Step 1: Check the sim tray or sim seater to see if it it broken, if it is, replace it Step 2: If the sim seater/tray is not broken, clean the entire terminal. Step 3: If the sim seater/tray is not directly on the board, trace the broken led and solder it, or you replace the broken led with another sim tray. Step 4: If it is still not working, change the battery and put a new battery, because a virus infected battery will always give such problem. Step 5: Finally, if the problem still persist, then check the sim card and replace with another sim card if the former is bad because a bad sim card will always display such message as insert sim card or sim card error.
Hi! The phone might have been black listed (blocked) or you might not be inserting the sim card correctly. To find out if your phone has been blacklisted then you could ring up your network provider and give them your phone serial number and they should be able to tell you straight away. There could be a problem with the connection port of the sim card. I hope I have been of help but please do not hesitate to ask if you have any further questions. I appreciate your vote if you appreciate my reply
Either your sim card is faulty, or more likely your handset is network locked.
You will need to either purchase a new sim card (if sim is problem) or obtain the network unlock code for your phone.
You could try to remove your sim card.
Install battery and turn on phone without sim card.
Use phone without sim card and do some operations.
This will check if you phone is working correctly.
Turn phone off and install sim card.
Made sure sim card is install correctly.
If this does not work, it could be the sim card is bad.
hi bro ,
Your phone is SIM-locked to a specific service provider's SIM card. You have inserted a SIM card that is not supported.
This is happens when you buy the phone from an operator. SIMlocked phones can be unlocked - contact your service provider for more information.They will give u the unlock code for free of cost after a few verifying question to ensure that you are so and so .You should be able to give them the details
For any quires write back to . If u are satisfied with the answer please vote for me (with atleast 3ups) .Thanks in advance
Hi, How to correct sim card error / insert sim card
Procedure to follow
Procedure to follow
It's possible your phone is locked to a specific sim card. If you got that phone from a telecommunications company for example AT&T, you will have to contact them..
have you also tried other sim cards on your phone? just to rule out if it's a problem with the sim card or the phone..
it could be that the contacts between the phone and the sim card are dirty and therefore you will get the error code. take the battery out and remove the sim card take a q-tip with some rubbing alchohol and clean the contact on sim card and the phone itself make sure not to use alot of alchohol. let them air dry then re-insert the sim and battery this should do the trick. the error warning should go away and the phone will be abale to receive the contact info from gthe sim card.. please rate this
