I got my floppy disk stuck in my wife's hard drive!
  • 70 Answers
Are you sure you mean hard drive? the hard drive does not have any openings to get anything stuck in.i think you mean flopy drive?theres abuton on the front have you pressed it?
Posted on Jul 22, 2008
My laptop says no bootable device insert disk what is wrong?
NO BOOTABLE DEVICE When the PC cannot see a boot file/disk on either the hard disk or floppy drive it gives an error message "No bootable device. Insert boot disk and press any key" First thing, check to see if the is a floppy disk in the floppy drive, if so removes this disk. If there was no disk in the floppy drive then it may be a hard disk problem.
Check the BIOS to see if the hard disk is detected, if not open the case and re-seat the data cable on the hard drive and also where it connects to the motherboard disk controller.
If it still gives this error message and the BIOS does not detect this hard drive, then the hard drive is probably faulty.
A further check on the hard drive, remove the hard drive and connect it to an USB hard drive adapter and connect it to a working computer's USB port, if this computer does not detect it as an external storage device then the hard drive is faulty.
To get the computer operating again, install a new hard drive in your computer and then install Windows on this hard drive plus the computer's device drivers and your programs.
Oct 30, 2012 | Toshiba Computers & Internet
Tip
No Hard disk detected / boootable device
<span>When the computer/laptop cannot see a boot file/disk on either the hard disk or floppy drive it gives an error message </span>- <span>"No bootable device. Insert boot disk and press any key"</span><span><br /><br />First thing, check to see if the is a floppy disk inthe floppy drive, if so removes this disk.</span><br /><span>If there was no disk in the floppy drive then it maybe a hard disk problem.<br />Check the BIOS to see if the hard disk is detected, if not open the case and re-seat the data cable on the hard drive and also where it connects to the motherboard disk controller.<br />If it still gives this error message and the BIOS does not detect this hard drive, then the hard drive is probably faulty.<br /><br />A further check on the hard drive, remove the hard drive and connect it to an USB hard drive adapter and connect it to a working computer's USB port, if this computer does not detect it as an external storage device then the hard drive is faulty.<br /><br />To get the computer operating again, install a new hard drive in your computer and then install Windows on this hard drive plus the computer's device drivers and your programs.</span>
on Jan 17, 2011 | Computers & Internet
Tip
NO BOOTABLE DEVICE
When the computer/laptop cannot see a boot file/disk on either the hard disk or floppy drive it gives an error message - "No bootable device. Insert boot disk and press any key"
on Oct 02, 2010 | Computers & Internet
Bootable device has not been dectected
When the PC cannot see a boot file/disk on either thehard disk or floppy drive it gives an error message "No bootable device. Insert boot disk and press anykey" First thing, check to see if the is a floppy disk inthe floppy drive, if so removes this disk. If there was no disk in the floppy drive then it maybe a hard disk problem.
Check the BIOS to see if the hard disk is detected, if not open the case andre-seat the data cable on the hard drive and also where it connects to themotherboard disk controller.
If it still gives this error message and the BIOS does not detect this harddrive, then the hard drive is probably faulty.
A further check on the hard drive, remove the hard drive and connect it to anUSB hard drive adapter and connect it to a working computer's USB port, if thiscomputer does not detect it as an external storage device then the hard driveis faulty.
To get the computer operating again, install a new hard drive in your computerand then install Windows on this hard drive plus the computer's devicedrivers and your programs.
Aug 24, 2011 | Intel D946GZIS Motherboard
Disk boot failure insert system disk
First if your computer has a floppy drive, check to a floppy drive does not have a floppy disk in this drive.
Your computer cannot find the hard disk to boot up.
Go to your BIOS to see if the BIOS detects the hard disk, if not remove the hard disk and re-connect it again and see if it boots up.
If it still does not boot up then most likely the hard drive has failed.
To get the computer working again, install a new hard drive, install Windows and the computer's device drivers and your programs.
Dec 10, 2010 | Computers & Internet
When my computer starts it goes to a black screen and says "no bootable device jnsert boot disk and press any key" what can i do
Normal 0
This error message - "No bootable device. Insert boot disk and press any key" means -
The PC cannot see a boot file/disk on either the hard disk or floppy drive.
Check the floppy drive and remove and floppy disk.
If there was no disk in the floppy drive then it is a hard disk problem.
If it still gives this error message and the BIOS does not detect the hard drive, then the hard drive is probably faulty.
To get the computer working again, install a new hard drive in your computer and then install Windows on the new hard drive plus the computer's device drivers and your programs.
Floppy is stuck in slot
The most comprehensive information that I have found is located at Computerhope.com
Floppy diskette stuck in floppy drive
http://www.computerhope.com/issues/ch000828.htm
If the above does not work then you will need to replace the floppy drive and take apart the old floppy drive to remove the disk.
May 11, 2009 | Computers & Internet
I have a HP 8595c computer. I put a DVD in and it froze. I restarted the computer and now it won't boot up proberly. I get this message. "Non-System disk or disk error Replace and strike any key...
Non-System Disk or Disk Error results when the Basic Input/Output System (BIOS) cannot find the boot sector or the master boot record is missing or damaged; i.e. the device does not have bootable media. The BIOS searches drives in the order usually specified in the CMOS Setup. This order is often, but not always, A: (floppy drive), C: (first partition on the hard disk)… The error will occur during startup if the CMOS is set so the BIOS seeks the floppy drive first and a non-bootable (or blank) floppy is in (was left in) the floppy drive. Other causes include:
No bootable partition on a hard disk drive
  • A defective hard disk drive
  • The CMOS drive settings (parameters) are not correct for the boot device
  • Defective floppy
  • Defective floppy drive
  • A virus
  • Jul 21, 2008 | Computers & Internet
    I could not get my floppy disk out and the paper sticky that describes what is on the disk got stuck. I had to get it out with a tweezer. The spring load would not push it out. NOW, I cannot put my floppy...
    On my Sony MVC-FD88 I had listed this as a similar problem on FixYa.com and then explored it further. I'm very technical so I replaced the internal floppy disk drive myself, so wanted to post my findings here.
    I bought the internal floppy disk drive (very hard part to find) at partstore.com
    It is not an easy procedure if you have not done this type of work before. There are several online places that will replace the floppy disk drive for you.
    They are very delicate, any jar to the camera can harm them, as well as, labels on disks loose or a misaligned disk cover on the floppy disk. Mine now works perfectly. Generally, once they jam, getting the floppy disk out often destroys the floppy disk drive heads inside the camera. These are great cameras. I am always impressed by mine, it is a definite keeper. From what I've found the electronics of the camera are quite reliable and I only need to take a couple of pictures at a time, so a memory chip type camera is of no real value to me.
    Jul 21, 2008 | Cameras
    Windows Setup cant find hard disk ?????????????
    Does the BIOS on your system see the drive and show it's model information? Is this the only drive on the system? If the answer is yes for both, then you can download free utilities from the web to wipe the drive clean. This will result in the loss of all existing data on your drive. You can search for "Wipe Disk" and will get several hits for free software. Once you have cleaned the drive, try instlling XP. If the BIOS does not see your drive, the XP can't see it. You may want to try other SATA ports on your motherboard, or try changing the IDE configuration in the BIOS. Let me know if this works.
    Aug 29, 2007 | MSI K7N2 Delta-ILSR (MS-6570-030)...
    Computers & Internet Logo
    David Payne
    David Payne
