Question about Maytag MSD2436GR Side by Side Refrigerator
Maytag Model MZD2766GEW iced coils
The refrigerator side stops cooling and evaporator coils in freezer are all frosted thick.
  • 2 more comments
  • roken Jul 23, 2008
    I have been reading posts that the Adaptive Defrost Control (ADC) board ($60) is the cause but I want to make sure before I buy one.
    OK - for continuity check, if the heater or sensor is good, the ohm meter will have a reading of some value instead of infinity right?
  • Dave B Sep 03, 2008
    Greetings: First off, great site. Secondly, Ive replaced the ADC, the heater element and temperature this that came with heater, litle quarter sized item with clips that snapped on copper piping from evap. coil. Anyhow, do I have to wait for the refrigerator to reach a certin cold/freeze temperature with icing on the coils to see if heat kicks on? Once I installed it all, I tried to start the refrig. into defrost by sliding freezer arm three times to right then leaving in the cold position, fans cycled off but heat didn't come on. Is that because there wasnt enough ice to melt and it wasnt cold enough or is there something else Im not doing. Many thanks...Code Blue 7
  • Anonymous Jan 13, 2009
    MAYTAG Defrost problem. Type MSD2436GR*. Bought adaptive defrost control baord, Part Number: 61005988. Does not look anything like old unit which has a small electrical coild visible. Not pin compatible either. Cannot find any info on the web. Anyone have experience with these different types of control?
  • 143 Answers
This sounds like a defrosting problem. There is a defrost timer, a heater element, and a therm-o- disk thing that shuts the heater off when the frost is melted. These are the things to check, but it's usually the heater that is burnt out.
Posted on Jul 23, 2008
  • B Carson Jul 23, 2008
    I'll be darned. They keep putting circuit boards like, everywhere! I guess a circuit board is cheaper to make than a mechanical defrost timer. The problem now, is that the brain is more likely to be fried than the heater, and harder to verify.
    With a mechanical timer, you look in the little window to see if the motor is still turning, then turn the knob until it gets to "defrost" and see if the heater starts. How is an average person going to check a "brain board?
    Here's an idea: Check the heater and the defrost terminator for continuity. If they are good, the only part left is the Adaptive Defrost Control Board.
    If it still uses a Klix-on brand temperature sensor, you have to check it while it is still below 50 degrees F. If there is no mechanical temperature sensor, the circuit board is responsible for deciding when to stop the defrost heater, and that will bring you back to a bad circuit board.
    If the heater is good, it will have a reading of maybe...a hundred ohms, probably less. Definitely not in the range of a thousand or ten thousand ohms. That would let about an amp or two into the heater. The temperature sensor will read zero to 3 or 4 ohms, but only if it is still frozen. It's whole purpose in life is to know when the frost is melted, then change to infinite ohms, and once it has clicked off, it has to get really cold to reset to "closed".
    If those two parts are good, you probably have a bad circuit board, but be sure to check and see if there are any more parts in the defrost circuit.
I have a Hotpoint HSS25GFPEWW side by side.....initially the ice maker stopped crushing and dispensing ice....then the freezer started to warm. I cleaned the condenser coils and confirmed the condenser...
dead if the compressor is running and theres no cooling or frost on the evaporator you have leaked out all your freon only way to fix is call a pro about 600$ to fix
Aug 15, 2012 | Hotpoint HSS25GFP Side by Side...
First the refrigerator portion lost cooling but the freezer was fine over time the freezer esentially turned into a refrigerator. It is no longer making ice or keeping things frozen, but is about as cool...
the evaporator coil is frozen over and cant release cold air due to this,defrost the unit remove rear panel inside freezer and troubleshoot the defrost heater and thermostat and also make sure the fan near this coil is running, on the evaporator coil as,you cant blow cold air thru a coil covered by ice
Jul 02, 2011 | Jenn-Air JSD2789GES Side by Side...
I have a maytag MSD2456DEB...the freezer keeps icing over and stop cooling about every five days..any ideas
if it's ice check the drain if it's frost you have a defrost problem which is three things to check, defrost control, defrost t-stat and defrost heater
Nov 17, 2010 | Maytag MSD2456G Side by Side Refrigerator
Maytag plus model mzd2766gew freezer working refrigerator
Hi!!
Check
Temp. control knobs,
Small fan in freezer, it should start working after opening the freezer door for a couple of minutes. If it does not start, use a pen or pencil to turn the blades, if it kick in, replace motor.
Remove freezer back panel (where the little fan is) and check for iced evaporator coil, if so, unplug unit and use a heat gun or hair dryer to melt ice, make sure the air duct going to the fridge is clear.
Once this is done, restart unit
Keep me posted!! Rate this post!!!
Aug 12, 2010 | Maytag MSD2456G Side by Side Refrigerator
Maytag MZD2766GEW side by side refrigerator fridge not cooling
you have a defrost problem, could be bad adaptive defrost board,t-stat heater,when you open freezer door listen for fan if fan is blowing check the t-stat,look at it and see if it has a buldge on it,sometime you can see this and tell it's bad,you'll need a meter to read out the heater and other parts to see whats bad,might be a good idea to call a tech to do this,when you find problem you have to melt everything out again
Oct 31, 2009 | Maytag MSD2756G Side by Side Refrigerator
Maytag Fridge (Model # MZD2766GEW) not cooling
Check to see if you have frost on the back panel of your freezer in your fridge. If you do your coil is frozen over and you'll have to defrost your freezer. I just did mine cause mine wasn't cooling properly on my fridge side.
Apr 06, 2009 | Maytag 25.6 cu. ft. Wide-By-Side...
Frige not cooling
Poor cooling is often the result of a heavy frost build-up on the evaporator coils or a condenser that is clogged with dust, lint, and dirt.
Evaporator coils Poor cooling is often the result of a heavy frost build-up on the evaporator coils. You can't see these coils without removing a panel on the inside of your freezer. A sure sign that there is a build-up is the presence of any frost or ice build-up on the inside walls, floor, or ceiling of the freezer. Such a frost build-up usually indicates a problem in the self-defrosting system or damaged door gaskets.
The refrigerator is supposed to self-defrost approximately four times in every 24 hour period. If one of the components in the self-defrosting system fails, the refrigerator continues to try to cool. Eventually, though, so much frost builds up on the evaporator coils that the circulating fan can't draw air over the coils. There may still be a small amount of cooling because the coils are icy, but with no air flow over the coils, cooling in the refrigerator compartment is quite limited.
Here's an inexpensive, though inconvenient, way to determine if the problem is with the self-defrosting system. Remove all of the perishable food from the refrigerator and freezer, turn the thermostat in the refrigerator to Off, and leave the doors open for 24 to 48 hours. (Be sure to have several towels ready in case the melting frost and ice causes the drip pan to overflow). This allows the refrigerator to defrost "manually." When the frost and ice build-up has completely melted away, turn the thermostat back to a normal setting. If the refrigerator then cools properly, it indicates a problem with one of three components in the self-defrosting system:
  • The defrost timer
  • The defrost thermostat (also called the bi-metal switch)
  • The defrost heater
If it still does not cool properly, there may be a problem with the refrigerant level or the compressor. You may need to consult with a qualified appliance repair technician to further diagnose the problem
Condenser Self-defrosting refrigerators all have a set of coils and a cooling fan, usually under the refrigerator, that need to be cleaned regularly. If these coils get coated with dust, dirt or lint, the refrigerator may not cool properly. The coils may appear to be a thin, black, wide radiator-like device behind the lower kick-panel. To clean them, disconnect the refrigerator from the power source, use a refrigerator condenser brush (see the Appliance Accessories section) and your vacuum cleaner to clean the coils of any lint, pet hair, etc. You may not be able to get to all of the condenser from the front, it may be necessary to clean the remainder of the condenser from the rear of the refrigerator.
Mar 24, 2009 | Maytag MSD2756G Side by Side Refrigerator
Ice build up in bottom of freezer
Check the ice maker. sometimes they get cracked a will leak water into the freezer compartment. Also check the ice maker fill tube for leaks or someone could have spilled something. Although this is tipical of a clogged drain. What happens is when the fridge go into derfost, it will melt all the frost that is on the evaporator, turning it into water. The water drains down to a trough under the evaporator and down a drain hole in the trough ( this trough is behind the evaporator cover ) Removing the melted frost from the freezer. If that drain is clogged, the water cannot leave the freezer. Then when the fridge starts back up ,it will freez the water that was not drained. After repeated defrosting the water will fill this trough and run off into the bottom of the freezer to be frozzen when the fridge starts to cool again.
Nov 16, 2008 | Refrigerators
Maytag refrigerator Model MZD2766GEW
Check the evaporator fan motor located abocve teh cooling coils in the freezer side.
Jun 05, 2007 | Maytag MZD2766GES Side by Side...
Maytag MSD2436GR Side by Side Refrigerator Logo
732 people viewed this question
Top Maytag Refrigerators Experts
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
