SOURCE: 1999 alero the front end makes noise like the wheel bearing or
if its clicking when you turn the wheal, then its a cv joint. If its making a bump bump bump noise as you go down the road and increases with speed and slows with speed then its probably a bering, It sounds like you have hit something and caused your ball joints to damage. take a board 2x4 about 2 foot long. jack up the car in the front, just enough to fit the board under the tires. At each tire lift the board and see if you have any movement in the wheal. The movement you are looking for will be up and down, not side to side. Your steering moves side to side. Your ball joints give you limited up and down rotation movement to allow your car to handle bumps. If its in access of an inch rotation then there is your problem. Depending on the car, I would probably look at salvage yards first then go to the part store and compare prices. Because some junk yards are chaging near new prices for used stuff. Also your struts may be shot also.
tepfy
SOURCE: Clunking and knocking noise from rear when hitting bumps.
-it could be the sawy bar linkages
-but also check to see if the struts are leaking or that it looks damp
-but because you said it doesn't look like it bouncing when you hit a dip most likely it could be that the struts are dead
-check to see the cars ride hieght that would give you a clue
SOURCE: rear suspension left side makes a knocking sound while driving
There are a few suspension parts that can cause knocking noises. Such as swar bar loose, strut mounts going bad. You should really have a shop do a complete suspension check.
SOURCE: Suspension has a knocking noise what could this be
the 1st thing to have checked is the front struts.
SOURCE: my 96 grand am is making a grinding noise under
Brakes hanging up or axle is going out. CV boot is probably torn and you are hearing bearings crashing around. Check before it goes out or you may end up crashing and stranded
