Question about Danby Heating & Cooling
I have a new 30 pint danby dehumidifier and wish to use the direct drain option. I have affixed a (clear) hose to the nipple as indicated in the booklet. the hose is sealed as it must stretch to sqeeze over the nipple. i hit the continuous run button and let it run. my problem is that the reservior fills up with nothing draining into the hose. is there another way water can get into the reservior from the condenser?
Leak inside the room
Posted on Jul 23, 2008
Why does water leak onto the floor instead of draining into the tank?
The hose connector should be capped or a hose connected and directed to a floor drain.
Apr 29, 2015 | Amana D930M 30 Pint Dehumidifier
How to get direct drain option to actually work on my Edgestar DEP700EW dehumidifier?
The outlet is probably clogged with moss or foriegn bodies. Clear the water way.
Sep 11, 2014 | EdgeStar 70 Pint Portable Energy Star...
We have Danby Model DDR557HE-7 and cannot locate our Manual. We need to disconnect hose and have excess water go to bucket. How is this done?? If we had copy of Manual we wld be able to search same...
All Danby dehumidifiers, regardless of the model number operate the same way.
The link below to a 50 pint model should provide all the info you need.
However, I think you'll find that draining into a bucket is not an option. As the hose drain relies entirely on gravity to drain. So, it will not drain down and then up into a bucket. The hose drainage method, is designed to drain into a floor drain or a sump.
Hope this helps you.
Jul 19, 2011 | Danby DDR557 Dehumidifier
Bucket fills instead of going down the drain
You may have an unintentional trap in the line (an up and down up and down. Hose has to lay flat on floor to drain.
Jul 04, 2009 | Danby DDR586R Dehumidifier - 58 Pints...
Watwrleaks out of the bootom of the dehumidifier -
There should be a drain hose to drain water!!Check tank for leaks or obstructions-check that drain isnt clogged!!un clog and clean as necessary!!! Best of Luck!!!!
Jun 24, 2009 | Danby DDR586R Dehumidifier - 58 Pints...
Water will not go down drain tube
Sounds like you have a clog. Either try plunging the drain in the stationary tub or replace the line from the humidifer.. Just a thought
Jun 10, 2009 | Danby DDR586R Dehumidifier - 58 Pints...
We lost the directions for our Danby dehumidifier. The model number is DDR557HE. Serial. No. 0107050701350. Can you help me out. T. MacKay
I had the same problem but was able to find a link from "Danby's" website. Hope it helps!!
Apr 11, 2008 | Danby DDR586R Dehumidifier - 58 Pints...
Danby dpac7008 portable air conditioner
I want to know how these portable air conditioners are supposed to be set up. Do they have to be on the same as the window out of which the hose goes? If the window is 4.5 feet off the ground, does the air conditioning unit need to be put on a table to make it and the window on the same level?
To the best of my knowledge the unit can stay on the floor and included the product features listed below and it does have a dehumidifier reservoir with direct drain and to make sure if you use the drain hose that the hose is higher than the item that you are draining the water into or you can elevate the unit so that the hose can drain outside and out the window - but you can also drain the water into a bucket or some thing that will hold water. I hope this will help you…..
Product Features
picexporterror From our expanded online assortment; not available in all Best Buy stores
picexporterror 7,000-BTU cooling capacity lets you cool rooms up to 250 sq. ft.
picexporterror Electronic temperature controls let you adjust the temperature in 1° increments for precision cooling; 3 fan speeds
picexporterror Dehumidifier mode removes up to 45 pints of moisture in up to 24 hours; 6.3-pint dehumidifier reservoir with direct drain
picexporterror Auto on and auto off timer
picexporterror Overload protection helps protect the air conditioner from power drains and surges
picexporterror Mesh filter is removable for quick and easy cleaning
picexporterror Includes remote
Apr 06, 2008 | Danby DPAC9030 Air Conditioner
Tank still fills when we are using direct drain feature
check to see that the hose isn't clogged, and that the hose runs down hill from the tank all the way to the drain. if it is higher than the tank at any point in its path it will not drain. you may put the dehumidifier on top of a small platform to aid drainage. also check that the knockout removed so there is a hole to let the water go from the tank to the hose?
Sep 24, 2006 | Danby DDR2504 Dehumidifier
Heating & Cooling Logo
163 people viewed this question
Top Danby Heating & Cooling Experts
Level 1 Expert
Dan Webster
Dan Webster
Dennis Boxerman
Are you a Danby Heating and Cooling Expert? Answer questions, earn points and help others
