RCA WHP141 Consumer Headphones Logo
Posted on Feb 09, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
New out of the box and the cover for the batteries will not open? Does the cover screw off? I know it is counter clockwise but it will not turn???
Anonymous
Level 3:
Guru:
  • Master 2,178 Answers
  • Posted on Feb 09, 2011
Anonymous
Master
Level 3:
Guru:
Answers
2178
Questions
0
Helped
390290
Points
6614
On the right headphone, locate the battery compartment.
Use the finger depression on the compartment to turn the battery
compartment cover counterclockwise to remove the cover.
Anonymous
Level 2:
Sergeant:
  • Expert 214 Answers
Anonymous
Expert
Level 2:
Sergeant:
Answers
214
Questions
0
Helped
101931
Points
560
From what i read i think you need to apply pressure to the compartment then turn counter clockwise .
check out the manual link here , page 7.
on the link page just type the numbers shown below , you don't have to give email
http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man
How do you change the battery of electronic glass scale Model # TN400/TN410
Turn the battery cover clockwise to remove insert new AA battery. Make certain the polarity is o.k. put the cap back on and turn counter clockwise.
3helpful
2answers
How do I change the battery on my zebco 33 live bait reel
take it to your local tackle shop, it needs taking apart and resealing
Commercial kitchenaid mixer will not switch on? I have replaced the amp on the plug and carbon brushes (putting them in the correct way) and still not joy. Any ideas about the problem? I was given the...
Yes i would open the back cover and try the adjusting screws on the speed control plate, I have repaired several mixers just by turning the two top screws a quarter turn counter clockwise or just the bottom one a quarter turn clockwise.
You will have to check the plug it may be damaged and make sure your wall outlet is working and not operated by a wall switch that may be turned off. seems silly I know but check anyway. let us know if this helped, there are other things to check but i would start there first
Mar 30, 2013 • Food Mixers
How to change oven light
Which model Whirlpool range do you have? For most Whirlpool ranges that I have used , the oven light is covered by a screw-on glass cover. When the oven is cool, unplug the range, open the door and turn the cover counter-clockwise (to the left). Then remove the 40W bulb (again counter-clockwise rotation). Replace the bulb with another 40W appliance bulb. Then replace the cover by turning it clockwise until it is tight. Do not over-tighten either the bulb or the cover. Then plug in the power cord for the range. (Unplugging the unit makes sure that you will not get shocked if anything goes wrong. Sometimes the bulb may break in the socket - in that case, use pliers to unscrew the base of the bulb before replacing it with a new bulb.)
Whirlpool has the manuals for most of their appliances on their support site: https://www.whirlpool.com/webapp/wcs/stores/servlet/OCManualsLiteratureSearchView?catalogId=10561&langId=-1&storeId=10211&krypto=5QgxQhneFliXuEuX564wSQ%3D%3D&ddkey=http:OCManualsLiteratureSearchView .
I hope this helps.
Lamp light is blinking on my sony 42 grand wega rear production tv...how do you fix install a new lamp
first step.remove the screw and lamp door cover at the right side of your TV . After removing the screw and lamp door cover, you will see the lamp cover (it is color black with a handle at the bottom).then turn the knob/handle of the lamp cover on counter clockwise direction to remove it. Then you will see the lamp of your projection TV. Remove the old lamp and replace it with a new one..Make sure that the lamp is properly installed, the return the lamp cover and turn the knob on clockwise direction to lock it up,then return the cover ,screw and its done...
2answers
Which way do you turn the piston clockwise or counter clockwise to retract the piston in when installing new brake pads on a 2006 Ford freestyle?
Clockwise-on the rear
I would open the bleeder valve first, push piston in,then screw parking brake in.
You need to flush your brakes every couple years,anyway.
After you install new pads,ratchet brake up by hand.
How do you lock spindle on Delta Osillating sander to change sand rolls?
The spindle screw is reverse tread and you need to turn it clockwise to loosen and counter clockwise to tighten the screw. You can usually hold the spindle with your hand then turn the screw clockwise to loosen the screw. Worst case scenario, carefully turn the machine upside down. Place it on a clean supporting surface. Use a flat-head screwdriver or similar device to remove the plastic gear cover to gain access to socket-head screw. Carefully place the machine on its side. Attach the spindle adapter to the motor shaft turning the spindle adapter counter-clockwise on the shaft.
NOTE: Motor shaft has a left-hand thread.
Place a 7/16" open-end wrench on the flats of spindle adapter. Insert a 3/16" hex
wrench into the socket-head screw located where the plastic gear cover was removed.
Hold the hex wrench to prevent the motor shaft from turning. Turn the wrench counter -clock wise to
fasten the spindle adapter on the motor shaft.
Reinstall the plastic gear cover that was removed above.
Jul 10, 2010 • Garden
Safe open but in locked position
I can't tell you how to set a new combination, without you having a tumbler key.
BUT I can tell you how to figure out the old combination.
First remove any armoured plate that covers the back and unscrew the cover plate. You will see wheels with slots cut in them. These are the tumblers. Now just like you know what the numbers are rotate the dial three times counter clockwise...then looking in through the back cover , slowly turn the dial clockwise ... look for the tumbler that is turning and stop where the slot lines up with the drop arm. Now look on the dial and write that number down. Now start on the second number by turning the dial counter clockwise until the second tumbler is lined up with drop arm. and so on
With a little patience you will figure it out.
I hope this helps you.. If you have any questions please ask.
Good Luck,
RSMITH972278
2answers
How do change the battery in a BSA HD42SB
remove the screw on battery cover counter clockwise.  Replace the small button battery and carefully replace the battery cover and don't forget the o ring.
2answers
How do I change to clutch on this blender. The outside of the clutch broke off leaving just the screw head on the blender, when I turn to unscrew it, the entire piece just spins, any suggestions.
You can probably use a Vise-grip pliers to clamp down on the brass insert and unscrew it. Not only is it on very hard, but it is also threaded reverse of a normal screw. This is so it does not come undone in normal operation.
You have to turn it counter-clockwise to unscrew it (a regular screw turns clockwise).
I had to clamp the motor shaft real tight with a bench vise to be able to remove the clutch. Hope this helps.
-Vince
Top RCA Audio Players & Recorders Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
