Question about Panasonic Panafax UF-595 Plain Paper Laser Fax
Panafax UF 560 manual
We do not have a manual for our Panafax 560 fax machine. How do we set our outgoing faxes to go to memory? As of now we hear the number dialing.
  • jank01 Jul 22, 2008
    link is unavailable
  • Panasonic Master
  • 19,396 Answers
Check here: UF-550/560/770
Posted on Jul 22, 2008
  • Ginko
    Ginko Oct 08, 2008
    Sorry about that.
    Here is the right link:
    ftp://techdoc:techdoc@193.251.13.10/UF550-560-770.pdf
    Copy and paste it in Internet Explorer to open the manual
    I will be grateful if you can change the vote given.
    Thanks
Can you add a new fax no that shows in the header for outgoing fax?
To set Outgoing Fax Number/ ID follow the follwing steps: -
- Press FUNCTION, Press 7 (Set mode will appear on display)
- Press 1 (User Parameters Settings)
- Press Set repeatedly until display shows ID
- Enter your Number/ ID (max. 20 digits) by using the key pad
For further information you may refer to User Manual for Panasonic Panafax UF-585 Page 29
Hope it helps! Good Luck!
CreativeTECH
Feb 03, 2011 | Panasonic Panafax UF-585 Plain Paper Laser...
Outgoing memory is full
press
Function
7
monitor key slowly 4 times
* star key
6
scroll down to ALL JOB CLEAR
set
wait for a reboot, about 2 mins.
Your fax machine most likely is not finding a dial- tone, so faxes are piling up in memory and are never being transmitted.
After the reboot, press the monitor key once and listen for the dial-tone.
Jan 20, 2010 | Panasonic Panafax UF-595 Plain Paper Laser...
How to clear memory on Panafax UF-560 ?
Press
Function
7
6
scroll down to SHIPMENT SET
set
wait for the machine to initialize.... 3 mins.
Oct 09, 2009 | Panasonic Panafax UF-560 Plain Paper Laser...
How to save fax numbers
press Function
72
set
1 for ONE TOUCH NUMBERS
set
press 01 on the soft pad
enter fax number with the DIALING NUMBER KEYS
set
enter name with LETTERS on the soft pad
set
continue with 02, 03, 04 etc.
when done press stop.
press Function 67
set
cut out directory sheet on dotted lines and put under the mylar sheet on the soft pad.
press Function 62 set to print out the list of one touch numbers.
Nov 19, 2008 | Panasonic Panafax UF-560 Plain Paper Laser...
press the monitor button and check for a dial tone thats the first step. have you had any changes to phone system or internet recently. you could also prees the memory button and try to send a fax directly without memory use, you should hear it dial then connect and send.
Apr 24, 2008 | Panasonic Panafax UF-595 Plain Paper Laser...
One Touch Dialing numbers won't permanently save to FAX machine
If you followed the procedure F 7, 2 set, 1 for speed dial, enter your free speed dial space, enter your fax #, set, enter the name, set.(continue to next free speed dial key or stop) If this doesn't work then you may have a bad battery on the main board that saves the data if the power goes off.
Feb 04, 2008 | Panasonic Panafax UF-560 Plain Paper Laser...
Panafax UF560 - how to set so confirmation page is automatic ?
Function 7 4 set.
07 (Header Print)
Setting number 1 (Inside copy area) 2 (outside) 3 (none)
Set.
You can also set the header format with Parameter 08(Header Format) 1 is for your Logo and fax number. 2 is for From: to:
Feb 01, 2008 | Panasonic Panafax UF-595 Plain Paper Laser...
Change date/time on panafax 560
press function 7, user parameters, use arrow keys to sccroll through and set time date, ID, logo etc press start or set to confirm
Dec 10, 2007 | Panasonic Panafax UF-560 Plain Paper Laser...
Panasonic Panafax UF-595 Plain Paper Laser Fax Logo
844 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
