Question about Trendware TEW-424UB (0710931502572) 802.11g/b Wireless Adapter
Little or no connectivity
The green light comes on. The two "horizontal thermometers" indicate a good signal is being acquired but the message "little or no connectivity" appears. I know that the thing is capable because I had a TEW 229UB before this one that my 2-year old grandson demolished. I have tried disabling the Windows Zero Wireless configuration service to no avail. It will not connect to the Internet.
  • 1 more comment
  • izla030 Dec 15, 2008
    I have also the problem with connectivity to optical modem. Before that the connection was OK and suddely I can not connect. The reaason is the modem does not deliver the IP address. I use WPA encryption.
    Best regardds,
  • Anonymous May 21, 2009
    I have been using my TEW-424UB and it was working just fine. Now it shows 100%connectivity, has the green light turned on, but it does not give me an internet connection. Whats wrong?
  • Hollyecho Montgomery
    Hollyecho Montgomery May 11, 2010
    Do you have a WEP security key enabled on your wireless router?
No - the WEP security key is not enabled as far as I know. I'm not sure how to do that on the host computer
Posted on Jul 23, 2008
I've got a Scanport H21 monitor that the green light comes on but has a black screen. Can not dring up a menu or "VGA IN" message.
I am in computers. This is either a #1. display that is going out. #2. the video card fails some times, #3. or the monitor is not plugged in all the way. #4. The VGA cable is not firmly attached to the Momputer/monitor. Your VGA IN message that the computer does not have its signal to the monitor that the connection to the computer is good. God Bless
Apr 16, 2017 | Scanport H21 21" LCD Display Monitor
You can try a different cable for VGA. Check if the port is lose. The green light is only indicating a proper power supply to the monitor. The display is very much dependent on the VGA cable. If your monitor also has HDMI port, you can try to connect using that cable (provided the display adaptor also has HDMI port). If nothing works for you, take it to a hardware engineer or local repair shop.
Jan 20, 2014 | Scanport H21 21" LCD Display Monitor
The picture is distorted by both vertical and horizontal lines (different colors; pixelated)
A distorted picture display soon after the Plasma TV is powered on has two indications. First, a picture display of pixels when the TV is powered on is usual prior to signals of video movies are acquired from broadcasting station. The movie from braodcasting station should display without noticeable objects of distractions. For example, the movie displeyed on the TV without obstructions is indication that the problem is from the display set. Alternately, movies with poor capability to display on the set is indication that the media from which motion pictures are acquire from is malfucntioning. For example, a TV connected to cable network or disk network or satellite broadcasted signals with receptive compromises are diagnosable from two areas. First, a clarification from the network station that has setup connectivity of devices. Perhaps a device in the setup is malfucntioning. Second, attempting the adjust the phsical connections that are attached to the TV is capable of resoving the problem. Refer to the user guide for what is default expectation on powering on. Thereafter consul technical experts if required. Good luck
Jan 08, 2011 | Philips 42PF9630A 42 in. Plasma Television
Pc turns on, but that is as far as it gets, nothing eles happens, help
You need to be a little bit more specific. Please indicate what happens after you turn on the PC. Is the LED on the CPU green? Is the monitor light green when you turn on the PC? Are there any error messages on your screen? Also, are there any beeping sounds coming from the PC?
Dec 08, 2010 | Computers & Internet
I turn on the camera, (S2550) and the green light indicator comes on. THen the green light changes to orange. THe display screen is black even when I press the button to take a picture. No picture...
With the orange light being on that means that the battery is not connecting properly or that it needs to be replaced. The first thing that you can try is a little rubbing alcohol on the connections of the battery itself and the connections inside the camera where the battery terminals connect. If that does not solve your issue then you will need to replace the battery
May 29, 2010 | Fuji FinePix S2000hd Digital Camera
Model # PTH5498 Red and Green horizontal lines show up after the set has been on for a little while. They don't stay but come and go
If it is being fed by a component video source you could have a loose connection. Component sends analog video signals via Red Green and Blue cable. If the blue cable is loose then you will generally get a redish or greenish looking picture. If the cable isn't the problem try using a different input such as the S video input. If this still doesn't fix the problem then you could have a problem with one of the lamps most likely the blue. Hope this isn't the case for you though.
Feb 08, 2010 | Akai PT5492S 54" Rear Projection...
I own a 2007 Fatboy. My left rear turn signal
Turn on the good indicator - find where the clicking comes from, this is the flasher unit - pull it off (little box 4/6 pins) and get a replacement, that should fix your problem 1st time. A good harley dealers should stock the flasher unit but you may have to wait a few days for order at smaller establishments.
Jan 27, 2010 | Harley Davidson FLSTF Fat boy Motorcycles
How does the temp gauge work on these cars
with my 2000 echo when you start it a blue temp gauge looking like a thermometer shows when car warms up it goes out indicating it is warmed up....If the red one comes on after driving for a while it is telling you car is overheating very simple but very effective once you know this
Dec 26, 2009 | 2001 Toyota Echo
Electrical problem. Turn signals, brake light.
with the snals not flashing it might ne the indicator relay, with the front brake light check he wires on the switch just under the front bkake lever
Oct 18, 2009 | 2001 Honda CB 125 T
Driver side signals only work when headlights are OFF
What may have happened is either the headlights wiring or the parking lights wiring somewhere along the wiring fused to the left turn signals wiring. Depending on if the turn signals go on when you put the parking lights on or the headlights on.
If the signals come on when you turn on the headlights than you only need to locate the light green wire that comes off the left turn signal harness.
Next follow that wire the entire way back to the firewall looking for another wire fused to that wire as you go.
If there are no signs of this you need to continue looking on the other side of the firewall all the way back to the turn signal and hazard flasher unit which is a black box that connects to a black harness located next to a grey harness behind the knee bolster.
But if the signals come on when you turn on the parking lights than you will also need to check the wiring from the rear left signal and follow that light green wire all the way back to the turn signal and hazard flasher unit.
This should fix your problem, but if not than your problem may lay within the the wiring between the turn signal/hazard switches and the turn signal and hazard flasher unit.
Also you may have a burnt circuit in the junction block. This block is where the light green from the rear left signal and front left signal meet. Don't have a description but if you cannot find it let me know and I will go out to the yard and look myself and let you know.
Apr 22, 2009 | 2004 Dodge Intrepid
Trendware TEW-424UB (0710931502572) 802.11g/b Wireless Adapter Logo
377 people viewed this question
Top Trendware Computers & Internet Experts
Michael Galve
Michael Galve
Prashant M
Prashant M
Are you a Trendware Computer and Internet Expert? Answer questions, earn points and help others
