Question about Brother HL-5240 Laser Printer
New HL-5240 printer red status light upon powering up
We have bought several HL-5240 and they worked fine out of the box.
This time we installed a unit that when we power it on, the toner/drum/paper lights and the status light come yellow for about 5 seconds then they turn off, the status light blinks green and then turns red and stays red.
Pressing the GO button has no effect, but if we press the Job Cancel button the status light blinks yellow green twice and stays green but the printer doesn't work (the motor running sound doesn't come on).
If possible, would appreciate some help on this.
Best Regards,
Candido Parrilla
cpcnet@prtc.net
  • 3 more comments
  • jbradley4000 Aug 21, 2008
    Help! I have the same problem but my printer was working fine until a couple days ago and then it just stopped working. Same thing happens when it turns on.
  • mcolvin Aug 21, 2008
    I have the same problem. Earlier today the printer was working well. Now, when I try to print I get a failure to print message. I have done this repeatedly and turned the printer off/on. I get the all lights yellow then the status light flashes green but instantly turns red and stays red. I have asked for a test print. I have tried printing from several sorces. I have turnedmy computer off then back on. I have also gone through the quicker restart.
  • jolson0 Feb 06, 2009
    I have the same problem as everyone else, but no paper jam
    jolson@phcinc.net
  • sylxav Mar 27, 2009
    Exactly same problem since we changed the toner
  • Anonymous Mar 31, 2009
    Thanks
    Saved me hours of additional stress.
My HL-5240 did the same thing, Here is what I found:
Look at the back of the printer. Pull down the back cover. Look to the right and the left of the exposed internals of the printer and there should be another handle/knob you can pull down. Pull these both down simultaneously and check to make sure there isn't a piece of paper in there! This was a shock to me! My office printer was held up for days until I found this hidden door in the back! I felt like an idiot that it was from a stupid paper jam!
Posted on Sep 05, 2008
  • chris lam
    chris lam Oct 18, 2014
    thankyou thankyou thankyou
  • Tim Clark
    Tim Clark Oct 29, 2014
    Brilliant....can't believe I missed this!
Solution 3 solved it for us after 3 days of head scratching and frustration!! God bless the internet. Thank you.
Posted on Feb 18, 2010
    Problem Solver:
  • 5 Answers
Well, ok, that didn't work for me...I think mine has no ink...I took out the ink cartridge and closed the cover, it made a few noises and realised then it was out of toner. I also opened up the toner cartridge and looked inside, no ink, wow but the ink costs so much! I'll get some more ink and repost the results.
Posted on Nov 19, 2009
I too found this tip sovled my problem of a 'non-functioning" printer! I never would have found this answer by myself. Many thanks!
Posted on Oct 15, 2008
Mine turned out to be a piece of paper hidden under the toner cartridge.
Posted on Oct 14, 2008
I just did what you explained and sure enough there was apiece of paper back there I had no idea existed. Thanks!!
Posted on Oct 13, 2008
  • chayia770 Dec 28, 2010
    THANKS SOLUTION 3!
Same here. Staus light red on start up. Pressing the 'Job cancel' button causes the status light to cycle through red amber green stopping on green but printer does not respond to a print command. Tried all combinations of power on/off, computer reboot etc but still won't print. Agggh.
Posted on Aug 29, 2008
Brother 5240 green light status stay flashing
Hi sofian,
please reinstall the printer.. But before that just uninstall the printer completely from the pc.. Then unplug it from all connections.. Then power off the printer for 30 minutes.. It will reset the printer.. Then replug the printer.. and download the latest driver of the printer from the following link..
Brother Solutions Center HL 5240 United States
Just search for your model number..
After finding the driver for your printer.. just reinstall a fresh copy of the printer.. Hope It's resolve all Your Printer Problem,
Or
Still having Problem Then follow Us ForBrother Printer Support
Feb 14, 2014 | Brother HL-5240 Laser Printer
I have a Brother HL-5240, status light red, paper light flashing. Plenty of paper in the tray
Ether the paper sensing lever is broken or there is dust accumulation or paper fragments inside the optical sensor.
Sep 13, 2011 | Brother HL-5240 Laser Printer
The printer is not working the status is red light
red light means in drum side or toner is not inserting properly...may be that issue...or you clean the inside printer ..after that insert a drum and toner ....check it ....try it...
Mar 14, 2011 | Brother HL-5240 Laser Printer
Brother HL 5240 Laser Printer Hi I hope you can
Hello
You need to re-install drivers of the printer. also check the USB cable.
Good Luck
Jan 07, 2011 | Brother HL-5240 Laser Printer
What does the red status light mean.
Unplug the Printer and again Turn it back ON after few minutes. A Solid Red Light Status means that, more than often it is for Paper Jam.
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Nov 04, 2009 | Brother HL-5240 Laser Printer
Brother Laser HL-5240 has a status light and toner light. Fuser was replaced but no help.
that error usually indicates that the toner has reached its end of life
or the drum is not properly installed.
i had one person who put the toner in but threw the drum cartridge away.
Jun 25, 2009 | Brother HL 5040 Laser Printer
Red status light came on red and toner light --orange
I have solved my own problem, I have a second identical printer that just developed the same problem, so this seems like a common problem. The solution was to replace the "toner sensor pcb assy" model # lj9935001. It is located in the left side panel which is easily removed (2 screws), I had it replaced in half an hour and that was the first time. It clips in ,the wire needs threading a little then then connector . if you take your time and think it through it is easy then turn it on and presto nothing but green status light. costs $18.50 with shipping ground. Contact Brother 901-379-1000, get customer service and ask for parts dept. Best of luck.
Aug 26, 2008 | Brother HL-5240 Laser Printer
My Brother HL 5240 has Status toner, drum and paper lights on, I bought it on 4/30/08, new toner, plenty of paper, it showed on computer: printer is off line, but it was connected with computer. Really...
The drum light will flash on my brother HL-5240 Laser Printer when printing but it continues to print just fine. Does this mean the drum needs to be replaced?
Aug 07, 2008 | Office Equipment & Supplies
Brother 5240 laser printer changed toner still wont work.
This works on several different Brother Printers to get rid of toner/drum empty errors:
1. Open the front cover and leave open while completing the following steps.
2. Turn the printer off.
3. Hold the 'go' button while turning the printer on. All panel lights should be on.
4. Release the 'go' button.
5. Press the 'go' button 2 times.
6. Pause.
7. Press the 'go' button 5 times.
8. The toner light should be off.
9. The paper light should be on or flashing [doesn't happen on all].
10. Close cover. The ready light should be the only light on.
Oct 20, 2007 | Brother HL-5240 Laser Printer
Brother HL-5240 Laser Printer Logo
8,436 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
