GE WJXR2080T2WW Washer Fills with water - then stops
I was given a GE WJXR2080T2WW. It fills up, but will do nothing else. The lid is down. I have tried every cycle. It won't run or even drain. It doesn't make a sound. Any suggestions what this might be.
I got this machine because my old GE WWA8324GALWH kept overflowing. Now I''m wondering whether the problem with the older machine was easier to fix.
Thank you for this site....
Debbie (with a growing mountain of laundry)
    Genius:
  • 1,028 Answers
Older machine would have been easier to fix ..remove front ck small hose to tub left side remove hose and clean crud from end as much as possible if still overflowing replace water level control..new machine may be timer or lid switch not closing properly remove front to acess lid switch on right side
Posted on Jul 23, 2008
I have a GE spave maker Laundry that fills up with water than stops!
GE Washer Not Agitating Repair Guide
www.appliance-repair-it.com/GE-washer.html
If your washer will not agitate or spin take a look at this page GE Washer Not ... If the washer fills up with water then doesn't do anything at all and you do not hear ... if this were the problem, the water would not stop running, over-filling the tub.
GE washer spin cycle not working - ApplianceBlog
www.applianceblog.com/.../217-GE-washer-spin-cycle-not-working
Mar 12, 2005 - 10 posts - ‎3 authors
I have a GE "Spacemaker Laundry" (Stackable) model number ... Today it filled withwater initially then stopped working all together when it ... Bad motor, something jammed/seized up holding the motor back from running?
Jan 10, 2016 | GE Spacemaker Washer and Dryer Electric...
I have a Kenmore 700 series washer and it fills with water then stops. It's NOT my lid switch. I have tried to find someone with the same washer and same problem and can't find nothing. Can someone please...
If you are sure its not the lid switch, then next would be the water level switch. Once the machine fills, it should switch an internal set of contacts to make the washer run. Last and worst case scenario would be a dead motor.
Mar 24, 2015 | Kenmore Washing Machines
My whirlpool thin twin filled with water and stopped!:(
Well if it fills then it needs the lid shut to work. So if the lid is shut it hits a lidswitch and if that lid switch is broken then nothing will work washer wise right? As far as the dryer that may be a blown fuse but nothing on the washer could stop it from running cept maybe a bad cord or breaker.
Dec 28, 2008 | Whirlpool LTE5243D Top Load Stacked...
Washer fills with water, then stops
OBVIOUS REPL LID SWITCH AND SHOULD SOLVE YOURE PROBLEM 100 % MAYBE INSTALLED IN CORRECTLY,, TAKE A LOOK AT YOUR LID MAKE SURE BUMBER IS ON AND NOT TWIKED
Nov 29, 2008 | Kenmore 22422 Top Load Washer
Washing Machines Logo
479 people viewed this question
Top Washing Machines Experts
