Question about Diamond Multimedia Stealth S60 RADEON 7000, (32 MB) PCI Graphic Card
No signal after standby/power interrupt
Computer: emachines t1140, Celeron 1.10, 384 MB RAM, WinXP
Video: Diamond S60 64MB DDR Radeon 7000 PCI
Monitor: ViewSonic 19" Wide DVI LCD 2ms 700:1 300 cd/m² 1440 x 900 WXGA+
When the computer wakes up from standby, I get "no signal" on the monitor; the only way to get a monitor signal is to restart the computer, which pretty well defeats the purpose of standby. The same thing happened when I accidentally hit the power switch on the front of the monitor -- when I turned it back on, "no signal," had to restart computer.
When I asked Diamond about this six months or so ago, their tech said it was a "slight compatibility issue" and there were "currently no fixes." Any thoughts?
  • 781 Answers
Check in BIOS to see how wake up is set
Also right click desktop go to properties/settings/advanced check setting for wake up
Posted on Jul 22, 2008
Is W7 compatible with p4s800d x mobo
If you have an operating system on your computer you should download and run the "Windows 7 Upgrade Advisor" available from the microsoft website.
Feb 27, 2013 | ASUS P4S800D-X Motherboard
I want upgrade my emachines t6528 hard drive and ram.i need help
Memory Upgrade for eMachines eMachines T6528 Computer, the eMachines eMachines T6528 Computer takes the PC3200 DDR SDRAM DIMMs. Supports Dual Channel DDR. Memory Type, and comes installed with 512 MB (removable) of Memory. You can upgrade your eMachines eMachines T6528 Computer to up to a maximum of 4.0 GB Memory, the system has 4 sockets to install Memory, already with 512 MB (removable) standard Memory installed. For best Computer performance use the maximum amount of allowed Memory per slot for your Computer.
As for the Hard Disc.... the following address will give step by step instructions on installing a new HD. http://www.manualowl.com/m/eMachines/T6528/Manual/
Thank You for using FixYa
Tom Miller
KD4DTK
Aug 19, 2012 | E-Machines T6528 PC Desktop
I need to buy memory for my computer its an emachines desktop model# T3410 512 MB DDR SDRAM and I dont know what to get
in DDR ram there is some models like ddr and ddr2 and another new model is DDR3. First you check what is your ram related to. for that in some pcs bios option system information the details are there. For that at the time of booting before windows logo press the button whatever is showing to enter setup. and check otherwise remove your ram and take that to a computer shop and take a new ram with same model.
And one more thing is you have to check your clock speed of your ram. Remove your ram from pc and check if any information is there on ram
Jun 24, 2010 | E-Machines eMachines Desktop PC
How can I upgrade/improve the capabilities of my Inspiron 1200
The best and quickest improvement is to add more RAM. Add another 512 Mb of RAM. If you already have a 512 Mb of RAM module then add another 512 Mb RAM module. If your laptop has 2X256 Mb RAM modules then you need to remove these and insert 2X512 Mb RAM modules.
The reason why you have 504 Mb RAM is that the video card has grabbed 8Mb of RAM off the main memory.
May 21, 2010 | Dell Inspiron 1200 Notebook
What is the hidhest ram i can use on a celeron 2.6
Hi. The amount of memory that can be installed is limited by the motherboard, not the CPU. That being said, the motherboard you have listed will take the following memory:
Each memory slot can hold DDR PC2700,DDR PC3200 with a maximum of 1GB per slot.
Sep 28, 2009 | Intel Celeron D 325 2.53GHz 533MHz 256KB...
Celeron d ram
you will have to find out what type of ram it is DDR, DDR2, DDR3, and how many sockets the motherboard has.
What Model is this computer or what is the mother board model? then we can find more out.
Jun 20, 2009 | Intel Celeron -D 2.26Ghz Computer System...
HELP with with Intel celeron d 325
Phew, k3! A ton of questions and even more confusion going on here!
Firstly (love that non-word), your Motherboard accepts DDR Ram. Unfortunately, DDR2 will not be compatible. Won't work. Sorry. It does accept up to 2gb of DDR Ram, though.
Second, for Graphic Card slots, it has 3 x PCI slots (NOT PCI-Express), which are great for G-Cards. Maximum amount of memory won;t be affected by your MB, but by your processor and ram. As long as it has a PCI slot for a PCI card, you'll be good. Just be sure to turn off integrated graphics in BIOS settings.
Thirdly, good luck. Opening up the side of your PC can be daunting at first. Ensure you either have the patience to learn before you touch or have the money to continue learning as you go. >.o
Mar 01, 2009 | Intel Celeron D 325 2.53GHz 533MHz 256KB...
Dell optiplex p4 1.8ghz: RAM
Best and easiest thing to do is go to www.crucial.com and run a scan of your computer. It will tell you what you have, how much it will hold, and what kind of modules.
Yes, it's safe.
Thanks for using Fixya!
If you have any trouble, comment back.
Jan 28, 2009 | Dell OPTIPLEX GX240 P4 1.8GHz 512MB 20GB...
My name is Siavosh Eskandari. I have a desk top PC Compaq presario Desktop with Intel celeron processor 2.7 HHz Model SR1010NX, Prod. # DW25AA-ABA,Serial # MXK4180P8Y with 256 MB PC 2100 DDR SDRAM. The...
the model SR1010NX can take upto 1gb max of ddr 1 ram and must be done a 2x 512 ddr 1 chips
Memory Component Attributes Memory Installed 256 MB (1 x 256) Maximum allowed 1 GB (2 x 512 MB) requires the replacement of the installed 256MB DIMM Speed supported PC2700 MB/sec (messages at PC2100 Type 184 pin, DDR1-333 SDRAM DIMM slots Two
Nov 28, 2008 | HP Computers & Internet
Diamond Multimedia Stealth S60 RADEON 7000, (32 MB) PCI Graphic Card Logo
294 people viewed this question
Top Diamond Multimedia Computers & Internet Experts
David
David
Gareth Cockram
Gareth Cockram
Jason Harris
Jason Harris
Are you a Diamond Multimedia Computer and Internet Expert? Answer questions, earn points and help others
