Question about Toshiba Satellite 1715XCDS Cooling Fan (k000882360) Laptop Cooler
Hard drive replacement
The bottom of the laptop has two covers; one is the battery and the other covers the RAM. How do I get to the hard drive on this model laptop? There are no other access hatches.
    Genius:
  • 2,028 Answers
Can only find one manual for this machine and the download is only compatible with Windows ME. The hard drive is located in the front left hand corner of the machine. Look at the front for a retangular panel, held by two screws, that slides out. Also, with some of the older Toshibas to acess the drive, you had to remove the plastic that surrounds the keyboard, holding the mouse buttons.
Posted on Jul 22, 2008
How to set a toshiba hard drive to slave?
Power off the Toshiba laptop. Remove the power cord and the battery.
Turn the laptop upside down and remove the panel where the hard drive goes with a screwdriver.
Depending on the model of Toshiba laptop being worked on, this may include the entire bottom panel, a panel covering both hard drive slots or a panel covering the empty second slave hard drive slot.
Install the second hard drive by inserting it into the open slot.
Replace the opened cover.
Replace the battery and power cord.
Turn on the computer.
The second hard drive is automatically configured as the slave drive.
Depending on the operating system and previous status of the slave hard drive, it may need to be partitioned or formatted before being used by the operating system.
hope this helps
Sep 13, 2012 | Toshiba Computers & Internet
HOW TO UPGRADE RAM ON VAIO VPCM121AX LAPTOP
Memory Upgrade for Sony VAIO VPCM121AX Netbook Laptop, the Sony VAIO VPCM121AX Netbook Laptop takes the PC2-6400 DDR2 SDRAM SODIMM 200pin memory Memory Type, and comes installed with 1GB (Removable) of Memory.
You can upgrade your Sony VAIO VPCM121AX Netbook Laptop to up to a maximum of 2GB Memory, the system has 1 Socket to install Memory, already with 1GB (Removable) standard Memory installed.
For best Laptop performance use the maximum amount of allowed Memory per slot for your Laptop.
if you're not sure if a module is right for your system, use the Crucial Memory Advisor tool for a list of guaranteed compatible modules.
first you will need to select the manufacturer from a drop down list then select your product line
from a drop down list then select the model then click find it will take you directly to compatible ram also you will have an option to scan your system
Power off the computer, and unplug it from the power source. Close the computer and turn it over.
Slide off the battery cover and remove the battery.
Locate the memory bay and remove the screws in the cover.
Remove your old RAM board(s) by pushing the metal clips and holding it down and outwards until the RAM board pops up. Then pull it out at a 30-degree angle. (If you only need to add more RAM to your existing RAM and you have enough available empty RAM slots, you will not need to remove the RAM.)
5
Insert the new RAM board into an empty slot at a 30-degree angle until you hear it click. Then push it flat down into the slot.
6
Replace the cover and screw it back in.
Upgrade the Sony VAIO Hard Drive
7
Locate the hard drive bay and remove the screws from the cover. Then slide the cover off.
8
Pull the hard drive out of the bay.
9
Remove the screw securing the hard drive with the magnetic screwdriver.
10
Pull the hard drive out of the bay by the black tab connected to it.
11
Re-insert your new hard drive into the bay and replace the cover.
hope it helps
Jul 15, 2012 | HP Pavilion dv7 Keyboard (483275-001)
Hard drive replace
Remove the power cord, remove the battery, turn the laptop over and remove the screws from the cover that houses the hard drive. The icon where the hard drive is located will be 3 circular discs. Once you remove the cover, there might be screws that hold the drive in the bay so remove them. Carefully lift the drive out then remove the screws from around the drive that holds it in the caddy.
If the hard drive is not on the bottom of the laptop, then it will be under the keyboard or palmrest.
May 09, 2012 | Computers & Internet
How do i remove Hard Drive from my Acer Aspire Note Book Model 5742Z Taken one screw out of carrier for HARD drive still cannot remove drive &carrier help Ken Leatham
I found this online, so hopefully it helps. It's to a page selling a second hard drive caddy for the 3623WXCi, but at the bottom is has directions on replacing the hard drive for that model as well.
http://www.batterystyle.com/acer-aspire-3623wxci-caddy-p-413622.html
Sep 06, 2011 | Acer Aspire 3623WXCi Notebook
Dell Inspiron N5030 refuses to boot. When it is turned on, the ON LED light stays on for a minute & goes off. There is no display on the screen. But when it is plugged to A/C, it stays on for a while...
The first thing to check for is loose ram, battery, a loose hard drive or any loose cards.
Pop the cover off the bottom, reseat the ram battery and hard drive and try booting again.
If that does not work try booting off a copy of Puppy linux on a live CD. Puppy runs only in ram and will allow you to bypass a bad hard drive to get a system running. Puppy also has system testing tools that you can check your hard drive with.
Aug 15, 2011 | Dell Inspiron N5030 Notebook PC
How to open and change RAM memory and hard drive on Gateway Netbook model number LT2704u?
This netbook is really the Acer Aspire One D255. You have to pop off the keyboard, then remove 4 screws that hold the back panel in place, which will allow you to remove that back panel in order to get to the memory.
Here's a video - blurry but it tells the story: http://www.youtube.com/watch?v=6KYNTvF0-5M
Mar 01, 2011 | Computers & Internet
My toshiba l300 only has a black screen!! when i start it up the lights come on at the bottom but the screen remains blank!!
L300 series laptops are very good normally but don't boot up if there is a device in the USB slot or a CD/DVD in the drive.
If it still refuses to POST, remove the AC Adapter, remove the battery and remove the hard drive.
Power the unit up without the hard drive and it should complete POST and complain that there is no hard drive. If that doesn't work remove AC adapter, ensure battery is disconnected and remove hard drive and RAM. Try again. If it still doesn't work, you have a mother board fault and it needs a service centre.
If it does work at one of the options, when you have closed the laptop down, replace the RAM first and test, then the Hard Drive.
Hope this fixes your problem.
Dec 28, 2010 | Toshiba Satellite Pro L300 Notebook
Replace the hard drive
remove all the screws in it and gently remove the cover.
Jul 08, 2009 | Sony VAIO VGN-NR285E/S 15.4" Notebook PC...
I like to replace old hard disk
There are panel/covers on the base or near the bottom edge of most laptops these enclose the RAM and hard drive. Remove these screws and covers to reveal the hard drive and possibly the hard drive carrier.
Before you attempt this I suggest to login to the Sony WEB site and download the drivers for the graphics and sound device including modem and LAN if you don't already have them and back up your data. You will need these drivers when you install a new and larger hard disk and the operating system.
Nov 15, 2008 | Sony VAIO VGN-SZ460N/C Notebook
Need help to replace hard drive in my Sattelite 1415S116
Hi Jerry
Here are the steps on replacing the harddrive in your system. It is pretty each just becareful of the static see warning below. Everything should go smooth for you.
  1. Remove the laptop battery.
  2. Remove one screw securing the hard drive bay cover. This will be located on bottom to the left of the battery in the rear.
  3. Remove the hard drive bay cover.
  4. Remove the hard drive out of the bay.
  5. Then put in new hard drive an cover back on and battery last.
ESD can permanently damage your computer and even kill it. Always ware ESD wrist strap when you work with internal computer components. And avoid static discharge.
Hope this helps answer your question.
Bill
Jun 23, 2008 | Toshiba Computers & Internet
Toshiba Satellite 1715XCDS Cooling Fan (k000882360) Laptop Cooler Logo
159 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
