I had just finished watching a video that I had recorded on an unfinalized disk. I unplugged the camcorder from my TV and got an error message (can't recall what it was).
It now is prompting me to format the disc but that will erase all that I have on it. HELP!!
Lynda
Place an empty disc in, format the disc, record a little scene. Turn off camcorder. Place the error disc in the camcorder, turn on the camcorder all the way to play/edit. If this doesn't work turn it to record and try to record. Worked for some of my error disc
hi its geoff
yes you can. i dose say that no more recording can be done after the disc is finalized (thats true, you first have to unfinalize the cd to write more files on it.but you can initialize the disk at any time but you lose the recorded content(it frormats the disk) then you can use the disk over and over again. remember finalizing and unfinalizing requires you to plug the mains charger into the camcorder it assumes theres not enough power in the battery to do the job and will need the mains every time.but initializing only requires sufficient battery power .
If your mini DVD disk is a DVD-RW (or DVD+RW) and it had (previously) been finalized in the VR (or Video) mode, simply select the "unfinalize" option ... (in DISC - Camera mode, from the MENU - Disc Manager - Disc Unfinalize ) ... as in p. 82 of your manual.
If you do not want the video data on the DVD-RW disk anymore, you can simply re-format the disk again, so you can re-use the disk.
Unless you recorded in VR mode, then you will not be able to delete single video clips.
The only option left for you is to "initialize" NOT "unfinalize" the disk, (warning: this will erase your ENTIRE disk). Once you initialize, you will have an empty disk to re-record on.
VR mode allows more editing and delete options but DVDs recorded in this mode are not compatible on all dvd players.
Try to use a cotton swap to 1st clean the recording lens or blow gently on it. Place an empty disc in, format the disc, record a little scene. Turn off camcorder. Place the error disc in the camcorder, turn on the camcorder all the way to play/edit. If this doesn't work turn it to record and try to record. Worked for some of my error disc
Drgadgt
Try playing the problem disks on your PC. If they wont play and the "Finalised" disks do then try recording a further brief clip on the problem disk. If that works then attempt to "Finalise" again. Can you play the problem disks in the Camera by the way?
connect a lead via your tv video out audio out jacks. Select tha appropriate channel (You may have to go through the av channel on you tv and tune in the channel you want to record) or, video or dvd player audio out video out jacks.
connect other end to your camcorder. Select on the camcorder menu video in audio in. Turn on tv. If connected to video or dvd player, press play. Press record on your camera. When finished recording press stop.
Presuming the camcorder is tape, you can buy a tape adaptor to play or record your mini tapes in a standard video recorder, then take them out of the adaptor and play them back on your camcorder. You can also do all this via a computer. Also if the camcorder is disk or hard drive it can be used the same way as a regular dvd recorder to record tv programmes once connected to you t.v.
Let me know how you go
26 red
