Nokia E71x Cell Phone Logo
Posted on Feb 09, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My Nokia E71X will not automatically connect when I re-enter my 2009 F150. I have set it up many times and it works fine until I exit and then re-enter.
Anonymous
Level 3:
  • Master 418 Answers
  • Posted on Feb 09, 2011
Anonymous
Master
Level 3:
Answers
418
Questions
0
Helped
60712
Points
1308
The use have to change your code to be able reenter another one that is new
How do I set day and date? All else is set
SETTING THE TIME
Note:
When the signal is being received (as indicated by the atomic indicator signal)
you will not be able to make any setting or adjustments to the clock.
1. To begin setting the clock, press and hold the MODE button located on the back
of the clock for 3 seconds to enter the TIME setting mode.
2. The HOUR digits on the display will begin to flash. Press the UP or DOWN button
to set the HOUR in one hour increments. Press the UP or DOWN button as
necessary until the correct hour is displayed.
Note:
If you are in the 12 hour time format, be sure you are in the correct AM or PM
time period. When the "PM" indicator appears on the display, the time displayed is in
the 12 hour period between 12:00 noon and midnight.
3. Press the MODE button again to exit the HOUR setting and enter the MINUTE
setting mode.
4. The MINUTE digits on the display will begin to flash. Press the UP or DOWN
button to set the MINUTES in one minute increments. Press the UP or DOWN
button as necessary until the correct minute is displayed.
5. Press the MODE button again to exit the MINUTE setting and enter the
SECONDS setting mode.
6. The SECONDS digits on the display will begin to flash. Press the UP or DOWN
button to reset the SECONDS to zero.
7. Press the MODE button again to exit the time setting mode. The clock will
automatically return to the normal time display mode.
Note:
If no settings are made within 30 seconds, the clock will automatically return
to the normal time display mode. If this happens, you will need to start the time
setting procedure again from step
SETTING THE CALENDAR
1. Press the MODE button (located on the back of the clock) twice (do not hold the
mode button) to display the CALENDAR.
Note:
The YEAR icon will be shown on the display indicating you are in the year
display mode.
2. Press and hold the MODE button for 3 seconds to enter the CALENDAR setting
mode.
3. The YEAR digits on the display will begin to flash. Press the UP or DOWN button
to set the YEAR in one year increments. Press the UP or DOWN button as
necessary until the correct year is displayed.
4. Press the MODE button again to exit the YEAR setting and enter the MONTH setting
mode.
5. The MONTH digits on the display will begin to flash. Press the UP or DOWN button
to set the MONTH in one month increments. Press the UP or DOWN button as
necessary until the correct month is displayed
6. Press the MODE button again to exit the MONTH setting and enter the DATE
setting mode.
7. The DATE digits on the display will begin to flash. Intermittently pressing and
releasing the UP or DOWN button to set the DATE in day one increments. Press
the UP or DOWN button as necessary until the correct date is displayed.
Note:
The day of the week will automatically set according to the month, date, and
year.
8. Press the MODE button again to exit the calendar setting mode. The clock will
Note:
If no settings are made within 30 seconds, the clock will automatically return to
the normal time display mode. If this happens, you will need to start the calendar
setting procedure again from step 1
Nokia E71 phone internet connects but exits out
Hello I thought that the net browser of your phone seems damage/corrupted.This could not be fixed unless you flash/update the phone"s OS.But at you can Restore the phone by selecting "Restore setting only" or type *#7780# when your phone is in standby mode.Moreover if you want to flash the phone by yourself Click here1.Or contact nearest mobile repairing shop.Again here is the link to download your flash file All nokia bb5 flash file.Good luck
5helpful
Hi , i got a Nokia E71x , and i can not change my clock and date also , when i try to open it , i got "system error" , i bought the phone in USA , and i live in europe , what can i do ,pls help...
Do a master reset:
CAUTION: A "master reset" changes the phone settings back to default. This process will erase all contacts, downloaded settings, and downloaded applications (ringtones, wallpapers, graphics, etc). This process cannot be undone. So please backup all data in phone memory to memory card first.
Enter *#7370# from standby screen, and the standard phone code for nokia phone is 12345
My Nokia E71x started to lock up and wont turn on now.
Switch-off your phone. 1. Press and hold 3
keys; Green dial key, *
Star key, no. 3 key on keypad and then press
the power on/off to
swtich on the phone. Remember, do not let go the 3
press and hold
keys until you see a formatting word screen show! 2.
After a few
minutes when the Full phone formatting completed, your phone
will
back to original system and factory settting.
2helpful
2answers
Where can I get unlock code for nlokia e71x?
Hi you can unlock your Nokia E71x using the unlock code. you can get the unlock code in this site http://www.wickedunlock.com/ at reliable cost...
Do not enter any wrong unlock codes on your Nokia E71x mobile phones. If you enter over a certain amount of wrong unlock codes on your Nokia E71x mobile phone, your phone may get hard locked and sometimes become unusable.1 - Switch on your Nokia E71x without any sim card.
2 - Don't bother as to what is displayed on your Nokia E71x.
3 - Compose #pw+CODE+1#.
4 - The Nokia E71x would then display the message "SIM Restriction Off" and will be unlocked!
Note :For Nokia E71x mobile phones locked to the network Fido or Rogers in Canada follow these instructions :
3 - Compose #pw+CODE+7#.
I have unluck nokia e71x at&t version, i can't send txt msg, but i can receive it. what should i do?
Took my e71x to AT&T when I first got phone with same problem. They changed out SIM card, worked fine after that.
I need to know the unlock code for my e71x nokia phone.
in any nokia multimedia mobile install the software names MCODE available in mobile software websites
now enter ur emei no. when asked u will get a 1o digit code it will be ur new security code
NOW ENJOY
pls vote me if u r satisfied with me answer
11helpful
2answers
Can't connect to Nokia PC Suite by USB
Go to settings--> "Data CBL"
Change the "Data Cable Mode" to "PC Suite"
and for the future, change the "Ask on connection" to "yes", and it will ask you every time what you want it to do when connected to the ESB cable.
Top Nokia Cell Phones Experts
Kolbrun...
Muhammad Irshad...
Muhammad Irshad...
