Nokia E63 Cell Phone Logo
Posted on Feb 09, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
When speaking on phone the listener can not hear my voice because volume is too low
Jose Ma DM.
Level 3:
  • Master 540 Answers
  • Posted on Feb 09, 2011
Jose Ma DM.
Master
Level 3:
Answers
540
Questions
0
Helped
177109
Points
1776
It seems that there's a failure with the microphone or you have something blocking it physically, i.e. skin covers o cases, if the mic is failing you should take it to an authorized service center for repair.
1 Related Answer
Anonymous
  • Posted on May 24, 2009
SOURCE: People cannot hear my voice very well (volume is too low) when I am speaking.
On the side of the phone there are two arrows, one stands for plus volume, the other stands for Minus volume... Try It!!!
Volume too low
when you are listening any call press the volume button which is on the left side of your phone.... then turn up the volume and listen the voice easily
I can't hear peoples voices when they call. The volume only works for the ringer
If you want to change volume of the caller's voice, then try adjusting the volume control WHILE you are actually talking on the phone during a call.
If you try to adjust the volume when there is no call in progress, then the volume controls will only change the ringer volume.
If you provide the exact model number of your particular device, then we may also be able to provide you with the User's Manual for your phone.
I hope that was helpful Loli.
Good luck and take care.
Joe.
1helpful
I can hear callers but they cannot hear me. Mute is not engaged,
Please see the link below for the User's Guide.
• Headset is muted. Long press (3 sec.) the volume down button on headset to unmute the microphone. See page 16.
• Improper positioning of voice tube. Try various other positions.
• Voice tube may be clogged. Remove voice tube and test to see if callers can hear you without it. If they can, then replace the clogged voice tube. See page 18.
• Speaking volume is too low. Increase the speaking volume by
adjusting the speaking volume minor adjust buttons on the base unit as described on page 16. If the volume is still too low, select another speaking volume major adjust setting as described on page 16.
• Incorrect configuration dial setting for your phone. Try other
phone configuration dial settings on the base unit. Ensure the
selected number is in line with the position indicator. See page 14.
Plantronics CS70 User's Guide
Good luck from Headsets Direct!
16helpful
My new Nokia C1-01 is very low on caller volume. I can hardly hear my callers properly. How do I increase the volume so that I can hear my callers properly.
oh! your problem is voice of volume. my dear user make sure your volume button and increase your volume voice.this type problem is creates when we are listen a song at low volume voice and forget to increase volume.
It is very low voice to other people
Just increase the volume of your phone, because you are probably clearly hear them speak but the tone of your phone is low,that is why they cant hear your clearly as you might expect.
Check on the phone tone/volume.
Dec 11, 2010 • Cell Phones
VOICE volume is low how do I set the volume of the handset so I can hear people speak
Thanks for using FixYa.
Kindly let us know the complete model number.
How do i increase the volume ob the receiver,not the ringer volume ,voice while speaking as i cant hear the other party loud enough
When you are talking on the phone (or listening to a dial tone), the volume control works to control the volume of the receiver. When the phone is not being used, the volume control is used to control the volume of the ringer.
1helpful
2answers
When i call someone they can hear me but i cant hear them what should i do
Hi
first ill suggest if your phone is under warnety then kindly go for support from where you buy, it is much better to utilize your warranty claims on first priority. If your warranty is expire then do the following steps
  1. On the side panel of your phone their is volume key button for increasing or decreasing voice check weather it is not too much low by increasing the volume
  2. you can also check your phone speaker by recording your own voice in , just find this icon in your main menu da6b529.jpg Record your own voice and listen if you are getting your voice clear. or play any ring-tone if your listening any sound from the speaker that mean your speaker is okey.
Note : we often get these problem in mobile communication that we can listen voice of a caller or caller cant able to listen our voice it is because of the disturbance in communication signals, or low signals in high traffic areas.
From all of the above attempts you still not getting any voice from your phone speaker then might be your speaker is not working and you have to replace it , contact authorized samsung hardware support and change your phone speaker .
Thanks
Please Rate !
1helpful
3answers
Top Nokia Cell Phones Experts
Kolbrun...
Muhammad Irshad...
Muhammad Irshad...
