Question about Maytag Neptune MAH5500B Front Load Washer
Bearing Sounds like a bearing going out. Very noisy when spinning. How hard is this to change
  • 1 more comment
  • reneeadukes Jul 23, 2008
    Sounds like an airplane during the spin cycle.....was told it was a bearing problem, but would be 381.86 to fix.
  • rds95991 Jul 25, 2008
    Same here.
    I'm going to run it until it won't and then replace it. I just replaced the matching dryer I had purchased at the same time..
  • cabernetguy Aug 06, 2008
    My Neptune has always been noisy during spin cycle. I sometimes leave the area, and we have a door to the laundry area. Now, it sounds like it is ready to come apart, is spewing brown rusty fluid, is out of sync spin wise, leaking this fluid on the floor, is making metal on metal noise, and towels have been smelling moldy for quite a while.
    We had the previous problems with mother board and mold due to gasket repaired, finally, but thinking maybe best to just landfill it and go back to reliable top loader. I am sure any service call will be several hundred dollars with no long term guarantee. Though a new unit won't look nice and match our (trouble free) Neptune dryer...oh well. I'd rather spend the money in other fashion.
    Bottom line........like so many posts........Maytag has bottomed out. I am certain the Maytag repairman now wishes he had gone to law school.
  • 639 Answers
Dear friend,
ngfam at you service!
The Neptune was discontinued for 98 design defects!!!!!!!!
You can not fix this problem your self!!!
This sounds like it will only fixed by service then you will be happy again!!
Yes sounds like you need service!
Call A&E Factory Service /They service nation wide
And are available 24/7 for making appointments!
If the appliance is 10 years old or more,it may make sense not to invest any money to fix it!
BUY SPEED QUEEN NEXT TIME AND HAVE IT FOR 25 YEARS! THAT'S WHAT I HAVE!
Happy to assist you,
PS. PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF!
Neil
Posted on Aug 26, 2008
  • Unplug Neptune, Disassemble front of machine, Remove rear access plate
  • Carefully slide belt off of large pulley as you slowly rotate pulley
  • Remove large pulley bolt (9/16" ratchet) and pull pulley
  • Use a large rubber hammer and carefully pound out the spinner shaft / inner tub assembly
  • Pry out the old seal and plastic white clip on the inside of outer tub
  • Clean up the front bearing using a drill powered wire brush and clean the weep holes
  • Spray penetrating oil on front bearing and Remove "C" clip on back side of outer tub (note: newer models may not have "C" clip)
  • Use puller to remove the rear bearing first
  • Pull out spacer and clean it up using the wire brush
  • Clean the rear-bearing race with the wire brush
  • Knock out front bearing
  • Clean the front bearing race with the wire brush
  • Clean out all of the weep holes and remove the seal off of the spinner assembly and clean bearing areas with the wire brush
  • Add lots of grease to both bearing races and Install rear bearing first
  • Install the spacer and front bearing
  • Wipe off the excess grease
  • Install "C" clip (if you took one off) on front bearing
  • Install plastic clip on front bearing (only goes in one way)
  • Install some silicon sealer around the front bearing race (if pitted)
  • Install seal kit
  • Split seal by pulling on it
  • Push removed seal piece onto the spinner assembly shaft position should be the same as you took it off of the other half and move onto spinner shaft so it mates up just like it was before you split it.
  • Install inner tub & spinner
  • Reinstall the pulley using the new bolt and washer that's included in the seal kit
  • Reinstall belt
  • Reassemble remainder of machine With these steps you can replace your Neptune bearings and save some serious cash!
  • Posted on Aug 26, 2008
    Kenmore oasis washer noisy when spinning
    Hi, your probably right about the bearing its usually hard to tell untill they have compltely gone have you tried turning the drum by hand to see if it turns smoothly if it does then it could be the motor thats noisy both can be replaced but the drum bearing is a nighmare trust me you need pullers and its hard work.
    So try turning the drum by hand and see if you can feel any roughness or catching this would tell you if the drum bearing has gone.
    Let me know the outcome ok
    May 01, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
    Kenmore HE low water washer: The machine has become extremely noisy when spinning out. Sounds as if the bearings are going outing the lower section of the unit. Any advice?
    its possible, but since I dont know the age of the washer, its hard to say.
    I would open the door and reach in there and try and give it a good shake around and see if you can feel anything loose.
    my mom has a HE low water washer and if its not loaded right, or got to many clothes or oddly weighed/shaped items in it, its noisy during spin out.
    theres a possibly that the washer is not securely level anymore cause it to shake about on spin out. If this is the case, if you was staring at it while it was doing it you probably would notice it shaking about, just amazing what can happen when something spins at high speeds.. its why car motors are so finely precise in engineering, they spin so fast, any imperfection would cause a disaster.
    Nov 01, 2013 | Washing Machines
    Maytag performa washer noise
    sounds like the bearing on the drum is noisy or you have some small change between the drum and the casing
    Apr 27, 2012 | Maytag Washing Machines
    Noisy drum, grinding sounds when the drum is spinning
    Hi
    The grinding sound is because of damaged or broken bearings.
    You will have to see if the motor rotor bearing is damaged or the drum bearing before you change anything.
    Regards
    Berry
    Feb 07, 2010 | Zanussi FS1155W Front Load Washer
    Machine noiser than it use to be when tub spins
    From the front of the washer, spin drum by hand, and if it feels rough or is noisy, then the main drum bearings are probably worn.
    Another possibility is the motor bearings noisy, or a worn armature.
    If the noise is gradually getting worse, then I think it is safe to say it is the main bearings.
    Jan 26, 2010 | Hotpoint WMA40 Front Load Washer
    The drum is very noisy when it turns and spins? There is no rattle but it sounds very raspy.
    Sounds like the main drum bearings have failed.
    Remove rear panel, and remove the drive belt.
    From the front open the door ,and spin the drum by hand,
    If it feels rough, or is rumbling at all, then the main drum bearings have failed.
    If no obvious noise, then it could be the motor bearings that are noisy.
    Hope this helps.
    Dec 09, 2009 | Bosch Washing Machines
    Very noisy when it spins out
    the spin surport and the back tub bearing ,defective,,shot,,bout check your owners manual your under warranty,,lifetime on spin basket...onthejob
    Feb 16, 2009 | Maytag Neptune MAH5500B Front Load Washer
    Belt keeps coming off hoover nextra hnl 3416
    It sounds like the bearing.
    It`s quite a big stripdown job.
    If you are good at DIY then you should be able to do it.
    Just make sure the drum isn`t damaged where the bearing fits.
    Feb 02, 2009 | Hoover Washing Machines
    Noisy Spin Cycle
    frigidaire frontloader infamous for rear bearings going bad,NOISY is probable an understatement. I wold open door and grab hold of inner tub, try to lift it up a bit, problably a bit of play in there, thats an indication of bearing failure, call authorized servicer possible warr parts
    Feb 22, 2008 | Frigidaire FWT449
    Maytag Neptune MAH5500B Front Load Washer Logo
    433 people viewed this question
    Top Maytag Washing Machines Experts
    Bill Long
    Ronny Bennett Sr.
    Ronny Bennett Sr.
    John Tripp
    John Tripp
    Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
