Question about RCA P52930BL 52" Rear Projection Television
My Big Screen making a loud beeping noise!
Model #: P52930BL
Its a RCA. Everytime I plug it in the wall it makes a loud beeping noise and will not turn on. What's the problem?
  • chewchang Aug 06, 2008
    same problem except my model is p52923
  • RCA Master
  • 8,617 Answers
The beeping noise is usually related to the Horizontal out put transistor or flyback being faulty or one of the coils are loose near the flyback. If you remove the rear cover without touching anything can you tell if the beeping is coming from the large transformer with the red wire coming out of the top or is it coming from a black transistor on a aluminum heat sink.
Posted on Jul 22, 2008
Loud static noise without warning
The audio may be randomly disconnecting or something. I know that when my TV has no signal coming in, that it makes a bunch of loud static.
Jun 04, 2010 | Tatung V20KQDX 20.1 in. LCD Television
TV is making a loud ear piercing noise.
Ur high voltage is going through FBT,the big black block of plastic with a wire red or gray solder to the board.The Flyback transformer.There a steel "3 inches like a paper clip like steel.Put some supper glue on that "3 steel paper clip look like, will help or stop loud wishling noise all together.
Apr 21, 2010 | RCA HD52W59 HDTV Projection Television
TV makes very loud noise
Ur high voltage transformer is dead,the FBT,the big block of plastic have red wire go to the video board.Also might have burns capacitors in the DM power suply board or deflection board it puffed up.
Sep 28, 2009 | RCA HD52W58 52" TV
Central air condtioner making beeping noise!
it means it has a fault. try resetting unit by switching circuit breaker off and on it might go away
Jun 04, 2009 | Amana ACD106R Wall/Window Air Conditioner
Rear screen tv
replaced flyback transformer
Sep 17, 2008 | RCA F36650 36" TV
Hp computer will start, all the lights come on but the screen is black.. also.. it makes this loud beeping noise 4 times?? whats wrong?
The beep is more than likely a beep code (sounds stupid and obvious, but they're there for a reason).
What make/model is your machine? We can look up the code by make/model. That will diagnose your problem.
May 16, 2008 | Sony VAIO VGN-N250E/B Notebook
Beeping noise
I've had the Dell 1720dn at my desk for years. Worked flawlessly. Moved it to a different workstation and it began beeping immediately while printing. Another site said to plug it directly into the wall, instead of a battery backup. I unplugged it from the battery backup outlet, and plugged into a surge protector only outlet on the same battery backup unit.... NO MORE BEEPING. Hope this helps someone else.
Apr 01, 2008 | Dell 1720dn Laser Printer
Beeping noise
Please check inside the machine to ensure that all packing material has been removed..cheers, John
Oct 20, 2007 | Brother ML-300 Typewriter
Beeping dryer
You should open the service panel and to find out where does the "beeping" unit located and to remove one of the wires connected to it (the unplugged wire should be insulated). Good luck!
Aug 20, 2007 | Miele Novotronic T230C Electric Dryer
When plugged in, makes beeping sound; won't come on.
The flyback and horz output has failed,if its a ptk195 chassis,most likely the part numbers are 239111 and 237470
Feb 24, 2007 | RCA P52930BL 52" Rear Projection...
Televison & Video Logo
339 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
