Back to:
Tags:
Panasonic DP-150A Grayscale Copier
Paper jam
posted by saramansy on Jul 22, 2008
Hi my copier is working fine but when it prints the paper pulls fine but I think theres something wrong with the roller inside bcause the paper would get crumbled befor printing causeing it to jam. What can Ido?
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Jul 23, 2008
Not Rated (0)
checkitright
Rank:Wiz Wiz
Rating: 82%, 645 votes
If it crumbles just before the exit, then the problem is with the fuser unit, there are 4-6 claws/teeth/scrapers that are supposed to help guide the paper out, when they wear out the catch the paper and turn them into accordions. Replace the claws, and check the heat rollers.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Paper jam:
I don't want to Accept this solution
Can you Help with these Copiers problems?
Copiers
when i turn on the copier it shows an error f35 - can i...
Copiers
Copy quality is fine (even though this machine would...
Copiers
I have a copier that went a little bit over the 100k with...
Copiers
Everytime i try to make a master copy,it didn't makes a...
Copiers
Duplo DP-203
Loading problems.
Repair Service
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
