Question about Sony Xplod Car Audio CDX-F7810 - CD/MP3 Player CD Player
Radio installation in a golf cart
I just bought a sony cd car stereo to put in my golf cart. I was curious to see how I might wire this. It is a 36 volt cart, so there are six batteries. Do I just run the red/yellow power wires directly to the positive post of the first battery and the black ground wire directly to the negative post of the second battery?
Each battery is 6 volts. You would have to connect to the 1st Battery 12 volts posiltive {+} side and the 3rd battery negative side[-]. Run the positive lead thru an inline 10 amp fuse , then to the radio.
Posted on Aug 17, 2008
How can I Speed up my 2004 Yamaha 36 v golf cart short of changing motor
If you are getting full voltage to the motor and that is the best you can do, then you have no recourse other than to change the motor.
Mar 31, 2017 | V Golf Golf
Wiring diagram for EZ-GO Marathon 36 volt golf cart
Excellent......asking for a Golf Cart wiring diagram in a Water Heater posting board....
Works for me
I have a Westinghouse Nuclear Reactor I bought used from the USN. Can you tell me where I buy the Heavy Water for it????? Kroger? Safeway? Whole Foods?
Oct 20, 2014 | Water Heaters
I have a stereo in my golf cart 48 Volt system If I push on the peddle to go the stereo shuts off when I let go it turns back on what could be the problem?
not knowing how or who installed the radio you could try the following
Is the radio 12volt ??, if so is it wired to one battery or running through a voltage reducer ??
if wired to one battery ( this is not advised as it should be wired through a voltage reducer) is the battery ok (load test battery)
If wired through a voltage reducer simulate driving then measure output voltage,, voltage should be equivalent to or slightly above accessory input voltage
Sep 26, 2012 | Car Audio & Video
How to wire a stereo into a G1 yamaha golf cart
all you need is a live wire which may be a switched live or a permanent live directly from the battery( switched live means the wire becomes live when you turn the ignition key) The chosen wire must be connected to theb radio via a 3 amp line fuse
Jun 26, 2012 | Yamaha G1 G-1 2-cycle Gas Golf Cart Tune...
Golf Cart (Gas Powered) Stereo Installation
What I did was to buy a good blue tooth speaker and connect to my cell phone. 3 hrs on the golf course and 10% of the cell battery
Jul 06, 2017 | Cars & Trucks
Anyone have the 2001 VW Golf speaker wire colors?
If your Golf is the premium sound model here is the list:
2001 Volkswagen Golf Car Radio Wiring Schematic for Monsoon Audio
Car Radio Battery Constant 12v+ Wire: Plug #3, Pin #7
Car Radio Accessory Switched 12v+ Wire: Plug #3, Pin #4
Car Radio Ground Wire: Plug #3, Pin #8
Car Radio Illumination Wire: Plug #3, Pin #6
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Plug #2, Pin #5
Left Front Speaker Negative Wire (-): Plug #2, Pin #6
Right Front Speaker Positive Wire (+): Plug #2, Pin #3
Right Front Speaker Negative Wire (-): Plug #2, Pin #4
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Plug #2, Pin #7
Left Rear Speaker Negative Wire (-): Plug #2, Pin #8
Right Rear Speaker Positive Wire (+): Plug #2, Pin #1
Right Rear Speaker Negative Wire (-): Plug #2, Pin #2
Signal for Anti-Theft Alarm System Wire: Plug #3, Pin #1
Data Link Connector (DLC) K-Wire: Plug #3, Pin #3
Battery Supply Constant 12v+ Wire for Anti-Theft System (SAFE): Plug #3, Pin #5
CD Changer Data In Wire: Plug #1, Pin #13
CD Changer Data Out Wire: Plug #1, Pin #14
CD Changer Clock Wire: Plug #1, Pin #15
CD Changer Constant Battery 12v+ Wire: Plug #1, Pin #16
CD Changer Control Signal Wire: Plug #1, Pin #17
CD Changer Ground Wire: Plug #1, Pin #18
CD Changer Left Line Out Wire: Plug #1, Pin #19
CD Changer Right Line Out Wire: Plug #1, Pin #20
May 18, 2010 | Car Audio & Video
Golf cart radio, sound dies when running, sound comes back stoppi
Enrique - I am having he EXACT same problem w my golf cart...did you ever solve this? jonthebickford@gmail.com
I am sure its because of the electric motor - thinking a monster electrolytic capacitor across the positive/negative wires of the radio could solve the problem - just wondering if you ever found anything out?
May 09, 2010 | Clarion DXZ745MP CD Player
Diagram on what wires go were for 2003 chevy cavalier / gm radio interface to sony xplode cd player
Car Radio Battery Constant 12v+ Wire: Orange
Car Radio Accessory Switched 12v+ Wire: The radio harness does not provide a switched power source. Run a wire to the fusebox for switched power.
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Gray
Car Stereo Amp Trigger Wire: Pink
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
Apr 29, 2009 | Car Audio & Video
Wiring diagram
dave, the link below contains electric golf carts wiring diagram, one here is almost the same with your 08 Precedent like the one below.
good luck
Wiring diagram
Jul 24, 2008 | Car Audio & Video
3,032 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
