Question about Epson Stylus CX3810 All-In-One InkJet Printer
Epson stylus cx3810 printer paper jam
Do you have a do-it-yourself work-around remedy for a printer whose design allows the user to look down into the loading part of the paper path, but not inside its interior? That is, if no apparent blockage is visible, how can I access further down into the paper path to clear any debris or other particles? The machine's insides seem protected by manufacturer's screws which themselves are capped by hard plastic that require special tools to remove. It seems to be a situation that leaves me no choices beyond visiting an expensive professional repair shop or buying another printer.
  • DubbleA Jul 22, 2008
    Reply to Inky - Thanks, your reply was helpful, but only in a general way, because the model numbers listed at the website linked to "Service Manual" included every other printer model except mine. When I clicked on another link to a website to join some other group, I was led to a cryptic page that was titled, "Th3 Owl was here!" and the page was blank, all white with "done" in the lower left corner of the screen.
    I will get a #2 phillips head screwdriver and also try prying the other types of bolts with a regular flat scrw driver.
    Does someone have access to the service manual I need without me having to join some other group? I am willing to buy the manual, if I can get the url directly without any other strings attached. Thanks.
  • DubbleA Jul 23, 2008
    Thanks, Inky,
    Now, I can see why professional shops can charge so much money. However, personal determination to avoid dependency on manufacturer's will spur me on to follow your detailed instructions.
    The repair is not as urgent for me now, since I had the incredible luck of receiving an unsolicited gift of an essentially identical printer from the cashier of a local hardware store! (I had visited the store for help in disassembling my printer.) Her son had abandoned it because it had run out of ink and its exit paper feed tray was missing. I gladly took it home, refurbished it with my existing cables, ink cartridges, and feeder door. After multiple nozzle cleanings, including a 24 hour waiting period for the dried ink to soften, I was back in business with a fully functioning printer!
    Here's an idea (I wonder if there is already such an entity): Establish an exchange place for used printers, where folks could merely swap their out of order printers for other same brand (or different brand) printers that have repair issues they know how to deal with. For example, the printer I fortuitously picked up had a few repair issues I could handle. I would have been willing to swap my harder to fix printer for it. Someone else might have eagerly taken it, if he knew how to repair tricky paper jams. Printer swaps wouldn't have to be required; maybe only a low nominal fee would suffice, or donations of partially used ink cartridges, or other detachable machine parts.
I had a small piece of plastic get jammed in the mechanism that loads the paper, it is a pretty simple fix as long as you are careful about organizing parts as you remove them. Step 1: remove the small plastic panel where the usb connects, this exposes all the wiring for the scanner, you will need to carefully remove 2 plastic connectors each with four or five wire, then remove the ribbon cable from the slot. There is a screw in a clamp that holds it tight, loosen that and make sure all the wires are clear. Moving that ribbon cable will expose a screw holding the scanner on, remove that screw, then look at the other hinge, remove the screw on top and the scanner assembly should just slide off, be mindful of the wires while you do this.
Step 2: remove the control pannel, slide the control pannel towards the back of printer, it should just slide out, disconnect the ribbon cable and set it aside.
Step 3: Remove all the screws from the top cowl, should be seven screws total, i just leave them in the deep slots and keep the piece level as I remove it. That should give you access to the internals to remove anything that was jammed in the printer.
Note: Any time I do a project like this I always make sure to lay out all my screw visually in the same way they came out, since there are several different kinds of screws. Just follow the process in reverse to reassemble, making sure you reconnect all the ribbon cables and wire connectors.
Posted on Nov 30, 2010
  • Epson Master
  • 691 Answers
All Epson machines use standard No2 Philips screws in their construction. They also use a tab system which usually requires the insertion of a finger or flat blade to help them apart. But in short no special tools are required.
Get a copy of the service manual to help you take the covers off without busting the machine.
Posted on Jul 22, 2008
  • Inky Fingers
    Inky Fingers Jul 23, 2008
    Sorry, DubbleA - I Have given you the wrong link.
    The one you need is HERE http://www.tradebit.com/filedetail.php/8...
  • Inky Fingers
    Forgot to mention: DO NOT PRY ANY BOLTS. You do not
    need to force any fixings. If you do you will break the cases. You simply need
    to know where to insert the flat blade to release the tabs. This is explained
    in the service manual in the link above.
    You don't need to join any group to download the above manual.
    If memory serves me, to remove the casings to get to the paper feed area on the
    CX3810, you remove the doc cover by opening it then releasing the guide pins
    (no tools req)
    Remove the paper support guide at the rear. Again release it from the guide
    pins (no tools req)
    Next remove the plate that covers the area around the USB connection. This is
    where you will meet the first of the securing Tabs. You need to pull with your
    hand at the top edge of this cover. Once you start to open a gap you should be
    able to see the tab located under the overhang at the top of the panel. Release
    this tab with a small flat blade. You will see another toward the bottom of the
    panel where it meets the angled crease of the printer’s side panel.
    Once you get the USB cover panel off you will be able to get
    the one No2 Philips screw that is holding the leg of the lid hinge in place.
    Remove this screw and you are ready to move to the other side hinge. You may
    need to remove the cables inside the USB cover to get to the screw. You will
    have to remove the small metal bracket that holds the white ribbon cable in
    place. Then you can CAREFULLY peel the ribbon cable off its double sided
    adhesive tape to reveal the screw.
    There is then just one screw on the other hinge. As you look
    down on to the top of the unit, you will see 2 screws in the right hand hinge.
    Remove the one that is furthest to the rear of the machine.
    You should now be able to pull up on the scanner unit to
    pull it off. DO NOT PULL IT FAR, you will need to remove other plastics to release
    cables and a screw that connect to the scanner unit.
Printer says paper is jammed but is lying flat. Turned it off and back on and paper ejected. I tried again but same thing happens. (Epson stylus)
sounds like you still have paper stuck in the rollers.
get a flashlight, and look carefully, teeth by teeth.
good luck
Apr 06, 2010 | Epson Stylus CX3810 All-In-One InkJet...
My epson stylus cx3810 printer prints fine from the internet or any other application but it wll not longer make a photocopy. Th paper begins as if it is starting and the printr makes noise like it is...
This was a long time ago but I hope you havent bought a new printer
You were right to think about uninstalling the printer, but you will have to follow the EPSON instruction to do it completely. I had a similar problem with mine.
Go here:
http://www.epson.co.uk/Printers-and-All-In-Ones/Inkjet/Epson-Stylus-DX3800-Series/Drivers-Support?supportLandingPage=true
Jan 25, 2010 | Epson Stylus CX3810 All-In-One InkJet...
Epson Printer NX400 series problem
Found this on the web. You can download the
manual, reference guide, troubleshooting guide and more. Hope this helps. If you find this helpful, pls rate. me.
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&oid=106004&infoType=Overview
According to the error codes :
Make sure there's no jammed paper or other obstruction inside your Epson Stylus.
The print head may not be able to move because of some obstruction. Follow these steps to remove jammed paper or other obstructions from the Epson Stylus:
Turn off the Epson Stylus.
Open the scanner.
Remove any jammed paper or other obstructions from the paper path.
Carefully lower the scanner.
Turn the Epson Stylus back on.
Note: If you can't remove the paper or foreign object yourself, do not use force and do not disassemble the Epson Stylus.
Good Luck............
Jan 22, 2010 | Epson Stylus NX400 InkJet Printer
Not feeding correctly
Hi-
Chances are that part may not be replaceable, but try contacting compassmicro because that is one of epson's part distributor, others vancebaldwin.
hope this helps
Aug 24, 2008 | Epson Stylus CX3810 All-In-One InkJet...
LOST MY CD TO ADD STYLUS CX3810
go to the Epson site, choose your country, click on support, then on all in ones, then on the download drivers. Simple. I do it all the time, I've had 12 different Epsons, all are listed.
Jul 24, 2008 | Epson Stylus CX3810 All-In-One InkJet...
Paper jam
My CX3810 started doing the very same thing. To solve the problem, I un-plugged the printer, turned it upside-down (while holding the scan-bed cover closed) and shook the printer vigorously for a few seconds. Lo and behold, a small, white finishing nail, a peanut and a ball of fluff fell out of the slot where the paper loads. I sat it down, plugged it back in.... works flawlessly again. Hope this helps.
Jul 22, 2008 | Epson CX3810 Stylus Color All-In-One...
"not ready to print" message
I just recently had the identical problem. Go to "start," click on "printers and faxes"; right-click on the icon (or copy for it) for your printer; select from the popup menu, "default printer." This will put a check mark by the printer icon, and possibly simultaneously remove the check mark from another icon that was a deadend. I encountered this problem when I replaced my paper-jammed epson stylus CX3810 inkjet printer with another almost identical printer that had been abandoned by an acquaintance. [He had abandoned it because his ink nozzles (except black ink) had clogged up. I was grateful for it despite the seemingly irreversibly clogged nozzles.] I think printer manufacturers should work on more user-friendly designs that allow easier repair of mechanical problems like paper jams!
Mar 28, 2008 | Epson Stylus CX3810 All-In-One InkJet...
Epson 3810
look in and around where the paper is fed into.there maybe a small piece of paper stuck somewhere inside. if you do see something, unplug the machine and try to pull it out with a pair of needle nose pliers. if you do get the obstruction out, try feeding the paper back in and see if it now works.
good luck.
wg
Feb 13, 2008 | Epson Stylus CX3810 All-In-One InkJet...
Printer Grabs corner of the paper and jams
I had the same problem and what I finally noticed was that something had falled off the shelf above and lodged itself way up in the paper feed slot. It was basically invisible at first and produced the exact symptoms that you described. Unplug, hold upside down and give it a good shake. It's worth a shot.
Nov 12, 2007 | Epson Stylus CX3810 All-In-One InkJet...
Open Questions:
See all Epson Stylus CX3810 All-In-One InkJet Printer Questions
Epson Stylus CX3810 All-In-One InkJet Printer Logo
855 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
