Question about Eureka Vacuums
The power wand electrical connection on the power unit itself seems to be corroded. I think I need a new two wire plug to plug into the wand. the model is a Eureka 6984 A. I am able to disassemble the power unit if necessary and replace the wire and plug if one is available
Try hesco inc they have a on line store with all the vacs parts diagrams and fast shipping.
Posted on Jul 22, 2008
Beater bar turning on and off. Why doesn't the vacuum?
Try wiggling the wire and where the hose swivels to attempt to determine where it may be shorting out. It could be the wire or the plugs where the wires connect if your model has them. Inspect these areas closely to find your short.
Apr 08, 2016 | Kenmore Vacuums
The power brush on my Kenmore canister vac #116 2761 works intermittently Depending on how I hold it. Seems to be a problem with the contacts on the wand????
all you can do is clean them contacts that you see on the wand
use wd40 .
an a brillo pad or such.
look at the female connector on the end an see if u can tighten an clean it .
Jan 04, 2015 | Kenmore Vacuums
I have a Kenmore 11659812991 canister vacuum. The carpet cleaning accessory that has the spinning brush turns off and on - seemingly randomly. I took it apart and did not see any loose connections (I
There is an electrical connection at each end of the wand, it could be any of the electrical connections. Could be a bad wire from the lower connection into the vacuum
Dec 27, 2013 | Vacuums
I have a CT600 power brush that would not power up. Thinking the motor was bad in it, I replaced it with a new CT700 power brush, I am still experiencing the same problem the power brush itself does not...
First try connecting the power nozzle directly to the hose. If it works, the problem is due to a broken wire or faulty connection in the wands. At least one wand will need to be replaced.
My guess is it's probably due to a broken or disconnected wire. This could be in the hose (most likely), the wands, or the tank wiring itself. You can test the hose wiring by using a multimeter or continuity tester. A tester may be easier for you to use, and will provide the info needed.
Disconnect both ends of the hose, sit down, and lay the ends on your lap. Touch one end of the probe to a terminal on one end of the hose. Place other probe on a connector at the other end. One connector will light, the other won't. Now repeat with the other terminal at the first end of the hose and repeat. The terminals will read opposite the reading in the first test. If the light fails to turn on with either test, it's a broken wire in the hose. This is most likely near/at the handle end, or at the wall end. In some cases it can be repaired, but not always.
It could also be due to a faulty switch.
For a definite diagnosis, take the unit, the hose, power nozzle etc. to a repair center.
Jan 28, 2011 | Broan-NuTone VX550 Bagged Central System...
It stopped working while I was using it . I tried to plugged in different electric outlets but it still dead. What should I do or look into in order to get it back to normal?? thanks
I would start by taking the wand apart. Be sure vac is unplugged from the wall outlet! You should be left with two pipe pieces, and the beater bar. I would also pull the hose from the canister unit itself. Once all the pieces are pulled apart, check the two or three prong wire connectors on each piece, both the female and male ends. If you have any dielectric grease, use a dab on each electrical connection. Once you reassemble, and still not powering up, wiggle the wand back and forth at the connection near the canister, and after the hose near where the switch is. If the vac cuts on after wiggling it, then you have a loose connection, and will need to tighten the female ends on the electrical connections, by squeezing them together slightly with a pair of pliers. Please rate if this works or does not work. Thanks!
Jan 03, 2011 | Kenmore 23612 Progressive PowerMate Bagged...
Power Head keeps cutting in and out while vacuuming???Canister motor keeps running but the power head starts and stops like there is a short or some loss of connection somewhere. Any ideas?
The electrical terminal at the top of the extension wand may be loose or corroded. Unplug the vacuum and remove the wand from the hose assembly. Look at the 2 prongs and clean off any corrosion using a a Q-tip or scrape with a screwdiver if it's more persistent. After cleaning reconnect the wand to the hose and try it again. If the prongs are not corroded, they might be loose instead or they might not be aligned properly. If this is the case then bending the prongs very slightly may help realign them. The part that may be giving you the trouble is called the terminal cover (PN 8191782). It costs about $10 but the problem is knowing the procedure to actually replace the part. CAN ANYONE EXPLAIN HOW TO OPEN UP THE EXTENSION WAND TO REPLACE THE TERMINAL COVER ??
Jan 14, 2010 | Kenmore 23913 Progressive PowerMate Bagged...
When running the 2100 Electrolux vacuum, it is stopping and starting when pulling or pushing the floor attachment. Seems like the connection at the top of the handle is a little loose or the electric tabs...
Depending on the age of your 2100, you will need to replace, the wand cord, the handle wiring and perhaps theh upper wand inner tube and handle as well.
If you examine your cord contacts they will be blackened from slippage, so will the female socket they plug into. On and aging 2100 the 1/2 inch groove at the front of the chrome handle tube begins to wear and the metal inner tube clip under the thumb button of the wand develops play back and forth. The wand comes apart into 4 pieces, plastic sheath, upper and lower tubes and cord assy.
If the hose handle groove is worn enough to allow in and out play, you will need to replace the handle, it's wiring, and at least the clip button on the upper wand as well as the wand cord.
You will find these wand parts at a pro vacuum shop but if your hose is original you will need to go to an AERUS Electrolux repair center for parts.
Post back with your results.
Nov 22, 2009 | Electrolux UltraLux 2000 Bagged Canister...
Just bought new power head electrolux guardian and
Did you get new wands with the power nozzel? The wires that power the nozzel run through the wands from the hose to the nozzel.The connectors at the end of the wires are fomous for getting too big and making a bad connection. This causes the on/off problem. This will only get worse if you continued use. The wires in the hose handle, the hose and the power nozzel elbow can all be changed out. You will not have to replace the hose handle or the wands unless the plactic has been burned. (A loose electrical connection causes heat). Take your hose,wands and nozzel to the shop for repair. Don't let the sales/service manager tell you that you need new parts until you can see the parts are bad. I think they saw you comming when they sold you the new nozzel.(just my opinion)
Oct 15, 2009 | Electrolux Guardian Bagged Canister Vacuum
Filter Queen Powerhead Not Working
is it the part where the hose connects to the wand or is where the wand connects to the power head? and what side keeps falling out. it sounds to me that its either a hose or a wand issue. unfortunatly the cord itself cannot be replaced and if the problem is a worn out connector in the hose which is possible it would require a replacement hose and if it is on the wand end it would require a new wand. either are fairly cheep on ebay. or you can possibly find one used at a local vacuum dealer. dont buy new. save yourself some money if possible.
Jul 22, 2008 | Filter Queen Majestic Canister Vacuum
Vacuums Logo
109 people viewed this question
Top Eureka Vacuums Experts
charlesjo336
Level 1 Expert
JoeVacs
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
