Question about Hotpoint Washing Machines
I have a hotpoint wt540 washer and it is sticking in wash mode now. i put some washing on this morning and it was still washing in wash mode when i got home about 8 hours later
    Genius:
  • 1,028 Answers
Bad timer or remotely possible bad wiring connection to timer motor
Posted on Jul 23, 2008
All lights flashing
just fixed 1 of these this morning.....was the main board at rear of machine in bottom corner.........
cheers
Mar 10, 2015 | Hotpoint Aquarius WT540 Front
Wt540
how-2-repair.com i found this web site for you
Mar 31, 2014 | Hotpoint Aquarius WD63 Front Load...
Hotpoint Wt540 1400 wont spin
check the machine washes ok if it does not turn the drum on wash check the motor brushes if drum action is ok on wash check the drain pump for blockages
Mar 06, 2014 | Hotpoint Aquarius WD63 Front Load...
Hotpoint wt540, reduced creases and extra rinse lights are staying on all the time
1) clean the contacts ribbon with erase pencil and put a little ethylic alcohol.
2) try it 3) if the problem persist the control board is faulty.
God bless you
Oct 11, 2012 | Hotpoint Aquarius WT540 Front
Hotpoint aquarius wt540 - it has started to malfunction
Most likely a control board failure, you need a service tech to come out.
Oct 27, 2017 | Hotpoint Aquarius WT540 Front
How can I unscrew the drain outlet at the bottom front of my Hotpoint WT540? Our machine has completed a wash and drained, but isn't spinning. The door light flashes when I try and run a spin. I decided to...
Keep trying to unscrew it, as it should come right out for cleaning. A little water will come out too so put a small tray under the machine first.
Look at my other solutions, as for DOOR light flashing.
Apr 02, 2010 | Hotpoint Aquarius WD63 Front Load...
Hotpoint aquarius wt540 no power in machine no light at switch
Hi, check the following trouble spots below. you will find the issue in one or, all the areas stated.
1. No power to the washer
Make sure there's power getting to the washer. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power. Sometimes the power cord disconnects at the washer, if this is the case, the wiring must be repaired or replaced.
2. Lid switch/door switch
The washing machine may not function if the lid switch or door switch is defective. The switch is usually located near the door. Replace if found defective.
**If you are getting power to the washer and, step 1 and 2 check out ok, replace the timer control and start switch as well.(You can test the continuity or, resistance level of the Lid switch with a multimeter(ohm).
Jul 16, 2009 | Washing Machines
The prewash light won't stop flashing and washer
get it checked by and expert it sounds like the board has gone or the door lock is faulty
Jun 28, 2009 | Washing Machines
Hotpoint wt540 can't get filter out
It is possible you have got something stuck in filter, and this is what is stopping it coming out, you are turning it the right way, you will just have to stick with it, and keep trying to ease it out.
Keep trying to eaes it in and out, and you should be able to remove it eventually.
Plz rate this solution.
Thanks.
Dec 14, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Washing Machines Logo
177 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
