Question about Sony KP-46WT500 46" Rear Projection HDTV-Ready Television
Sony kp-65ws500 picture trouble
I'm getting a red and green shadow on the picture. Also, around the edges it looks like the picture is being pulled, it is kind of rounded/bowed. i would really like to save the money and fix it myself if possible. please help asap, tv repair man is supposed to come next week and is going to charge almost $400!!!
  • 2 more comments
  • Anonymous Sep 06, 2008
    CMPRESSED CONVERGENCE IN THE CENTER
  • myork101 Sep 12, 2008
    I have the same problem, any solutions?
  • Anonymous Oct 03, 2008
    I have the same problem.
  • yccr1 Oct 07, 2008
    I've got a same problem the colors misalignment after I moved the tv uptair. and in the front of TV it have a door it has some buttom as chanel/volume ajust in the last buttom it has 1 call (FLASH FUCUS) after I press that buttom the picture back to normal, But now I moved down stair and it happen again and I try to do flash focus but it can't fix the align focus.
  • Sony Master
  • 3,459 Answers
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projeciton sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems.
sony kp-65ws500 picture trouble - e87380c.jpgsrc="http://i.fixya.net/uploads/images/e87380c.jpg" alt="e87380c.jpg" class="h_mi" />
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fisony kp-65ws500 picture trouble - 69189a5.pngelow for a fix
69189a5.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you are handy and can follow directions. You can get complete repair kits from TvRepairKits.com or click here. They have put together DIY repair kits that include the OEM parts and step by step photo instructions for each repair. If you are not handy or can't follow directions we would suggest calling a shop.
Posted on Jun 06, 2010
My sony kp 65ws500 has a all red picture. It looks fine otherwise. nothing i have tried has changed the color of the screen at all. Please help.
Tv have a problems known as a convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors pictures shadows or 3D pictures look alike?Yes.The tv convergence board it dead.The tv convergence board must be replacing the 2 STK convergence ICS and some or all of it resistors too.To fix the tv convergence board to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Mar 02, 2011 | Sony KP-65WS500 65" Rear Projection...
Red and green color separation mostly on the left side
The tv have a problems known as a convergence problems,it dead.Any colors lines R,G,B mis alignment,have colors shadows picture or 3D pictures.The tv convergencce board require changing 2 STK convergence ICS and some or all it resistors are dead.These parts nust require changing to solved convergence problems.The shop,will cost $300-350 for parts and labors.
Sep 11, 2010 | Sony KP-65WS500 65" Rear Projection...
Kp-65w500 green flash... led blinks 8 times
I am going to guess that model number is actually KP-65ws500
This is one of group of Sony sets that had bad picture tubes---red, green, blue----the tubes are no longer available and can only be obtained by removing the bad one and sending it out for rebuild (very expensive)
There is one easy thing you may be able to do to correct this problem---It involves no replacement of parts and is just adjusting the Green screen control---usually if this is the case when set comes on background will be somewhat (in your case) green---best way to see this is turn set on and have it on a unused video input---if screen appears somewhat green and has curved retrace lines--you may be able to turn the Green screen control down and continue to use the set---set will shut down if any of the 3 picture tubes pulls too much current--ie--goes to bright green, red or blue.
Let me know if you want to know how to attempt this
SD TECH
Oct 03, 2009 | Sony KP-65WS500 65" Rear Projection...
I have a sony projection tv KP-46WT500 and have red/green shadows around the people plus some double word image that are red & green. On the tv guide the station #'s are double and green and red.The...
Replace Both of your convergence ICs STK392-??? they are big black ICs will have part number on them also CK pico fuses they look like resistors but are fuses they will be yellow or green will be around ICs.
Aug 08, 2009 | Sony KP-46WT500 46" Rear Projection...
KP_65WS500 Tube numbers
Here is the part number for the blue tube B 07MVC61, the Red is R 07MVC61, and the Green is G 07MVC21. The number to contact the company that makes the tubes is 1-800-241-5005 Ext 143
Jun 15, 2009 | Sony KP-65WS500 65" Rear Projection...
Sony kp-48s75, shadow or ghosting picture
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer2_bing.gif Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.png http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 07, 2009 | Sony KP-48S75 48" Rear Projection...
Blue shadows
Sony Too green,red or blue
http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
Nov 25, 2007 | Sony KP-53HS10 TV
Sony 65 Inch Projection TV Color Red Green Separation
Sounds like a convergence issue. Call Sony for an ASC that can come out and give you an estimate. You are probably looking at $200-400 to do the repair.
Nov 02, 2007 | Sony KP-65WS500 65" Rear Projection...
Sony KP-46WT500 46" Rear Projection HDTV-Ready Television Logo
99 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
