posted by kdug on Jul 22, 2008
Computer would not turn on or off. I replaced the power supply but that's not it. It seems to be the ON/OFF button; when I separated the inside from the outside and pressed it, sometimes the light came on for a split second and the fan would turn, but then all stopped again. Is this fixable, and if so, how?
thx
Solution #1
posted on Jul 23, 2008
Everythings Fixable. If you locate the power switch Cable To Motherboard. Should be marked ( pwr on Motherboard )
use a hard-drive jumper. small plastic link block. to join the 2 connections on the board itself. ( Jumper )
now plug the mains cable in, if it runs. then you know it,s the switch thats faulty. you can replace this with any similar make break switch. alternatively. if the case has a seperate reset switch. use that instead.
Mike @ Compurepair.
Mike @ Compurepair.
Was this solution helpful? Show your Appreciation by rating it:
Suggest a new solution for this problem
Post a New problem for Compaq Presario 5000 PC Desktop
Email this problem
Email this problem
Can you Help with these PC Desktops problems?
Start button wires came out of...
I need to find out the order of... Answer This...
I have broadband but use
I have broadband but use aol... Answer This...
Repair Service
Find PC Desktop Repairman Near You:
