Question about Maytag Dryers
Maytag dryer model # PVE 2300 AYN The dryer heats up, but does not spin. I assume it is the belt. How do I get to the belt? I see 3 star shaped screws at the bottom of either side, as well as numerous screws on the back. What is the procedure in getting to the drum/belt? Thanks, Derrick Hamrick, unauthurized repairman!
  • pussyeater Jul 22, 2008
    Maytag dryer model pve2300AYN
    How do I get to the belt/drum? The back panel does not come off as was previous suggested.
    Thanks,
    Derrick
  • 2,071 Answers
Turn upside down your dryer and then open it ,then belt will be appear take it form the pulley and change it with desame belt,,
hope this may help;
Regards,
VOTIT
Posted on Jul 31, 2008
  • 13,433 Answers
  • Maytag Master
  • 19,396 Answers
Usually , after you remove the back panel you can see the belt yourself, running from the motor to the basket gear.
Posted on Jul 22, 2008
Dryer won't spin
If you have kids and they over fill the dryer it strains all systems including the heater because it cannot get rid of excess heat. Solution*** Possibly needs a new belt
Dec 07, 2012 | Maytag Dryers
Dryer quit spinning.
If the blower is working, then it's most likely the belt, a belt pulley or a tensioner spring.
Open the dryer, it will power off, and then spin the drum by hand. If it moves with little resistance, it's your belt.
Dec 11, 2009 | Maytag Dryers
Maytag dryer wont spin It makes heat,but the dryer wont spin
Sounds like the drum belt is broken or off the pulley of the motor
Sep 25, 2009 | Maytag Dryers
Maytag Model PYE 2300 AYW Dryer will not Start
How about the controller that turns everything on? Check for power to it? Relays(if any) working?
Aug 28, 2017 | Maytag PYE2300AY Electric Dryer
Replace dryer belt
Pull the front panel off, remove the top screws and tilt top back. Rout the new belt around drum at the old wear spot with the grooved side against the drum. Next remove the back access door and rout the belt around the idler pulley and motor pulley. There is only one way to do this and get proper tension on the belt.
Also, when you order the belt, ask if it has a belt routing diagram on the belt package.
Apr 07, 2009 | Maytag PYE2300AY Electric Dryer
Maytag performa intellidry dryer model#PYE4500AYW
Check drive belts. If too loose or too worn it will not spin at proper speed.
Mar 27, 2009 | Dryers
Need ohm readings for Maytag Performa Model PYE 3200AYW
Go to this site for info on your dryer type, you may find what you need there...
http://www.applianceaid.com/ww-and-mc.html
Jan 14, 2009 | Maytag PYE2300AY Electric Dryer
Dryer Drum Won't Spin
Reach inside and grab ahold of the baffle. Try to spin the drum, it should have resistance. If it spins freely you have a broken belt. Hope that helps. Dave ww.washermd.com
Dec 16, 2008 | Maytag Dryers
I could not find the moder number in any maytag list, all I can do is posting general guidelines, like this one here:
online guide Clik here.
Generally to remove a belt in an electric maytag dryer you unscrew thescrews at the base of the front side of of the machine to remove thefront panel.
Then the topc omes up.
Thenyou remove the rear access panel and remove the tension on the belt. Getthe drum out, clean the dryer, eventually oil wheels and rollers, and re install the drum ensuring the belt ison right side and not twisted.
Jul 22, 2008 | Dryers
Dryers Logo
270 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
