Uniden Cordless Phone Logo
Posted on Jul 22, 2008
Uniden 900mhz i can't find the directions to set a greeting. can you help me.
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Jul 25, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
55
Points
Did you solve this problem.. I am having the same problem setting up a greeting on my phone. Can you help?
How do you set up voicemail; on a uniden dect 6.0?
Which exact model Uniden DECT phone do you have? There are a number of models. Some require you to set up the answering machine from a handset. Other models have a Menu button on the base station, as well. The entire list of DECT phone manuals are here: http://www.uniden.com/scat/dectphones_mnl . They are listed in alphabetical and numerical order. Ignore any digits after the dash in the model number, that indicates the number of handsets in the original package. My experience with Uniden DECT phones includes systems where the menu is accessed from the base like the D3588, http://www.uniden.com/content/ebiz/uniden/resources/ownersmanuals/D3588om.pdf .
The following directions work for the Uniden systems that I have used to set up the . First make sure that the answering system is on at the base station and the phone is in standby. Next press the Menu/Select button and use the Up/Down arrows to navigate to Answering Setup. Press Menu/Select to enter the submenu. Then navigate to the different options in this menu and press Menu/Select to enter them.
To record a greeting message, navigate to Record Greeting. Press Select and wait for the "Record Greeting" response. Speak your greeting clearly (between 2 and 30 seconds) and press Select to Stop the recording. You'll hear the greeting repeated. Press End (on the handset) or Stop/Cancel on the base to interrupt the playback.
Next press the Phone Book button to go back up to the Answer Setup menu. Select Greeting Options to switch greetings (if your model has a default greeting). Use Select to switch between greetings. (Arrow keys to swap; Select to confirm.) Use the Ring Time option to select how many rings before the unit picks up. If you wish to use the answering system when you are away, make sure to set up a Security code and press Select to confirm the code. Make a note of the code. Press End to exit the menu system.
Note: if you have Voicemail from your telephone provider, you will need to ensure that your Uniden phone picks up before the Voicemail service.
I hope this helps.
How to change greeting for a 5.8 digital uniden phone
Since you declined to specify the model of your Uniden system, I can only direct you to select it from the list beginning here.
I need the manuel for the Uniden EWC1936 900MHz Cordless Weather Forecast Phone could you help me please?
You can download the manual from the manufacturer's web site at
http://www.uniden.com/content/ebiz/uniden/resources/ownersmanuals/EWCI936m.pdf
How do you recieve messages off of a uniden 900 mhz answering machine from another phone?
Since you declined to specify the model of your Uniden 900MHz system, I can only direct you to select it from the list beginning here to download a copy of the manual.
1helpful
2answers
Need instruction manual for 900MHz cordless phone
Did it ever occur to you to just go to the Uniden website to download it? Here: http://www.uniden.com/pdf/EXAI985HSom.pdf
2helpful
How do you record a greeting
CLICK HERE for your owners manual in PDF format.
See Recording a greeting pg. 47 (45 actual)
Thanks for using FixYa - a FixYA rating is appreciated for answering your FREE question.
Answering feature
how do i change the greeting on my digital recorder
Increase numbers of ring
If the machine won't go past 4 rings (which it should somewhere in the answering machine settings menu) you could always change your greeting to a message that tells the caller to wait a few more moments for you to answer, while you get to the phone....
7helpful
6answers
How to set message for answering machine lost directions
I lost the directions for my NW Bell GHZ answering machine. I would like to change greeting and set the time. How do I do this? It is model 36288.
Top Uniden Lands Phones Experts
k24674
Grand Canyon Tech
Grand Canyon Tech
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
