Question about Cameras
Camera not staying on
My Samsung Digital Digimax shuts off after a few seconds.
New batteries fitted.
Battery gauge reads 'not full'
Please e-mail me
jerry_elena5@hotmail.com
  • fiery07 Jul 23, 2008
    Hi Bubbabear
    Many thanks for your reply.
    There is a small hole next to the USB 'in'...it says DC 'in'
    3.3 V.
    I do have a lead fro USB to computer, but nothing that goes into
    the 3.3v hole....never tried it...what's it for ?
    At present I am in South America and my mauual is in the UK !
    Thanks JERRY
  • Tim Babcock
    Tim Babcock May 11, 2010
    Does your camera have a charger with it or a way of plugging electrical power to it?
  • 2,794 Answers
The 3.3v is for a charger. If you camera has rechargeable batteries in it, thats where that goes.
Samsung.com has them available on their website.
You could inspect the battery contact to see if their getting a connection. sometimes they get bent, corroded, or oxided. You can try cleaning them up.
Posted on Jul 23, 2008
When i turn on my samsang digimax v700, some time it beeps 3 times and shuts off, some time it stays on for a minute, i could enen take a pictue or change the zoom position but then it shuts off without...
is it new? if its not , maybe there's a problem on your battery, check the status of your battery if its full charge or not or is it charging when you plug the charging adapter
Jun 18, 2011 | Samsung Digimax V700 Digital Camera
Samsung digimax S700 battery problem
Clean the battery terminals and clean the metal contacts in your camera and insert your battery and check, whether you get low battery warning.
Hope this helps.
Jan 31, 2010 | Samsung Digimax S700 Digital Camera
Hi---our Digimax won't stay powered up, even with fresh batteries. When the power button is pushed, we get a green light for about two seconds, then camera shuts down. Any tips?
Your problem may be due to corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, the camera may have a problem that requires professional repair.
Oct 31, 2009 | Samsung Digimax A503 Digital Camera
Digimax s500 cutting off
BAtteries draws down too quick...
Use 2500 mAh or better for longer life the higher the number...
eveready bunny is sometimes not in all their work
Jul 27, 2009 | Samsung Digimax S500 Digital Camera
No picture on screen after 1 second
Try this. Go to your tools menu, look for something like power saver or display off and change the duration that the screen stays on.
Jul 08, 2009 | Samsung Digimax S500 Digital Camera
Camera wont stay turned on
I had the same problem - found the answer on another forum: remove battery and memory card, press shutter button twice, replace battery and memory card, and switch on.
Nov 12, 2008 | Samsung Digimax i6 PMP Digital Camera
I am having an issue getting a clear picture with the Panasonic WV-CP254 using the Panasonic WV-LA2R8C3B Lens, 1/3``, AI, F1.3, 2.8mm Super WA. This is a new install and I followed the instructions for set...
My Samsung Digimax A5 is not staying on with new batteries fitted ?
I have used this camera for 3 years...never had a problem.
It's Digimax A5 / A53
Please e-mail me
Jul 22, 2008 | Cameras
Samsung Digimax D53 Digital Camera
refer to my answer I gave to:
bsnydto
why does my camera say low battery...
seems to be the same problem
Jun 20, 2008 | Samsung Digimax D53 Digital Camera
HELP!
Use lithium batteries. I had a problem when our camera would turn on for a few seconds, beep 3 times, and then shut off. The best batteries, which are actually recomended for this camera is the lithium batteries. I strongly suggest them.
Nov 13, 2007 | Samsung Digimax S500 Digital Camera
Camera won't turn on
Please eject camera battery and clean with a pin your battery tip in your camera with care fully.
Hope its helpful to you
Sep 26, 2007 | Samsung Digimax L60 Digital Camera
Cameras Logo
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
