Question about Sharp Audio Players & Recorders
Please, can you tell me where can I find an IC OUTPUT for a Sharp Optonica model SM4646C. The part # write on the IC is: RH-iX1056AF
  • ANTONIO SANCHEZ Feb 06, 2018
    there are and ic called SW-100..is a good replace
Hola necesito el integrado para el optonica sm-3510 el integrado es rh-ix1056af si lo tienen enviar correo a gilmor18@hotmail.com
Posted on Oct 01, 2014
    DAVID..CON ESE NUMERO ES DIFICIL CONSEGUIRLO..ADEMAS ESTA DESCONTINUADO..PERO AUN SE CONSIGUE EL IC MARCADO COMO SW-100..CON ESE PUEDES REEMPLAZARLO CON TODA CONFIANZA
I have 2 pieces for you if you still need them!
Wim
Posted on Nov 29, 2009
I need to repair the sharp optonica rp-104 turntable cartridge
VinylEngine.com has information about this table/cartridge. Optonica was a division of SHARP electronics and made some good products back in the day.
Jun 01, 2014 | Audio Players & Recorders
My optonica tv was putten off for almost 3 or 4 months but it was working before we have putten it off as we watched and used the other tv instead of this then we finally thought to put cable for the...
Dry soldering of the vertical section IC. If your tv works properly or intermittently if you slap it :) on the sides then dry soldering is confirmed.
Oct 15, 2010 | Televison & Video
Only a horizontal line can I see in my TV
In most cases the vertical output IC and possibly a fusible resistor off of the high voltage transformer are bad. The vertical output IC is located on a heat sink and usually right next to the vertical yoke winding connectors that are green and yellow in most sets. Please take a moment to rate my answer..Thanks...
Nov 24, 2009 | Sharp 27G-S60 TV
Hello There!, Where can I get a T.V. Picture tube for my Sharp Optonica CS 5400 Model TV ?? (Near Goa or Bangalore)
You could try KOTHARI ELECTRONIC HOUSE 75, Sadar Patrappa Road,, Bangalore - 560002 (Karnataka) India Phone(s) : 080-2223351 Should cost around Rs.2500-3000. But, as the model you are mentioning is pretty old, is it worth replacing a Picture Tube? Think about it
Jun 08, 2009 | Sharp Televison & Video
My sharp Stereo is stuck in '' protect'' mode
Protect mode is not something that a reset will fix. Basically it indicates that there is a problem with the final output stage of the amplifier. Normally this indicates that the output transistors are defective. In most boomboxes, the amplifier is a single IC. If you can post the model number, I can provide you with the required part and cost.
Thanks,
Dan
Mar 25, 2009 | Sharp Audio Players & Recorders
Users gude
I couldn't find anything on this optonica stereo company, and do you need to know how many watts it really is? Why don't you just plug it in and see how LOUD IT GETS!!!!
Dec 23, 2007 | StorCase 2 Bays Data Silo DS320 Storage...
Sharp 25" tv unknown model (no av in)
It is a simple trouble, tv has got dry solder joints in the vertical deflection circuit. Resolder vertical output ic pins and related components, this will be okay.
Dec 17, 2007 | Sharp 25R-S100 25" TV
SHARP OPTONICA SM-1515 STEREO AMPLIFIER
15+15Watts per channel PMPO. Optonica is a Brand under which SHARP was Marketed in India.
Oct 31, 2007 | Audio Players & Recorders
Shorted a RH front speaker, now there is no output from RH channels at all
The output stage of the amplifier (RH channel) was probabla damaged from the grounded cable. The heat in the speaker means that the coil (d^speaker) is recieveng DC power from the damaged amplifier. Audio amplifiers are not special and can be fixed. In many cases, the output stage is a power MOSFET or a power audio amp IC. The only issue is the availability of the parts in your area.
Jun 14, 2007 | MTX RT404 Car Audio Amplifier
219 people viewed this question
Top Sharp Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sharp Audio Player and Recorder Expert? Answer questions, earn points and help others
