Question about Philips GoGear HDD6330 MP3 Player
Removed all music
I've had my philips go gear for over 2 years and when I first got it it just wouldn't hold a charge for over 2 hours. I thought no big deal. well then around 6 months after I bought it the battery died and when I turned it back on and went to my music it said list empty. I plugged it into the computer and on the computer it showed everything still on there so i had to erase it and put it back on. then 4 months later it happened again and now all the songs are on there twice and out of order. it's a TOTAL mess! please help me.
  • bbt_salle Aug 05, 2008
    My GoGear is freezen and all songs got missing.I need solution, i have not done any thing yet.
  • 8,596 Answers
You cannot recover the songs, but you can try the firmware upgrade from Philips website
Posted on Aug 07, 2008
Philips DCB146 NO SOUND!!
The answer is straightforward. The main power amp has gone. If you are lucky it's a single IC unit which you will find on a big heat sink. It might look like the one shown below.
You will of course need to de-solder it and resolder a new one. The type needed to replace it will be shown by the letters and number on the IC itself.
May 02, 2017 | Audio Players & Recorders
My mp3 player has been used since april of 2010 and after awile it was accidently stepped on the screen had cracked all you could see was a white blur with colors and the crack shown but it was cracked...
Dear Consumer,
We regret and apologies for the inconvenience caused to you.
We request you to kindly share your contact details with us or contact us on below mentioned contact details.
Thanks & Regards,
Philips Consumer Care, India
1800-102-2929 1860-180-1111
May 16, 2011 | Philips GOGEAR SA6045 MP3 Player
I listen to the music for 1 hour. I turn the lock switch off. The next day the Go gear MP3 has completely discharged. I re charge it on the pc. The screen reads 'Fully charged'. The same thing...
There are two things possible.
1) You have defective re chargeable batteries in your GoGear.
2) There is some short circuit because of which the re chargeable cells are discharging.
Either way you should get the system changed. If you want to confirm if its the battery defect or GoGear. Charge the system fully and play music continuously. If the Go Gear plays for about 4 hours with out break---- its not the battery but the charging system.
Mar 14, 2011 | Philips GoGear SA3020/37 MP3 Player
How do I operate my Philips go-gear 8GB mp4 player. Serial # RK1H1051038306, model # 06095819004. I can't make out the users manual. What I am tying to do is, transfer my class lectures, recorded in mp3...
I have a Philips go-gear 4GB player. There is no charger included. To charge the player, use any firewire/USB cable and connect the device to a PC or laptop. While the device is charging, the battery icon is blinking. When it is fully charged, the battery icon will stay static.
To copy to the device, open Windows explorer. Look for the Philips Go-gear folder icon. Open the Philips folder and Copy you music files inside the device's my music folder. If the file is video, copy the file in the my video folder.
Once the device is fully charged, disconnect the device by right-clicking on the Safely Remove Hardware icon on lower right portion of your PC screen. Select Safely remove hardware then Choose the philips go-gear device to eject.
Power on the device then use the navigation keys to select the files you like to play. Click ok or the play button.
Jan 21, 2011 | Computers & Internet
My Razr v3 won't turn on and it's only 2 months old. the battery was fully charged in another phone. I've tried holding the on button down, plugging in the charger and replacing the battery but the phone...
Well you seem to have done the hard bit.Either charger or battery you`ve tested.
Just had one thought,How long was the battery out of the phone?
So put the phone in a warm room for 2-3 hrs.As condensation can form in the phone. Firstly remove the battery and check there`s no moisture anywhere.
The last solution I can think of is to try a battery in the phone ,plug the charger in and try charging for 3 hours. It can take time for the graphics to appear.
Well after it not being the battery,charger it will be the phone. So take it back to your retailer and ask for a replacement.
Hope i`ve helped!
Dec 20, 2009 | Motorola Mobility RAZR V3
How Long Do I Charge Before I Can Put Songs On?
You can do it while plugged in to usb charger. Otherwise you can do it 2 hours after. It should be charged for about 6 hours
Oct 29, 2009 | Philips GOGEAR SA6045 MP3 Player
I am trying to charge the battery. The charger is flashing a red light and the battery won't seem to charge. Placed it in the camera just in case, and it won't turn on.
Well, with my Nikon, the light flashes to show the battery is charging. It stays on when it's charged. My battery and spare battery are 2 years old and working fine. I'd say wait till it stops flashing...hour or 2 in my case, though I never let them run down all the way.
Jun 28, 2009 | Cameras
My Phillips Go Gear player wont work
Make sure the hold/lock switch wasn't accidentally activated.
If it is freezing, update the firmware.
Download the newest version of the Philips Device Manager:
www.usasupport.philips.com - change your country/language as needed
Enter in your exact model #
Click on the link for your exact model #
Click on the Software & Drivers section
Click on "Firmware Upgrade Software"
Install the new Device Manager
Open and run the "Update" tab
-Tha Mp3 Doctor
Mar 27, 2009 | Philips Audio Players & Recorders
Solution
Running the Go Gear on low power will give you strange symptoms like that. Reload the songs and see how it performs.
Unfortunately, if it is broke, Philips no longer has any of these to send you.
Aug 05, 2008 | Philips GoGear HDD6330 MP3 Player
Philips GoGear HDD6330 MP3 Player Logo
50 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
