Question about Smeg FAB32 Bottom Freezer Refrigerator
How to defrost?
How do i defrost my freezer as cant even open the top freezer shelf now as all iced over please help
  • 143 Answers
Unplug the machine, open the doors, and wait until the ice melts. Using hot water speeds things up, but it's awfully messy.
Posted on Jul 23, 2008
Water dripping inside KTLA22EMSS01
Your freezer actually cools your fridge. It sounds like you have ice build up in your freezer behind the back panel. You should be able to unscrew the back wall inside your freezer. A hair dryer should help defrost or keep it open for a few and use a screwdriver to remove the build up of ice. The ice has made its way down the vent and when it hits the fridge it is above 32 degrees so it is melting. Hope this helps. I manage rental properties and have had it happen on a few occasions.
Aug 16, 2012 | KitchenAid Refrigerators
Why is my ge refriderator "frost-free" freezer frosting up?
most likely the defrost heater behind the panel thats frosted up is burned out so it cant defrost the unit,g.e. is notorious for this,remove this panel inside the freezer and remove 2 screws at the bottom of the evaporator coil holding the heater to the evaporator and unplug it the new part number is g.e. WR51X10055
Jul 23, 2012 | GE GSH25JFT
Water collecting on top shelf of refridgerator
Your defrost drain line in the freezer has stopped up. The defrost water is coming in through the air vent to the fresh food section.
Turn the unit off and use a hair dryer to defrost the drain hole located behind the freezer panel.
Jun 21, 2011 | Kenmore Top Freezer Refrigerator
Water on the top shelf of the refrigerator
Your defrost drain is clogged and now the defrost drain trough has filled with ice causing the water from your defrost cycles to flow into the fresh food section. You will need to clear all ice form thr drain area and this is done thru the freezer wall and some models also have a removable bottom panel in the freezer that has to come out also to get to the drain. You can do this it will just take a little time. About an hour for a first timer with little experience. Good luck and hope this helps
Feb 02, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
Water dripping from freezer onto top shelf of fridge with ice buildup back of freezer
the defroster isn't close enough to the drain to be effective. remove the back wall of the inside of the freezer, remove the excess ice. clear out the ice from the drain using hot water and a turkey baster. there is a kit from whirlpool that uses a piece of metal and a screw around the defrost rod, but I found out that a piece of 14 gauge solid core wire with the insulation stripped off works great too. stick the stripped wire into the drain, 2 to 3 inches, and wrap the rest around the defrost rod.
Jun 02, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Water build up in the freezer
When your refrigerator defrost the condensation has no place to exit to because of a restriction in the drain and that could be water that has turned into ice or possiably a food partical or foreign object. Defrost it compleatly by leaving freezer door open for aprox. an hour at least make sure ref is level front to back an d you should not have this problem anymore. Please rate me and let me know if this helped. Thanks
May 22, 2009 | Kenmore 73262 / 73264 / 73269 Top Freezer...
Bottom drawer wall is covered s ice/ top shelf not freezing
Sounds like a defrost system problem. Could be related to defrost timer, heaters or defrost thermostat. Have it serviced.
Jun 09, 2008 | Frigidaire 14.1 cu. ft. Upright Freezer...
Constant build up of ice on the freezer lower shelf
sounds like you have a clogged defrost drain tube. removing back panel of freezer will give you acess to drain trough, melt away the ice with a hair dryer, youll find a drain hole under there somwhere,pouring boiling water down the drain will clear it pretty quickly( i use a steam machine purchased from the infomercials works awesome, after you clear it and all water drain down tube wrap a piece of solid copper wirearound the heater( black calrod heater right above the drain trough) and stick it in the whole maybe an inch or so. now everythime the heater comes on to defrost it will prevent the hole from freezing over
Mar 01, 2008 | Kenmore 72073 Top Freezer Refrigerator
Hotpoint FFA70
Remove the plastic venting box which feeds cold air over the top of the freezer drawers,There are 4 hexagon headed self tapping screws,two at top.and two bottom.Now defrost all ice off rear of freezer and back of vent box.Now replace and door will shut with draws in.Make sure no ice left round fan housing.
Jan 21, 2008 | Hotpoint FFA70 Bottom Freezer Refrigerator
Whirlpool refrigerator with top freezer either model GR2 or 9FHTXT will not keep get cold
Sounds like the defrost drain has become iced over or clogged. This is why the ice builds up.
Jan 14, 2008 | Refrigerators
Smeg FAB32 Bottom Freezer Refrigerator Logo
369 people viewed this question
Top Smeg Refrigerators Experts
John Tripp
John Tripp
Michael Galve
Michael Galve
ashburton
Are you a Smeg Refrigerator Expert? Answer questions, earn points and help others
