SOURCE: Hp Photosmart 8150 can't read
Unless the SD slot is specifically designated that it can read the new SDHC (Secure Digital High Capacity) memory card it will not read even though it plugs intop the standard SD slot.. I checked and this printer can't read the SDHC card only the standard SD card. You can buy a SDHC USB reader on ebay for a few dollars.
SOURCE: Error reading SDHC flash card in a HP Photosmart 8250 printer.
Purchase a SDHC to USB media converter (e.g. SanDisk
M/N SDDR-113-A10M), which allows you to plug that SDHC
memory card into the printer via the USB port.
SOURCE: memory card error for 4GB SDHC card on HP Photosmart printer 2710
Well SD max is 2gb, so you can get 2gb if you want.
SDHC max is 32gb. If you are not on a budget, try upgrading your printer to a newer model.
SDHC is coming out with even newer models, now with a class 10 (10mb read/write speed - but very costly).
However, if it doesn't matter to you, might as well just stick with the same printer, since SD cards are coming down in price. Just make sure you get 2gb cards with a good class speed.
