Question about Dell Inspiron E1505 Notebook
Ethernet port?? i have a dell laptop and the internet isnt working, i thought it was a problem with my provider so they came out and looked at it... they said its a problem with the computer... he said that where you plug in the internet cable there should be a green light, but mine is orange.... What does this mean and how can i fix it?
  • 2 more comments
  • lindsey1188 Jul 22, 2008
    The guy and i have unplugged and rebooted and its still not working.... He brought his computer up from his vehicle and plugged it in and it worked just fine...
    Sorry but computer terminology is a foreign language to me.... so how do i do that?
    Thank you! =D
    I will try this as soon as i get home from work.
    After i uninstall it and reboot i will have to go back in and re-install the same way?
  • esy7
    esy7 Nov 01, 2008
    I have a similar problem. I was on the internet and I slightly dropped my laptop on the carpet. The ethernet cord was plugged in. So I restarted my comp and I have no internet connection whatsoever. My laptop seems to be working perfectly fine except that I have no internet connection. I have a Cox modem and I restarted that as well and Cox sent a technician to see if something might be wrong with the modem. He told me something was wrong with my computer - possibly the network card???
    So basically something is wrong with my laptop because my I have no internet connection with the ethernet plugged in when it's working on my brother's laptop.
    I followed the instructions but I don't see any device that reads ethernet or network controller. Now did you mean "Network adapter"?
    Please help! Thanks!
    Genius:
  • 2,028 Answers
The lights are green when active, orange when at idle. This could be a simple driver glitch. Uninstall the ethernet drivers from the device manager and reboot. The machine will find the port and reinstall the drivers. If it still doesn't work try a different laptop on your home service, some of these guys are idiots, and assume the problem is on your end without checking the problem thoroughly.
Posted on Jul 22, 2008
  • 1 more comment
  • Ryan Rogers
    Ryan Rogers Jul 22, 2008
    O.k. I'm going to say that it's a driver glitch. Unistall the drivers for the ethernet or network controler and reboot. The automatic reinstall should clear up the issue.
  • Ryan Rogers
    Right click on "my computer" and open properties. At the top there will be tabs, one will read hardware, open the hardware tab and click on the button marked device manager. In the device manager there will be a list, the ethernet or network controller will be in the section that reads network or network devices. Once you find the device that reads ethernet or network controller, double click on it and it will open. Under the drivers tab there will be a button that reads uninstall, click this button. Then back out and reboot.
  • Ryan Rogers
    No, the machine will detect the hardware as if it were new, and automatically find and reinstall the drivers. Let me know.
Can I disable wireless and connect with ethernet cord and modem, for work do not want remove wireless cord, in the day want to be able to use my wireless.
Are you talking about direct-connecting via Ethernet to a cable or DSL modem? You shouldn't have to disable wireless to do that. If the cable modem has an open Ethernet port, you should be able to run a straight-thru Ethernet Cat-5 cable between that port and the Ethernet port on your laptop. The laptop should recognize that it is connected to the modem through the direct connection. Check the manual for the cable modem or information supplied by your ISP for connection details. You may have to do some setup on the modem to get an Internet connection, like having your ISP 'activate' the modem. Just be sure your Ethernet cable is a straight-thru, standard Ethernet cable, and not a 'cross-over' cable such as is used to transfer data between two computers.
Jul 24, 2014 | Dell Inspiron Computers & Internet
How to connect thru ethernet cord on dell latitude d510
Plug it into the Ethernet slot in the back or side panel to your modem that is about it and you should get Internet if you have a provider. John
Apr 19, 2012 | Dell Latitude D510 Notebook
My new laptop has ethernet a port and I only have dial up internet,how can I hook it up.
ethernet a port is used for broad/tribandband connection so subscribe to ISP & replace u'r dialpup or use both
Dec 03, 2010 | Computers & Internet
Internal modem is not working
Are you sure it's a modem port and not a ethernet port. They look very similar and people confuse them easily. The ethernet port is slightly larger though. So we can verify we're talking about the correct thing, are you using dialup to connect to the internet? or are you connecting to a broadband router or dsl modem?
in either case you should be able to get drivers on dell's website and copy them over to your laptop.
Oct 07, 2009 | Dell Inspiron 2200 Notebook
Ethernet port
try to reset first the modem before checking the cable maybe your modem need to be reset... if not work... try to unplug for a minute then plug it again... then try to use your internet..
Jul 17, 2009 | Dell Dimension 4600 PC Desktop
Questions about replacing ethernet card on my Dell desktop
Any ethernet card will work fine. Just be sure it's the fit's the correct slot. You probably have a "white" slot which is a pci slot. If it's a longer "black" slot then it's isa. More than likely it came from a pci slot. Before you buy one, confirm the type of slot. In additon, before installing it go to control panel and system settings, hardware, device manager and remove the old one by right clicking it and select delete or remove. Shut down the computer follow instructions for new card.
Probably will have to install the drivers first then shut down and install the new card. Good Luck.
Apr 17, 2009 | Dell Ethernet Card Network Adapter
Network problems connecting to internet
Hi. If Dell is correct, then yes, it would be expensive. Your other alternative is to buy a PCMCIA Ethernet Card. They range from about $20 to $40. Or, you could go with what you suggested and do wireless via a wireless router.
May 21, 2008 | Dell Inspiron E1505 Notebook
Dell inspiron 1525
check your lan card maybe it is disable, try to enable it
Apr 12, 2008 | Dell Inspiron 6400 Notebook
Plugged ethernet cable innto laptop from cable modem and nothing
Click Start / Control Panel / Network Connections.
Your Ethernet status should show under LAN or High Speed Internet. It might be disabled, in which case, right click & ENABLE.
Let me know how you get on.
Jan 10, 2008 | Dell Latitude C640 Notebook
Dell Inspiron E1505 Notebook Logo
121 people viewed this question
Alun Cox
