Question about Proscan 42LA30H 42 in. LCD Television
Proscan Television When going to the menu, the choices are limited. On the setup, there is no icon for tv . Also, can't display close caption. Mike
Operator erra.
Posted on Jul 23, 2008
Don't know how to activate closed caption, and cannot find instructions
What is the TV source? For some sources (set top box), you may need to turn on the captions using the menus of the box.
Assuming you are using a source that gives captions that the TV can interpret, if you have the Proscan 26LA30Q remote, press the CC button to toggle through the caption options. Another route is to press Menu (either on the remote or the buttons on the side of the TV) then select the Feature submenu with the left/right arrows. Press Enter (menu when you use the buttons on the TV) then navigate to the Digital Closed Captions option. Here you can set the captions to on and adjust the size, style and color of the captions when they appear on-screen.
If you are using a universal remote, try the CC button. If it doesn't work, try another code for the Proscan TV on the remote. There are some codes that may not control all of the functions of the TV with the remote.
Crutchfield has the manual for the TV on the product site: http://www.crutchfield.com/S-Kaec3gBqVtM/p_68326LA30Q/Proscan-26LA30Q.html . The direct link is http://a248.e.akamai.net/pix.crutchfield.com/Manuals/683/68326LA30Q.PDF .
I hope this helps
Aug 18, 2011 | Proscan 26LA30Q 26 in. LCD Television
Sharp Aquos LCD TV 52"
Does your cable company support CC?
Apr 08, 2008 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Tip
HDMI Closed-Captioning won't go away
I bought this television yesterday, bought the HDMI cord and hooked it up through my Comcast digital cable box. Every channel would display closed captioning, despite it's supposed inability to support that function. In order to remove it, we had to turn off the cable box's ability to display closed captioning. To do that, turn off the cable box and hit menu to get to the setup menu. It is there that you will be able to turn off closed-captioning.
on Jun 16, 2007 | Sylvania 6626LG 26 in. LCD Television
ProScan Model 40LC45S There is a black box in the middle of the screen only on one station. How do we make this go away?
This is a text box and is part of the closed captioning features your television has. You would have to turn closed caption off completely on your television. There should be a cc button on your television remote or in the television menu there should be a closed caption sub category you can go to and select off.
Jan 07, 2011 | Proscan Televison & Video
How do i enable the closed caption on my samsung tv/direct tv?
Correct solution WITH DIRECT TV is NOT going to SETUP MENU on your Samsung TV and enabling it, this won't work with Direct TV!! I'll walk you through it. Grab your Direct TV remote, hit "Menu", pan down to "Parental, Fav & Setup", next click "System Set-up", next click "Display", now at the top of the screen between "Preferences" and "Clock" is "Captioning", click on it, now the first box reads Captioning TURN IT FROM OFF TO ON! You now have Captioning.
Aug 05, 2009 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
How to activate "closed captioning" for a Proscan Full HD 1080P
Comcast's remote has nothing to do with closed captioning. It's on your tv remote. First, the tv has to be capable of handling closed captioning, and your's is- and second, the program must have closed captioning provided- current programs do, some older shows do not support closed captioning. Recheck your remote, and if necessary- look at the setup instructions that came with the TV- they should also be posted online at the Proscan support site.
Mar 26, 2009 | Proscan 26LB30QD 26 in. LCD HDTV
Can't get closed caption
Press the menu button on the front panel of the tv or the remote control. Use the up and down arrows to find the features section.Press the right arrow to enter the sub-menu for the features section. Use the up and down arrows to find the closed caption section. Press the right arrow to enter the closed caption sub-menu.Used the up and down arrows and the enter button to go into each of the features, use the right and left arrows to adjust each control for you preferred viewing.Press enter again to select the feature in each of the controls.When you are satisfied with you selections press menu to exit the feature. This information can be found on the PROSCAN website in the customer section under manuals. Go to www.oncorpus.com.the information can be found on pages 21 and 24 of owners manual for your model television.I hope this information helps you with your problem.
Feb 08, 2009 | Proscan 32LA30Q Television
Can't turn off closed caption & not its not on the TV menu
I went to menu, special features. then select analog CC and selected OFF.
Dec 27, 2008 | Vizio P2 42 in. HD-Ready Plasma Television
Closed captions
In all situations I've seen:
A) It's an option on your cable/satellite box.
B) It's a broadcast signal and it's in the TV menu.
Sep 02, 2008 | Proscan Televison & Video
Cant get rid of captions
look on top and behind of the monitor you will find buttons for your TV then follow this steps: The Setup menu lets you configure the TV to fit its surroundings and your preferences. To access the Setup menu, press MENU, and then select Setup from the Main Menu.closed caption options are: CC Setting Lets you choose the way closed captioning information appears on the screen. Off No captioning information displayed. On Always Captioning information shown always, when available. On When Muted Displays captioning information, when available, whenever the TV?s sound is muted by pressing the MUTE button. The captioning information is not displayed when the sound is not muted. Make sure all of the options for closed caption are off press exit and you are good to go.
Aug 23, 2007 | iLO 3200 32 in. LCD Television
Proscan 42LA30H 42 in. LCD Television Logo
50 people viewed this question
Top Proscan Televison & Video Experts
matt martin
matt martin
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
