Pre Amp Set up
How do I set up Phase Linear Pre Amp to a system that has an amp and a mixer? Where do I go out to in from Pre Amp to Pre Amp/Mixer? Where do I hook up the accessories ie CD player/turntable. All 3 units have ports for these accessories.
  • 143 Answers
Get the right cables and plug them in. Pre-amp to mixer to amp. Radio Shack is a good place to buy the wires with proper ends on them.
Posted on Jul 23, 2008
Less than a year my church purchased wireless microphones suddenly not working there is no sound coming out of microphones. HELP!!
What does the receiver go into ?
a pre amp mixer ?
What are the volume levels set at on the mixer for the receiver input ?
Also check if the pre amp goes into another amplifier that the volume setting on the final amplifier device if used have not been turned down.
Bet someone has fiddled with these settings of volumes !
Aug 23, 2015 | Pyle Pro PDWM5000 4 Mic VHF Wireless...
PB10 mixer
speakers i suggest something like sp 2
amplifier i sugest an intergrated amp with main in and pre out (in order to conect the mixer)
moinitor your choice
Mar 05, 2014 | Peavey Audio Players & Recorders
Mixer only runs at one speed
if it runs only at high speed it needs a new phase control board if the mixer is post 1978, if the mixer is pre 1978 then you will have to replace a capacitor on the end of the power cord inside the mixer. if the mixer only works on one speed that is not high speed then you need to adjust or replace the speed control plate on post 1978 mixers and the capacitor on pre 1978 machines. Hope that helps
Jan 30, 2013 | KitchenAid Food Mixers
Power mixer to a power amp.
You have two aux sends on that mixer so quite easy to use one of those to feed the external power amp. You could have one set of spkrs connected to that amp and another connected to the powered mixer. This would give you full independent control over each set.
Aug 09, 2012 | Samson Xm910 8Channel Powered Mixer...
How to run receiver+mixer+pre-equalizer-mixer+equalizer+receiver in loop
solution 1
repost this to right forum for other experts to solve
Jun 02, 2012 | Sony PC Notebook
I have a ep4000 amplifier, how can i connect to a mixer
The rule of thumb is you control your audio on the low side. That means you plug your mics, tuners, audio sources into the pre-amp and then the pre-amp into the equalizer/mixer ant finally the mixer into the power amp and the amp into the "large honkin' speakers". The inter connects on the low side (between the source, the mixer and the power amp are usually done with RCA plugs. Use a good quality set of cables to get good tight connections and solid grounding.
AUDIO SOURCE?MIXER?POWER AMP---
heavy speaker wire sized to your SPEAKERS.
Sep 29, 2011 | Behringer EuroPower EP4000 2Channel...
My band plugs into the input channels on the SX2442FX mixer, which we then hook up to the PMP2000 to use as a PA. Since the SX2442FX is not a "Powered" Mixer, I figured that we should be going...
Either way will work, however your friend's method probably would be slightly better since it goes through less stages within the PMP2000. The "left and right power amp inputs" are the INPUTS to the power amp in the PMP2000 and hence are the best places to connect the mixer if using the PMP2000 as only a power amp. Note doing this will LIKELY disconnect any other input to the PMP2000 from the power amps in it... that is all the preamps in the PMP2000. DO USE TRS cables!!! and power both units from the same receptacle to avoid ground bounce.
Aug 25, 2011 | Behringer Sx2442fx Eurodesk 24channel...
I have a new set up and i need a step by step instruction on how to set up the mixer to the amp and the decks to the mixer/amp
if this is a dj type set up, the mixer should have a main output (RCA or XLR), that is what you connect to the input on the amp, each deck should have RCA outputs, depending on if they are turntables or cd players, plug the turntables into the phono channel inputs on the mixer and if they are cd players, plug them into the line inputs on the mixer
Mar 28, 2011 | Audio Players & Recorders
Cant hear anything out of my speakers connected to djio
Are you using a Mixer as a pre-amp for this set-up? For example, I have a Numark CM200 where I have all of the inputs and outputs I need to run. DJ IO is connected to Chanel 1 and Chanel 2 Lines in my mixer. The DJ IO is conected to my computer by USB cable. In Traktor souncard settings chanel 1 is set to (3&4) Chanel 2 (2&1) also, devise set up is Numark DJ IO and in External mode. Of course the mixer is conected to my amp and speakers conected to the amp as well.
Apr 26, 2010 | Numark DJ/iO Sound Card
Multi Room Function on marantz SR-19
Hi..
Put a RCA (phono cable) splitter at the pre-out /main in.
That way you can go to both amps with the same signal
Jan 14, 2009 | Marantz SR-19 Receiver
163 people viewed this question
 Grubhead
Grubhead
