Question about Hoover U5753-900 WindTunnel Bagless Upright Vacuum
Brushes won't spin on carpet
The brushes won't spin when placed on the carpet. They spin just fine when I lift the vacuum up just a little bit (so they're not really touching or cleaning the carpet), but not when they meet the resistance of the carpet. I have checked for clogs. I seem to have at least some suction both through the floor unit and through the tools hose. It does not matter whether I have my height adjuster on hardwood floors or carpet, they just won't spin when they hit carpet. I am not getting the "sweeper marks" on the carpet and only moderate cleaning. The unit (U5753-960) is about 8 months old.
  • trchase Jul 22, 2008
    Thanks - I didn't know that the belt would stretch but not break. That's why you're the expert!
  • 558 Answers
Belt is stretched replace the belt and all will be well
Posted on Jul 22, 2008
My Shark rotator is very hard to push at times, easy at other times. What makes it hard to push and how do I fix it?
Does it have a "brushes" lowering/higher switch?
Normally due to brushes being too low in particular on deep pile carpets??
check the actual fixings for the rotating brushes are ok and the brush not simply need "clicking" back into place?
Feb 12, 2015 | Shark Rotator Professional Lift-Away...
Why is my Shark nv500 vaccum carpet brush is not spinning?
I am having the same issue. The brush won't even move when I turn it with my hand. I just posted this same question.
Aug 01, 2014 | Shark Rotator Professional Lift-Away...
Carpet washer brushes stopped spinning
Unplug it, turn it over and there should be some thing stuck in the roller brush.
Mar 14, 2014 | VAX Appliances Vacuums
THis is not a self-propelled vacuum. The problem is that the brushes are no longer rotating on their own. They only 'brush and lift carpet' when I pull backward. I have ahd the vacuum for about 1 year. ...
Sounds like you need to take the brushes off the unit and clean the end pieces that the brushes rotate around. Not uncommon that they get dirty and stop rotating. Clean all debris and add a little WD40 on the end of the bush rods that the brush spins around. Make sure the belt is on properly.
Sep 04, 2010 | Vacuums
Brushes won't rotate on hoover steam vac. I have removed them and cleaned.
The brushes turn by the airflow from the vacuum suction turning a turbine motor to spin the brushes. First try to spin the brushes by hand. If they won't turn it usually means the brushes are clogged with hair and debris or need replaced or the turbine could be seized up. If the brushes won't spin reach under the brushes and push the little tabs and remove the brush block asssembly from the machine. If the brushes spin freely after you remove them from the machine then that means that most likely the turbine is seized and will need to be repaced. If the turbine is not seized you may simply just have a clogged filter screen. Most steam vacs have a red screen filter either on top or underneath the machine. On the top it is under a little clear plastic cover that you have to pry off before you can pull the screen out to clean it. If it's underneath you can pull it out and clean it.
Jul 18, 2010 | Hoover SteamVac Carpet/Upholstery Deep...
The brushes spin fast until I put it down on the carpet
raise the bottom to level of the carpet , just so it hits, must be a lever in the back, its meant to sweep up debree to **** up, there is nothing yet to bring pile up
Sep 28, 2009 | Hoover SteamVac F5914-900 SpinScrub...
I have a Bissell Pro Heat 2X carpet cleaner and the brushes spin, then stop. I turn it off and when I re-start, the brushes do not spin until I push foreward. The it spins and stops again. Both belts are...
The reason for the brushes to stop when it is above any surface is there is a switch in the handle that stops the brushes so it dont burn your motor up it may have a faulty switch.
Jul 14, 2009 | Bissell Carpet Cleaner Powerbrush Deep...
Beaters stop when vaccuming rug...didn't when new
I believe you need to change the belt that drives the brushes. When it gets stretched out, it will just spin on the axle of the motor or spin on the brush and smoke.
Jim
Jun 01, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Brushes won't spin on hoover steam vac ls
I have the SteamVac Dual and there's a screen on the underside of the unit. It's beneath the brushes and it's red. You have to pull and wiggle it to get it out. With the machine unplugged, lay the unit with the handle on the floor. In the owner's manual ( http://www.hoover.com/pdfs/manuals/F7222900.pdf ) this is shown on page 10 figure 3-2. Clean that screen.
If they still won't spin, then take the brushes out. Again, with the unit on the floor, you simply grab the unit firmly and pull towards you. It's much easier to remove than the screen. I took the brush unit outside and blasted it with the house. You'll have to pull out whatever fur balls are clogging it but eventually you'll see that the brushes spin freely with the water squirting on them. Plug the brush unit back in and - in my case - they started spinning.
Jun 26, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Hoover U5753-900 WindTunnel Bagless Upright Vacuum Logo
296 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
