembly at first-time setup. s.gif Installing the print cartridges minimtop.gif
  1. Verify that the unit is on.
  2. Open the ink cartridge door. Figure 1: Opening the ink cartridge door c00718797.gif
  3. Squeeze the gray tab below an ink cartridge slot to release the gray latch and then lift the latch. Figure 2: Lifting the latch c00721793.gif 1 - Ink cartridge latch for the black ink cartridge 2 - Ink cartridge latches for the color ink cartridges NOTE: The ink cartridge areas are color-coded for easy reference. From left to right, the ink cartridges are black, yellow, light cyan, cyan, light magenta, and magenta.
  4. Remove the new ink cartridge from its packaging.
  5. Hold the ink cartridge by the handle and then slide the ink cartridge into the empty slot. NOTE: Make sure that the ink cartridge is inserted into the slot that has the same shaped icon and color as the ink cartridge. The copper-colored contacts should be facing the printer as the ink cartridge is inserted. Figure 3: Inserting an ink cartridge c00721795.gif
  6. Press down on the gray latch until it clicks into place. Figure 4: Closing the gray latch c00721796.gif
  7. Repeat steps 3 through 6 for each ink cartridge that needs to be replaced. NOTE: All six cartridges must be installed. The printer will not work if an ink cartridge is missing.
  8. Close the ink cartridge door. Figure 5: Closing the ink cartridge door c00718798.gif
s.gif s.gifHave a Good Day
Jul 17, 2009 | HP Photosmart C4580 All-in-One InkJet...
Broken clip for black ink cartridge
Unfortunately, this is not an easy fix. To replace the ink cartridge holder, you would have to dissasemble the whole Print head/Carriage assembly. The when you put it back together , there are timing factors to be set. With printers so inexpensive, I would opt for a new unit.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Oct 31, 2008 | HP DeskJet 5550 InkJet Printer
How to load the new ink cartridge. HP Photosmart C5140.
Replace the ink cartridges (from the manual for the printer)
Follow these instructions when you need to replace ink cartridges.
3. Squeeze the tab below an ink cartridge to release the latch inside the HP All-in-One, and then lift the latch. If you are replacing the black ink cartridge, lift the latch on the far left.
5. Remove the new ink cartridge from its packaging, and then, holding it by the handle, slide the ink cartridge into the empty slot. Make sure that you insert the ink cartridge into the slot that has the same shaped icon and color as the one you are installing.
Jul 04, 2008 | HP Office Equipment & Supplies
Im tying to replace my ink cartridge
Open the scanner bed/door. The Inks will center automaticly. Then squeeze the clip at the end of the ink cartridge to remove the ink cartridge thats empty. replace ink and click it back into place.
Do a deep clean and calibration of the printhead.
Jun 25, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
HP Officejet Pro L7780 All-In-One InkJet Printer Logo
37 people viewed this question
Seeker5211
Seeker5211
