Question about Gateway FPD2275W LCD Monitor
HDMI/DVI input problems
Hi!! i have a sceptre monitor model x22wg-Gamer from about a year, i've tried to connect my xbox 360 but nothing comes on he screen, surfing on the internet i noticed that this brand have a lot of issues with the High definition ports my warranty past over so i need to go with a technician to fix the monitor so my question is: there is a way to fix this problem (a cheap one)?
  • iuliu Mar 24, 2009
    If I connect the monitor to HDMI/DVI port it says NO SIGNAL.
    Thanks,
    Iuliu
  • 304 Answers
You could try opening the housing, with the power cord unplugged. Find the location on the circuit board where the HDMI/DVI port interface with the circuit card. Check the condition of the solder joints and look for signs of a cold joint or bad connection where the sockets connect. If you find bad solder joints simply resolder them with a low wattage soldering Iron no larger than 30 to 40 watts. Make sure you do not accidently solder any of the pins together causing a short circuit. Use the thinest 60/40 lead/tin rosen core solder. You can get this cheap at radio shack. If this is the case you will be up and running in no time.
Also I'm sure you already tried this but make sure you set the T.V. to get the signal from the proper port. You do this in most cases by hitting the source button on the remote or finding the option to select input source under the main menu somewhere. If you somehow over looked this, Try this first and your problem will be solved. If you need more help feel free to contact me. I will answer any of the questions you may have.
If you could please remember to rate this solution after we are done diagnosing your problem
Posted on Jul 23, 2008
  • George Kohler
    George Kohler Jul 23, 2008
    Please log in and rate this comment fixya if it helped you resolve your problem. If it did not send me an E-mail with
    your phone number to geokohler@gmail.com And I will help you fix your problem. Do not rate the problem until We
    have it fixed.
    Thank you,
    George
    Ps. This is totally free or charge to you. I even pay for the call.
  • George Kohler
    have it fixed.
    Thank you,
    George
Can i connect my xbox 360 using Dvi D to Hdmi in the dvi slot and also my tower to the vga slot on my eMachines E19T6W
I am not an xbox person, but as far as hooking it up, it should work as long as the other device is NOT powered up. That being said you will still have to provide audio from the xbox another way as dvi only carries a video signal, unlike the hdmi which carries both audio and video.
Dec 12, 2011 | eMachines E19T6W 19" Monitor
My sceptre X22WG is no longer showing white screen but getting progressively darker blue. How can I get it back to a white screen?
Colour changes like this are either due to a failing graphics card, failing monitor or bad connection from the computer to the monitor.. with this monitor, I'd have it checked by a tv repairman
Jan 18, 2011 | Sceptre x22wg Gamer Monitor
I am trying to connect a Sceptre monitor
Will the monitor work on another computer? Will the computer work with a different monitor? Are you connecting the vga port to vga output on the video card or the dvi input to the dvi output on the card. You may need a video card with hdmi output.
Jul 17, 2010 | Sceptre X24WG-NAGA Monitor
X22wg-Gamer Monitor: It appears the power supply is dead, what can I re...
you need to check if your capacitors are blown, if they are, you can replace them...it's a very economical way of fixing it. This is a common problem of Sceptre x22wg-gamer.
May 16, 2010 | Sceptre x22wg Gamer Monitor
Monitor will not turn on blue light flashing bottom right hand of monitor
I'm having the same problem. Had the monitor for almost 2 years and everything was working fine until this week. The blue light would blink, then after an unpredictable period of time, the monitor would turn on. Seems like it needs to warm up or something. I suspect it has something to do with the capacitors not charging inside. Somewhat disappointed with Sceptre. I suppose I should be thankful that I got 2 years out of it.
Oct 09, 2009 | Sceptre x22wg Gamer Monitor
Monitor worked fine for years, then permanent standby
hey
usually this happens due to static try to power cycle the monitor by disconnecting all the cables from the monitors
then connect teh cables back one by one
and see if it works and if not yes get teh monitor replaced
Sep 18, 2009 | Sceptre x22wg Gamer Monitor
X22WG-gamer sceptre 22" monitor won't power on. It's not the power cord because I've used the power cord on a different monitor and it worked fine. Any and all assistance will be much appreciated.
Your monitor has 3 or 4 blown caps right next to the power plug. They are CapXon 470uf25v. Just open the back and remove the power board, desolder, and replace the 3 or 4 caps put it back together and it should go back to working. This a typical problem with the Sceptre gamer, HP1706, and the HP1903. And guess what they all have the same caps blown in almost the same place.NOTE: When seperating the case the power led is glued to the front frame. Take your time if you rush you will break a cable wire or plug.
Sep 07, 2009 | Sceptre x22wg Gamer Monitor
My Sceptre x22wg-Gamer Monitor isn't getting any power, HELP!!!
I have two of the X22WG monitors, both dead. The power supply in this model is apperently plauged with a common error. The problem is close to the +5V and +12V output connector (Far right corner, with power plug against you). Two out of the four small caps are blown. Replace those, and it should be fine. C551 and C552.
Jun 09, 2009 | Sceptre x22wg Gamer Monitor
I have a Sceptre x22 gamer that has been serving me well for about two years. A week ago I started having trouble getting the monitor to ''Wake Up'' after the computer goes to sleep or when rebooting. It...
warcryofjuda, One of the guys that I work with brought in a small screen Sceptre DTV/DVI/VGA +audio unit. and it also has a optional TV/tuner module. mod S1701DTV with side mounted speakers. The viewable screen size is 14"w x 8.75"h . Oh! First things first! Turn it OFF and leave it off. Disconnect it and put it in a safe place for now. IT'S BROKE!! It will not work today, and it will not work tomorrow or the next day. Got that? Ok! Now I want to know if you would like to work together with me and explore both of these monitors and possibly come up with a fix for them? Please get back to me via my email with what ever approach you feel is best for you. We have already opened up our unit and I will try to attach some pic's for you to compare your unit with. I'm louie12fix on fixya or lmistyrel@aol.com
Bye for now.
Apr 15, 2009 | Sceptre x22wg Gamer Monitor
Gateway FPD2275W LCD Monitor Logo
177 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
