Question about Hotpoint Aquarius WD640 Front Load Washer/Dryer
Aquarius a load stopped today, it has drained but cloths are dripping wet, the on/off light is flashing along with the dryer light flashing. I never use the dryer function. have turned on and off but even setting for spin cycle only the same 2 lights keep flashing. Please help
I have the same problem if you find out please let me know...... think may need a new program for machine would be cheaper to buy new one all together
Posted on Jul 24, 2008
Hi, Have a hotpoint WF440, it will only do a short spin, then the lights flash on and off... the water is being drained, but clothes still soaking wet... any advice please.. Des
if your washer drain hose is connected to your sink waste it may be blocked there allso you should check the pump filter may be blocked these 2 things are very common faults as what you have discribed
Sep 25, 2011 | Hotpoint Aquarius WF210 Front Load Washer
Hotpoint Aquarius waher dryer
possible blockage ' filter or could aslo be water coming back from the sink if drain hose too low , you may need to raise this....
Nov 13, 2009 | Hotpoint Ariston Aquarius WD420 Front Load...
Why do the lights just keep flashing?
Try unplugging it and rubbing the plug on a soft dry cloth, static electricity can cause problems.
Try opening and closing door acouple of times, if still no luck , suggest you call engineer
Dec 09, 2008 | Hotpoint Aquarius WD63 Front Load...
Bosch classixx 1000 washing machine - stops on spin
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
Apr 29, 2008 | Bosch Classixx WVF 240S Front Load Washer...
Washer/Dryer not drying
is your dryer a conderser type
does it have a tank that you have to empty at the end of cycles
if it does the filter that condensers the water from drying cycle
if that is blocked it will not work
Jan 25, 2008 | Equator EZ 3710 Front Load Washer / Dryer
Not draining
it will be the pump they have a small fan inside them they get weak and with the pressure of the water they stop spinning which doesnt push your the water through the motor fast enough to drain properly replace and you will see the difference
Aug 22, 2007 | Hotpoint Aquarius WD640 Front Load...
Hotpoint Aquarius WD440 Error
Remove the white plastic cover on the back near the bottom. To the right as you look at it their will be a black concertina pipe with a hose clip on its top edge. Undo this and pull the pipe downwards to reveal the filter. There will be a plastic ball inside (which is supposed to be there) remove this and clear out the cr*p.
Re-assemble as removal.
That should fix it
Jul 26, 2007 | Hotpoint Aquarius WD63 Front Load...
Hotpoint Aquarius WD640 Front Load Washer/Dryer Logo
109 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
