Question about NetGear WGR614 Wireless Router
Netgear router rangemax adsl wireless router
Can you tell me why my router only seems to only work for about 2hours then crashes & signs me off net then if i unplug it. It will start again for the same ammount of time
Dear sir i cannot afford to get into debt i,m 70 years of age and diabbled thtis why i signed ooff your offer ann i didn,t get over my problem sorry if ive been any bother to you
Posted on Jul 23, 2008
My Rangemax wireless wndr3000 is not working properly, though it has in the past. The problem seems to be that I'm hooked up to the wireless network (ex. I can print wirelessly), but with no internet....
Same situation here. Wired connection from modem works fine. I can also log in to the router via routerlogin.net. However, the router does not detect an internet connection.
Jul 12, 2011 | NetGear WNDR3300 - RangeMax Dual Band...
I have been offered a Netgear N150 DGN1000 Wireless ADSL modem Router new for only £25.00 from a friend, however it has a sticker on the box that says ''For BT Connections''. I wanted to know if this...
Well this product DGN1000 is a generic router supplied by Netgear and can be used with any ADSL/DSL ISP. Please ensure that you upload the latest firmware for this router from the netgear support site and then you can use it with other ADSL/DSL ISP.
Hope this allows you to resolve the issue. If you need further assistance then let me know.
Regards
Anand
Jul 15, 2010 | NetGear RangeMax WPN824 Router
I connect fine to it but cannot get to internet
This is not a trivial task but to start, I presume that your Wireless Router is connected to an ADSL or CABLE modem:
1) Make sure that you can connect to the Internet/Web directly from the ADSL/CABLE modem. 2) Once you have step 1 validated, connect your Wireless router to the ADSL/CABLE modem. 3) Ensure that you can communicate to the Wireless router and use Netgear supplied software - I suggest that you connect your PC/LAPTOP used for configuration directly via an ETHERNET cable attached to your router: 'NETGEAR's Smart Wizard™ makes the set-up of the RangeMax™ wireless router easy and hassle-free. Smart Wizard automatically detects your ISP's network settings, then walks you through each step of the installation proces' 4) When the installation is finish, try connecting to the internet via the ETHENET cable on your router. If it does not work, the FIREWALL on the ADSL/CABLE MODEM may be blocking the port and needs to be opened/disabled. 5) You can now concentrate in getting the WIFI working by first using an 'unsecured/no encrytion' connection by setting an appropriate SSID. 6) Once setp 5 is working, you SHOULD NOW SECURE your Wifi connection by using a selected encryption (such as WEP or better) and security key.
ps. you will get this 'limited access' message if anywhere in the device chains the IP addresses cannot be resolved.
Dec 20, 2009 | NetGear RangeMax WPN824 Router
My Netgear Rangemax WND3300 has been working fine for 1 year, but in the past 2 days the 2.4 GHz wireless signal has been cutting in and out every 30 seconds, making it impossible to use my laptop. I...
Well, There seems to be an issue with the wireless network on 2.4 Ghz band. Please change the wireless channel on 2.4 Ghz to a diffrent value and check if works fine.
Let me know if you need any further help.
Oct 20, 2009 | NetGear RangeMax WPN824 Router
ADSL setup problem for O2
You need to manually configure the router.
Connect a computer directly to the router using ethernet cable and access the router page using address http://192.68.1.1
Username = admin and password = password
Click on ADSL settings in the left hand side menu. Enter the requred infor VPI= 0 VCI =101. Select the required multipexing mode.
Hope this helps.
Jun 20, 2009 | NetGear RangeMax Dual-Band Wireless-N...
Using default connections on netgear allowing
You also need to tell your PC to get its IP address automatically from the router.
Jun 11, 2009 | NetGear RangeMax WPN824 Router
Can not install my router
First of all power off the net gear wireless adapter and than try to install the rangemax. if it dosen't work than please check the dhcp range in both the wireless router are the of the same range. than kindly the change the range of dhcp of this new rangemax wireless adapter. you can change this dhcp range my connecting the router to your computer and login by default ip . e.g http://192.168.1.1 and login with userid "admin" and password "admin" than go to lan management option and try the same.
Dec 03, 2008 | NetGear RANGEMAX WNR834M Router...
Best Buy says I "must" use their $250 wireless router when I buy a Verizon Air Card; true?
You can still use your Netgear Rangemax Wireless Router if ever you avail there service, there's no problem with it of coarse they will say that it wont work so you can get all the networking device from them that's a plain marketing strategy , I can tell you any wireless router will be working for their service.....
Oct 27, 2008 | NetGear RangeMax WPN824 Wireless Router...
NetGear WGR614 Wireless Router Logo
37 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
