Question about Hotpoint Aquarius WD63 Front Load Washer/Dryer
How to cahnge carbon brushes
How to you change the carbon brushes on a Hotpoint Aquarius 1100 wm63 front loader
  • Anonymous Mar 13, 2014
    changed carbon brushes now have f 43 falt
  • Anonymous Mar 31, 2014
    how to change the carbon brushes
    Sergeant:
  • 225 Answers
The brushes usually "come complete with brush-holders", which is a way of selling you something extra that you don't need. Easiest way is to disconnect the machine from the power and the water, turn it onto its front on an old cardboard box and remove the motor from its mountings on the washer. You can usually get acces to one of the brushes really easily and the other is guaranteed to be a real pig, so keep it simple. The brush-holders are usually fastened to the motor casing with either self-tapping screws or small bolts.
I buy my brushes from Ebay sellers and always send them a digital photo of the old brush together with the make and serial number off the motor itself, just to be sure. Brushes can look similar and be that silly millimetre too short, or long, or wide.
Did that answer the question? If not, add a comment and I'll expand further as necessary. Cheers, D.
Posted on Jul 22, 2008
Hotpoint Aquirius 1100 - WM63 Hi, A leak has sprung from my washing machine and being fairly capable I've already had the sump off cleaned that out and re- attached it and checked the door seal for...
Hotpoint Aquirius 1100 - WM63 leaking This video will show you how to find that leak on any front loading washing machine
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
May 31, 2011 | Hotpoint Aquarius WD63 Front Load...
Hotpoint Aquarius 1100 WM63 Not Spinning Clicking Programmer
I would suggest you check the brushes in the motor, as it sounds like they are worn out.
Replace them if they are less than 3 or 4 mm long
This would give you the symptoms you are describing.
Please rate my solution.
Thankyou.
Feb 09, 2010 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint Aquarius 1100 WM63. fills with water...I dont think it is heating water...rarely rotates and spins (saw it once in early stage of J prog only) seems to fill and empty but no rotate or spin....
if it fill with water then stops it is the ellement the machine first fills turns the drum then heats up the thermostat cuts in and the it emptys rinses and spins so if it does not get to temp it will stop or continue to wash forever
Jun 27, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Drum not turning
My problem is the same as colins my hotpoint wm63 is starting okay i.e. water fills up but drum is not turning. I can hear it clicking through the cycle but drum doing nothing. i to have just put in new carbon brushes but still no joy please help
steve
Apr 08, 2008 | Hotpoint Aquarius WD63 Front Load...
Changing belt
the belt seems to be too short, how can i get the belt on the motor and the pulley on the drum?
Mar 29, 2008 | Kenmore 44072 Front Load Washer
Hotpoint aquarius 1100
yes easy to change there are 2 of them look for a single wire going to each side of your motor when u find each wire u have found were your carbon brushes are right you will need a pair of bent nose pliers place the ends either side of the plastic casing if the carbon brushes squeeze and pull the first brush should pull out take wire of now the 2 brush you wont be able to see but its directly across from the first 1 do exact same to take that 1 out now before replacing the new brushes there a small slot running down 1 side of the plastic at the end you will see a small metal bar push this up which will release the carbon now you can fit them
Dec 11, 2006 | Hotpoint Aquarius WD63 Front Load...
Aquarius 1100 WM63
some times when there is no motor action people think the machine has stuck try a set of brushes you must diconnect from the electrical mains first if unsure call an expert you can not put a price on safety
Oct 08, 2006 | Hotpoint Aquarius WD63 Front Load...
Hotpoint Aquarius WD63 Front Load Washer/Dryer Logo
395 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
