Question about Bosch Classixx WFC 2465 Front Load Washer
Conditioner drawer not emptying out (filling with some water but not enough to drain away) Bosch Classix 1200 thanks Bill
  • h14lrh Aug 01, 2008
    mines exactly the same bosch classixx 1200 not emptying the conditioner drawer, have cleaned all around and no improvement. Any suggestions?
  • TSM Copiers Ltd Sep 24, 2008
    I had similar problem, however mine did not finish the program ad came with error as 1200 and 600 rpm were lit and it beeped differently than usual. what i did was cleaned the upstanding pipe coupling it was cloged.
    Scholar:
  • 97 Answers
Hiya
more than likely the cold inlet valve as mentioned above, these are not hard to replace so even with minimal diy skills should be an easy fix. i think £30 is a bit steep for one of those though even if it is a genuine bosch part. try these as i've always found their prices quite cheap
www.masterpart.com
Phone Sales on 0871 811 7011
hope this helps
please dont forget to rate the helpfulness of this reply, thanks kj
Posted on Aug 06, 2008
I've also got this problem and by taking the lid off I can see where the water comes in a tthe back of the machine there is a Solenoid (a switch that diverts the water during the programme to a 2nd water hose that feeds the conditioner) not working (I tested this by removing the hose from the output of the solenoid - turning on the programe and checking no water came out - this proved no blockage)
I can see the part is about £30 amd now looking to see how easy to is too fit
Posted on Aug 01, 2008
Bosch classixx 1200 fabric softener dispencer doesn't empty into machine just fills with water
Pull out dispenser drawer in the middle section for fabric softener lift up top plastic cover and flush out hole with water and this should solve the problem
Jun 08, 2017 | Bosch Washing Machines
Why does the conditioner drawer not empty
If you remove the drawer and pull up the flap that has 'max' written on it, checked that the two cylinder parts are clear, especially the larger of the two as the fab cond and water are drawn up the side of these when they are together by capillary action (make sure when you close the flap down the large cylinder sits over the small on and the whole thing clips into the main body of the drawer). While you have the drawer out, look into the top of the dispenser housing (in the machine) look in the middle above where the fab cond chamber would be if the drawer was in, you will see four small rectangular cut outs, this is where the water flows during the final rinse. Get a medium size cable tie and push it through each of the holes, giving it a wiggle as you push it in (if the cable tie is long enough you will see the end appear at the back of the chamber). This will clear the channel of gung. Replaced the drawer and run a rinse cycle. This will send water through the channels to flush them completely. Hope this helps
Apr 09, 2013 | Bosch Washing Machines
I have a bosch 1200 classix machine and its stopped dispensing water into the fabric conditioner bit
Sorry to ask but have you pulled out the dispenser drawer far enough to be able to just see the softener tray, then selected the (final?) rinse and checked that water is entering the tray? If it isn't there is a fault with the water distribution and an engineer call is required ;-0(
If water is being dispensed it could it be that the conditioner/softener tray is holding the softener rather than letting it be siphoned into the washer by the water, which is not uncommon. If so the softener part needs a thorough clean (see my complete guidance notes below, please)
paying particular attention to the sentences in BOLD ;-0)
Remove the complete drawer. To do this you will have to do one of the following-
  • Top catch- push down the lip/catch at the middle rear and pull the drawer out (that's how our Bosch one is removed)
  • release the catches underneath (our daughter's Indesit) or
  • lift upwards on the tray as it is coming out to clear the lip underneath.
One of these should enable you remove it
(I am having to guess some of the following!)Once out identify which tray is for the conditioner- the others are simply 'chutes' and open-ended.
It will normally have some sort of cover over it which you must remove to expose the little stuck up pipe/tube. On some models there is just a small individual cap over the tube. The tube is down which the conditioner and water should siphon. It is likely to be blocked by 'gunge'- a mix of powder and conditioner. The whole of the tray, particularly this pipe and the bit which fits over it, must be completely clean and clear for it to operate correctly. It is worthwhile checking fairly regularly.
Good luck,
John C
Mar 25, 2011 | Bosch Washing Machines
My bosch excel 1200 washing machine is not taking the fabric conditioner away from the drawer and it not being used in the wash despite cleaning the draw out. why?
bosch excel 1200 washing machine is not taking the fabric conditioner away from the drawer This video will show you how to keep your soap draw clear and how to service the parts
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Feb 20, 2011 | Bosch Washing Machines
When i put the conditioner in the drawer it fills up with water
But the soap the bleach and the conditioner all at the same time in ther hon slot. Just make sure that u had 1/3 of conditioner that is water! to get away from the moldy smell i sai do two wash with bleach and then 2 wash with everything! just make sure u do all of them withouth clouths
Nov 19, 2009 | Washing Machines
Bosch classix 1000 express fabric conditioner won't empty
Get a piece of stiff wire, and make a right angled bend at the end of it, then poke it in all the holes on the top of the soap drawer compartment, this should solve your prob.
Please rate my solution.,
Thanks.
Jul 16, 2009 | Bosch Classixx WFL 2066 Front Load Washer
Only adds water and drains
well. check for limescale in the back. if there isnt any there then call a mechanic ^_^
Jun 25, 2008 | Bosch Classixx WVF 2402 Front Load...
Bosch Classix 1200 washing machine fab conditioner tray (middle) will not empty
check the water in let valve connections and the current over it when it is in the fab cond. cycle. Replace valve if current is on. Valve price range is 15-35$
Apr 17, 2008 | Washing Machines
Conditioner is not used in the wash cycle
I had the same problem with my Bosch Classixx 1200 Express.
It was fixed today & I now know what to do in the future if it happens. The water gets into the soap/ conditioner dispenser drawer via 2 pipes. One points to the main detergent compartment and the other to the pre-wash and conditioner compartments. The pipes become clogged with a type of mould. This meant that in my machine the water was bypassing the conditioner. I had already removed the drawer and cleaned it up and cleaned the jets above with an old tootbrush but it hadn't solved the problem. The repair guy used a cable tie (one of those that is quite firm & will lock) and pushed it up inside the bigger jets. This loosened the black gunge. Then ran water thru from start of the basic cycles and all is now OK
Dec 12, 2006 | Bosch Classixx WFC 2465 Front Load Washer
Bosch Classixx WFC 2465 Front Load Washer Logo
136 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
